4 Replies Latest reply on Sep 14, 2010 2:50 PM by tyuiop86
    PopupAnchor inside a custom component
    tyuiop86
      Hi All,
      I have an autoComplete custom component built using a TextInput control and PopupAnchor, and I am having problem trying to re-use the component.
      The problem is the component only built the PopupAnchor once, then refer to the same popup every time I instantiate the autoComplete else where.
      For instance, I have the autoComplete on the app header and I want to reuse it on a item order screen. Since the component does not create a new instance of popup, if I do something on the item order screen, the autoComplete would popup on the header instead of the screen.
      Is it even possible to have multiple PopupAnchor in one application ? or probably a property that I can set so that PopupAnchor is destroyed on displayPopup = false ?
      Please help.. thanks..
        • 1. Re: PopupAnchor inside a custom component
          Flex harUI Adobe Employee
          Run a test with two DropDownLists.  They work independently don't they?
          • 2. Re: PopupAnchor inside a custom component
            tyuiop86 Level 1
            Can you explain more where to add the DropDownList ? I tried adding a drop down in my custom component, then use my custom component in two different places, both drop down works fine.
            Does drop down list use PopUpAnchor ?
            My custom component is an actionscript class with a skin.. below is the mxml markup from the skin for the popUpAnchor:
            <s:PopUpAnchor id="popUp"
                    displayPopUp="false"
                    includeInLayout="false">
            is there any other property I need to set up ?
            Thanks for the reply, I really need help on this one..
            • 3. Re: PopupAnchor inside a custom component
              tyuiop86 Level 1
              One more thing.. I have found one work around which is to add static public variable to store the x and y coordinates of the popUpAnchor
              so in my SearchBar.as component I have:
              [Bindable]
              static public var xPos:Number;
              [Bindable]
              static public var yPos:Number;
              and in my skin, I bind PopUpAnchor x and y to those var:
                      x="{SearchBar.xPos}" y="{SearchBar.yPos}"
              What I dont' undestand is I've seen other people's component that uses PopUpAnchor and it doesn't have this problem.. so there must be something that I am missing right ?
              • 4. Re: PopupAnchor inside a custom component
                tyuiop86 Level 1
                help anyone ? harUI ?
