1 Reply Latest reply on Sep 13, 2010 11:31 PM by Balakrishnan V
    How to read forward slash from xml file
    flexchief Level 1
      I am reading in values from a complex xml file but am unable to read values that contain a forward slash ('/').
      For example: <key>Year</key><integer>2004</integer> can not be read because of these slashes?
      Can anyone please tell me how to read these values as strings?
      Adam
      Flexchief
        • 1. Re: How to read forward slash from xml file
          Balakrishnan V Level 3
          XML::toString() and XML::toXMLString() methods return a string.
          String::indexOf()
          String::lastIndexOf()
          String::search()
          These methods can be applied on strings to find location of '/'
          However your problem seems to be that of accessing the values "Year" and "2004".
          To do this, you can use e4x to access fields.
          var xml:XML= <XML><key>Year</key><integer>2004</integer></XML>
          use xml.key and xml.integer to access the fields
          Hope this helps
          balakrishnan v
