1. Re: P7 Menu Visibility Problem
MurraySummers Sep 13, 2010 10:15 AM (in response to Missteach)You should take this to the PVII forums - response there is fantastic.
2. Re: P7 Menu Visibility Problem
Al Sparber Sep 13, 2010 10:45 AM (in response to Missteach)I can't seem to get P7's 'Pop Menu Magic 2' to display correctly. It reveals its menu behind the image below it on the page. if
you get chance, have a look at http://www.bemday.co.uk/Energy%20Studios%20Website/index.html. Don't look at the actual site - it's
just a test but I'm puzzled why the menu hides behind my image below. On P7's site there is some info about using the Z-index that I
think I implemented but it doesn't seem to work in this case.
It's obvious that page was generated by a third-party application. I've never actually seen such a simple page layout written quite
so poorly in terms of markup and CSS. I would strongly advise against using it in the future. In any event, this is the rule, in
your other style sheet, which is causing the problem:
Prevents the non-intuitive collapsing margins default behaviour of the W3 Box Model.
This rule is recognized by all modern browser (Firefox, Opera, IE8, Safari, Chrome and other) and IE7, but not by IE6 or the
Dreamweaver design view.
IE6 does not collapse margins and for DW the problem was solved in another way.
.cssLO > .cssLI:first-child
Remove the rule.
Al Sparber - PVII
Dreamweaver Menus | Galleries | Widgets
http://www.projectseven.com/go/hgm
The Ultimate Web 2.0 Carousel
3. Re: P7 Menu Visibility Problem
Missteach Sep 13, 2010 12:11 PM (in response to MurraySummers)Hello Murray,
I buy all P7 stuff the day it gets announced because they are simply that good. And, it's rare I get a problem with their extensions. However, when I do, I can't use their forums because I don't have the correct reader for the newsgroups. There doesn't appear to ba any way I can get Outlook to let me in. I understand it's simple with Outlook Express but I don't use it. Therefore, I have to occasionally ask for help here.
4. Re: P7 Menu Visibility Problem
Missteach Sep 13, 2010 12:18 PM (in response to Al Sparber)Hi Al,
Thanks for the quick response. I'll look through your pointer now. You're a star.
The program I used is called 'Flexi Layouts' and is a dream to use: http://www.extendstudio.com/product/tableless-css-layouts-for-dreamweaver.html if you want to create tableless design in seconds. I didn't realise it was causing such a confilict though. To be fair, it could well have been a setting I clicked on with the prog that caused the problem; although it is all self explanatory to use.
Anyway, thanks again for the quick response.
When's your next one out? As usual, I monitor the P7 site each day waiting with anticipation.
Cheers
5. Re: P7 Menu Visibility Problem
Al Sparber Sep 13, 2010 12:54 PM (in response to Missteach)The program I used is called 'Flexi Layouts' and is a dream to use:
6. Re: P7 Menu Visibility Problem
Al Sparber Sep 13, 2010 12:57 PM (in response to Missteach)There doesn't appear to ba any way I can get Outlook to let me in. I understand it's simple with Outlook Express but I don't use
