1 Reply Latest reply on Sep 14, 2010 4:01 AM by rootsounds
    Calling event called in a component but set in another?
    RandomReado Level 1
      I have two components, both called from my main application. I've added an event listener in one of the components, but when I try to dispatch the event in the other component, nothing happens. Can anyone explain why this is please?
        • 1. Re: Calling event called in a component but set in another?
          rootsounds Level 4
          It sounds like you have the following:
          • Component A - has a listener attached for some event.
          • Component B - dispatches the event.
          Assuming this is a correct interpretation, it's pretty clear why nothing happens. You have a listen attached to A, but A never fires the event. It is B that fires the event, but you are not listening to it. Attach the listener to B and have the handler function perform whatever operation is desired on A.
