0 Replies Latest reply on Sep 12, 2010 4:01 PM by hadar1
    casting problem
    hadar1
      I write an flex application using blazeds.
      I define new class in java in server side called DataColumn.
      I configure the return type and generate service call.
      I am returning list of DataColumn.
      For debugging I put the following code :
                          var t : Object = columns.getItemAt(i);
                          if(t == null) {
                              Alert.show("NULL");
                          } else {
                              var x :DataColumn = t as DataColumn;
                              if(x == null) {
                                  Alert.show("NULL2");
      In the first time it called I see that x is NULL. ("NULL2" message appear)
      From the second time I call the server it works OK (no message appear).
      When run in debug mode I see that t has value (not null)  but x get null in first time and after that x is equal to t.
      What can cause this issue ?
