4 Replies Latest reply on Sep 16, 2010 9:44 PM by Radhakrishna Bhat
    Generate sample PHP service from db could not set primary key
    biyd
          Some information about my system:
      OS :Windows 7 64 bit
      Computer type: HP Pavilion dv6-3013cl laptop
      Eclipse 3.5+Flash Builder 4 plugin
      DB: MySQL 5.0 local server
      Web Server: Apache 2.2+PHP 5.2.14
      Zend Frame work 1.10.1 (installed by Flash Builder)
          I am trying to configure a PHP service in the Connect to Data/Service wizard. I clicked "click here to generate a sample" to generate a Sample PHP service. I selected Generate from database radio button and entered the db connection information in all fields. I am able to connect to my local database and select the table I want to create the service. But after I selected the primary key from the dropdown, the Ok button is still disabled and a warning note at the bottom of the screen still prompt for selecting the table's primary key. At this point, the log in eclipse metadata folder in the workspace has the following error:
      !ENTRY org.eclipse.ui 4 0 2010-09-13 09:05:23.565
      !MESSAGE Unhandled event loop exception
      !STACK 0
      java.lang.NullPointerException
          at com.adobe.flexbuilder.services.PHPService.serverproto.ColumnModel.setType(ColumnModel.jav a:204)
          at com.adobe.flexbuilder.services.PHPService.serverproto.ColumnModel.buildFromColumn(ColumnM odel.java:218)
          at com.adobe.flexbuilder.services.PHPService.PHPService.setPrimaryKeyColumn(PHPService.java: 185)
          at com.adobe.flexbuilder.services.PHPService.serverproto.MySQLConfigurationDialog$4.widgetSe lected(MySQLConfigurationDialog.java:419)
          at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
          at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
          at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
          at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
          at org.eclipse.jface.window.Window.open(Window.java:801)
          at com.adobe.flexbuilder.services.PHPService.PHPConfigurationPage$6.widgetSelected(PHPConfig urationPage.java:240)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
          at org.eclipse.swt.widgets.Link.wmNotifyChild(Link.java:1004)
          at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4877)
          at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:1757)
          at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4507)
          at org.eclipse.swt.widgets.Control.windowProc(Control.java:4000)
          at org.eclipse.swt.widgets.Display.windowProc(Display.java:4602)
          at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
          at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2312)
          at org.eclipse.swt.widgets.Link.callWindowProc(Link.java:172)
          at org.eclipse.swt.widgets.Widget.wmLButtonUp(Widget.java:1917)
          at org.eclipse.swt.widgets.Control.WM_LBUTTONUP(Control.java:4301)
          at org.eclipse.swt.widgets.Link.WM_LBUTTONUP(Link.java:842)
          at org.eclipse.swt.widgets.Control.windowProc(Control.java:3982)
          at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
          at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2409)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3471)
          at com.adobe.flexbuilder.DCDService.ui.wizard.ServiceWizard.show(ServiceWizard.java:190)
          at com.adobe.flexbuilder.DCDService.ui.wizard.ServiceWizard.createService(ServiceWizard.java :152)
          at com.adobe.flexbuilder.dcrad.views.ServiceExplorerView$1.handleEvent(ServiceExplorerView.j ava:528)
          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
          at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
          at java.lang.reflect.Method.invoke(Unknown Source)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
      I figured this explains why the OK button is not enabled. I could trick the screen by clicking the Generate from template radio button and back to clicking the Generate from database button which will enable the OK button. I clicked OK, and a Security Information warning about ricks of generating the service php file popped up asking if I want to continue. I clicked OK and back to the generate sample PHP service screen. After this, the process entered an endless Ok-warning-OK-warning-OK loop and could never proceed to actually generating the service file. In the Eclipse log file, I see more Unhandled event loop exception:
      !ENTRY org.eclipse.ui 4 0 2010-09-13 11:11:30.482
      !STACK 0
      !ENTRY org.eclipse.ui 4 0 2010-09-13 11:12:07.460
      !STACK 0
          at com.adobe.flexbuilder.services.PHPService.PHPService.fillUpModel(PHPService.java:221)
          at com.adobe.flexbuilder.services.PHPService.PHPService.createFlexService(PHPService.java:27 7)
          at com.adobe.flexbuilder.services.PHPService.serverproto.MySQLConfigurationDialog.okPressed( MySQLConfigurationDialog.java:948)
          at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:472)
          at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
      !ENTRY org.eclipse.ui 4 0 2010-09-13 11:14:34.534
      !STACK 0
      I was able to do this on my old windows xp (Media Center OS) laptop. I wonder if this problem has anything to do with the Windows 7's system permission security feature. I 've stuck for 2 days now. Can someone help?! Thanks so much!
