I am about to move my systems to 64 bit and upgrade three suites to full Master Collections because of the Premier Pro and After Effects 64Bit support.
I have read that the Flash plugin does not work on 64 bit browsers but if I use a 32 bit browser (which windows provides) on a 64Bit OS it will work fine in that 32 bit browser.
When I install the Flash professional CS5 software on my 64Bit system will it have issues when I test using the plugin with in Flash Professional or will I have to always test useing the 32 Bit browser? if yes...
Correct me if I am worng when I use the main menu control, test movie , Flash Pro. app uses the flash plugin to test .swf moves right?
How will I utilize the simulated download settings and simulated download which is part of the plugin and it cannot operate in a 64 bit OS environment?
64 Bit challenged....
INVT
32bit flash works without problem in 64bit systems.
your flash players will be 32 bit, in addition, to your flash program.
the only limitation is you will be unable to use a 64bit browser with a flash plug-in, at this time.
