4 Replies Latest reply on Sep 14, 2010 10:47 AM by bobgalka
    How to set a property in one custom component from another
    bobgalka
      Hey all....
      I have been trying to lean how to refactor code from Catalyst in Flash Builder... Making progress but I am stumped on how to handle the following...
      I have one custom component that processes files from a couple of directories... I have another custom component that displays progress bars for each directory...  so.. in the file processing component I want to manually update the progress bars with the setProgress function....
      Here is the progress bar module....  (let's call it CustomComponent10.mxml)
      <s:Group
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:components="components.*"
      xmlns:d="http://ns.adobe.com/fxg/2008/dt"
      xmlns:mx="library://ns.adobe.com/flex/mx">
      <s:Rect height="150" d:userLabel="progressContainer" width="443" x="0.5" y="0.5">
      <s:stroke>
      <s:SolidColorStroke caps="none" joints="miter" miterLimit="10" weight="1"/>
      </s:stroke>
      </s:Rect>
      <mx:ProgressBar x="16" y="12" id="beforeProgress" width="418"
      mode = "manual"
      minimum = "0"
      maximum = "100"
      visible = "true"
      direction="right"
      labelPlacement="center"
      label="Before Images 0%"/>
      <mx:ProgressBar x="16" y="56" width="418" id="afterProgress"
      mode = "manual"
      minimum = "0"
      maximum = "100"
      visible = "true"
      direction="right"
      label="After Images 0%"/>
      <mx:ProgressBar x="16" y="102" width="418" id="bgProgress"
      mode = "manual"
      minimum = "0"
      maximum = "100"
      visible = "true"
      direction="right"
      label="Background Images 0%"/>
      </s:Group>
      so from the file processing module (let's call it CustomComponent4.mxml) I try to code the following.....
      public var app:Object = mx.core.FlexGlobals.topLevelApplication;
      if (app.folder == "before")
      app.beforeProgress.setProgress(app.index, app.files.length);
      app.beforeProgress.label = "Before Images: " + (app.file.length/app.index)*100 + "%";
      else
      app.afterProgress.setProgress(app.index, app.files.length);
      app.afterProgress.label = "After Images: " + (app.files.length/app.index)*100 + "%";
      but I get this at run time.....
      ReferenceError: Error #1069: Property beforeProgress not found on Main and there is no default value.
      at components::CustomComponent4/doLoaderComplete()[C:\Users\Bob\Adobe Flash Builder 4\BeforeAndAfterGallery-artboards_1\src\components\CustomComponent4.mxml:127]
      what to do.. what to do...  ;O)
      thanks for looking
      bob
