6 Replies Latest reply on Sep 14, 2010 5:11 AM by Deh Bontempos
    call responder within a loop. How to get those info?
    Deh Bontempos
      whats the method to retrieve information like this?
      The idea is to retrieve a information on data base based on the item's id.
      private var ids_ac:arrayCollection = new ArrayCollection([{id:4},{id:5},{id:6}]);  //these are the ids i have to retrieve info private var ids_results:array = new Array(); for ( var i:String in ids_ac ) {      getProcessedResult.token = Service.getProcessed( ids_ac[ i ].id );         //this returns an integer.      getProcessedResult.addEventListener(ResultEvent.RESULT,onResult);      function onResult(e:ResultEvent):void      {           ids_results.push(e.result.data)  // only the last id results are stored because the onResult function comes after all the looping is finished.      } }
      while debugging I saw the all the looping is performed before the onResult take place. This way, one result is overrider the earlier result.
      is there any method I can do this?
      Thanks in advance!
      Btp~
        • 1. Re: call responder within a loop. How to get those info?
          jfb00 Level 3
          Hi ,
          You don't have to do a loop.
          When you call your method, the result can be add in your array collection like:
          private var ids_ac:arrayCollection = new ArrayCollection();
               ids_ac = ArrayCollection(e.result);
          If you want to add items to your array collection then use ids_ac.addItem( );
          Also after adding an item don't forget to use ids_ac.refresh();
          Rgds
          Johnny
          • 2. Re: call responder within a loop. How to get those info?
            Gregory Lafrance Level 6
            Hard to read your code post. You may want to format it better so we can read it easier.
            • 3. Re: call responder within a loop. How to get those info?
              Deh Bontempos Level 1
              thanks for the reply. The code was well formated while I posted. For some reasons, I should not use the "html" formater.
              My workaround is to make a ping pong btw 2 functions:
              private var function ids_results():void
                   var ck:int = array.lenght; //number of ids to check;
                   var i:int = 0;
                   go();
                   function go():void
                       if ( i < ck )
                        else
                             // end of function...fill the dataprovider or something
                        ids_results.push(e.result.data);
                         i++;
                         go(); //call function again AFTER fetch the result (processed) from previous ID.
              Just to be clear, I dont mean to getAllItems. I mean that I have those items already and I want to process each one by its ID.
              the "getProcessed" is a method that returns an int based on the id.
              Btp~
              • 5. Re: call responder within a loop. How to get those info?
                Radhakrishna Bhat Level 3
                Another way is to instantiate new CallResponder in 'for' loop. This will make OnResult to be called for every result returned.
                     getProcessedResult = new CallResponder();
                -Radhakrishna
                • 6. Re: call responder within a loop. How to get those info?
                  This looks like a more robust approach.
                  Thanks so much for the code, Radhakrishna.
                  Thanks for those links, Jonny. They weren`t exactly what i needed here but they were useful still.
                  Wish you all the best.
                  Btp~
