8 Replies Latest reply on Jul 24, 2007 7:34 AM by HKabaker
    Hyperlinks not appearing after publishing
    ODoyle Rules
      Hello everyone,
      I'm hoping someone out there can help me out. I'm working with RoboHelp 5.0.2 and i'm working off my C drive. In our project i'm working on, i've created hyperlinks to other HTM pages within the project. The links work fine in the preview but as soon as i publish the project the hyperlinks do not appear. I've removed the link in the project and re-added the links and they still will not appear. Is it possible RH doesn't like to use long file names in the path? This is happening on several pages. Any help would be greatly appreciated.
        • 1. Re: Hyperlinks not appearing after publishing
          You say they do not appear. Is the text there but not formatted as a link? Or has the link text has gone missing?
          Have you tried View Source in the output to see how the link is formatted?
          Is it that all links on these pages do not work or just some?
          If you suspect long file names, have you tried shortening them?
          • 2. Re: Hyperlinks not appearing after publishing
            ODoyle Rules Level 1
            Hello Peter,
            Thanks for replying. The text is still there but it's not formatted as a hyperlink. It's a few links that do not work. On some of the other topic pages the same links work and on others they don't. After it the project is published this is what it looks like through View Source.
            <tr valign="top" class="whs18">
            <td onMouseOver="this.bgColor='rgb(185, 211, 238)'" onMouseOut="this.bgColor='rgb(255, 255, 255)'" ;&quot;width: 85.107%; padding-right: 10px; padding-left: border-left-style: Solid ; border-left-color:
            #7d7d7d; border-right-style: border-right-color: border-bottom-style: border-bottom-color: border-bottom-width: 1px; border-right-width: border-left-width: 1px;&quot; width="79.253%" class="whs28">
            <p class="whs26"><a href>Disbursements,
            Holds, Refunds and Withdrawals</a></td></tr>
            This is what it's suppose to look like through True Code in RoboHelp
            <tr style="x-cell-content-align: top;"
            valign=top>
            <td_null>
            ;&quot;width:
            85.107%;
            padding-right:
            10px;
            padding-left:
            border-left-style:
            Solid;
            border-left-color:
            #7d7d7d;
            border-right-style:
            border-right-color:
            1px;
            border-right-width:
            border-left-width:
            1px;&quot;
            style="width: 79.253%;
            padding-left: 10px;
            border-right-style: none;
            border-bottom-style: dashed;
            border-bottom-width: 1px;"
            width=79.253%>
            <p style="color: #959595; font-size: 8pt;"><a href="../../Disbursements_Holds_Refunds_and_Withdrawals/DeVry_Call_Center_Disbursements_H olds_Refunds_and_Withdrawals.htm">Disbursements,
            If i open up the published HTM and paste
            <a href="../../Disbursements_Holds_Refunds_and_Withdrawals/DeVry_Call_Center_Disbursements_H olds_Refunds_and_Withdrawals.htm">Disbursements, Holds, Refunds and Withdrawals</a>
            the code into the HTM and save it, it works; however when the project is published again RoboHelp will overwrite the HTM and the hyperlink will disappear.
            • 3. Re: Hyperlinks not appearing after publishing
              With paths like that you don't need any content in your topics! :-)
              If you look at the output, there is a tag <a href>. That should also contain the path and file name. My guess is that you are on track suspecting the length.
              Check the length of those that work and those that do not.
              Also, I assume the target is in the project.
              • 4. Re: Hyperlinks not appearing after publishing
                Hello Peter,
                Yes, those are long paths. On other pages the same links work but on certain pages they don't work. Yes, the target is within the project.
                This is kind of frustrating
                • 5. Re: Hyperlinks not appearing after publishing
                  Hello Peter,
                  I believe it doesn't work because the pathway is too long. What i did was deleted "Disbursements_Holds_Refunds_and_Withdrawals/" out of the path so it looks like this
                  <a href="../../DeVry_Call_Center_Disbursements_Holds_Refunds_and_Withdrawals.htm">Disburseme nts,
                  Holds, Refunds and Withdrawals</a> then i re-published the project and the hyperlink worked. I can't believe RoboHelp can't handle long pathway names.
                  thanks for trying to help me out.
                  • 6. Re: Hyperlinks not appearing after publishing
                    HKabaker Level 2
                    ODoyle,
                    If I have copied and pasted correctly from your posts, the first path is not the same as the second. It looks like the first has one more level of directories to travel than the second one. If the second one is correct, that means the first would be flagged as a broken link and not carried over into the output.
                    1.
                    <a href=
                    "../../Disbursements_Holds_Refunds_and_Withdrawals/DeVry_Call_Center_Disbursements_Holds_R efunds_and_Withdrawals.htm">Disbursements,
                    a href=
                    (Back up two levels, go into the directory Disbursements_Holds_Refunds_and_Withdrawals,
                    and open the topic
                    DeVry_Call_Center_Disbursements_Holds_Refunds_and_Withdrawals.htm)
                    2.
                    "../../DeVry_Call_Center_Disbursements_Holds_Refunds_and_Withdrawals.htm">Disbursements, Holds, Refunds and Withdrawals</a>
                    and open the topic
                    Or are you saying that the first was correct, and you changed the directory structure in between, so the second also was correct. but the first didn't work because it was too long?
                    Harvey
                    • 7. Re: Hyperlinks not appearing after publishing
                      quote:
                      Originally posted by: HKabaker
                      ODoyle,
                      1.
                      <a href=
                      a href=
                      and open the topic
                      2.
                      and open the topic
                      Harvey
                      Hello Harvey.
                      The first one is the correct pathway and that is the one RoboHelp has isses with and did not generate the hyperlink.
                      The second one is the incorrect one, what i did was delete the folder "Disbursements_Holds_Refunds_and_Withdrawals/" out of the pathway to shorten it up and then i published the project to test the long pathway theory. After the project was published, RoboHelp finally generated the hyperlink. Just to let you know, i did not physically change the directory structure, only the deleted a directory from the pathway just to shorten it up.
                      • 8. Re: Hyperlinks not appearing after publishing
                        HKabaker Level 2
                        ODoyle,
                        I've sent you a private message.
                        Harvey
