7 Replies Latest reply on Sep 15, 2010 1:33 AM by anilreddy_narra
    display the image in flex using XML content???
    anilreddy_narra
      Can u find the belox XML and flex code..
      Can any one help to display the image in flex using XML content?
      Flex code:
      <mx:Repeater
      id="rp" width="950">
      <mx:VBox
      backgroundColor="#6B735B" label="{rp.currentItem.body_frag_title}" >
      <mx:Label
      id="lblid" text="{rp.currentItem.body_frag_title}" color="#070000" fontSize="15"/>
      <mx:Text
      text="{rp.currentItem.body_frag_text}" width="950" color="#070000" fontSize="10"/>
      <mx:Image
      source="{rp.currentItem}"/>
      </mx:VBox>
      </mx:Repeater>
      XML code
      body_frag>
      body_frag_title>Persistent Objects
      body_frag_title>
      pic src="Images/2.jpg"></pic>
      body_frag_text>
      Data in database systems are held in persistent objects
      A persistent object survives the processes that creates and manipulates it
      When such a process ceases to exist the persistent object remains
      body_frag_text>
      body_frag>
        • 1. Re: display the image in flex using XML content???
          BhaskerChari Level 4
          Hi anilreddy_narra,
          Try the code below....
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
          <mx:XML id="myXml" xmlns="">
          <body_frag>
            <body_frag_title>Persistent Objects</body_frag_title>
            <pic src="Images/2.jpg"></pic>
            <body_frag_text>
            </body_frag_text>
          </body_frag>
          </mx:XML>
          <mx:Repeater id="rp" width="950" dataProvider="{myXml}">
            <mx:VBox backgroundColor="#6B735B" label="{rp.currentItem.body_frag_title}" >
             <mx:Label id="lblid" text="{rp.currentItem.body_frag_title}" color="#070000" fontSize="15"/>
             <mx:Text text="{rp.currentItem.body_frag_text}" width="950" color="#070000" fontSize="10"/>
             <mx:Image source="{rp.currentItem.pic.@src}"/>
            </mx:VBox>
          </mx:Repeater>
          </mx:Application>
          If this post answers your question or helps, please kindly mark it as such.
          Bhasker Chari
          • 2. Re: display the image in flex using XML content???
            anilreddy_narra Level 1
            Hello,
            How did u take the below code? body_frag, body_frag_title, body_frag_text are located in XML file that is my data source. Flex is my presentation side. I didn't understand .......... <mx:XML id="myXml" xmlns="">.
            my question is: how to load the XML image in flex? I have 3layers in my project. Data source is XML,Business layer is c# webservice and presentation layer is flex. I have displayed the label and text from XML. But,I am facing the problem with image..
            Can u please help me?
            <body_frag>
              <body_frag_text>
              </body_frag_text>
            </body_frag>
            </mx:XML>
            • 3. Re: display the image in flex using XML content???
              Hi anilreddy_narra,
              I have just used your xml which you have posted in your previous post and placed in a local xml tag so that I can have access to your xml.
              You dont worru about that you just replace the Repeater below with your repeater component and check whether image is being displayed now ..??
              Make sure that the images are present in your Images folder in your Flex application...
                </mx:VBox>
              </mx:Repeater>
              Bhasker
              • 4. Re: display the image in flex using XML content???
                XML file is different..Where can I use xml id=myXml?
                The below is my flex code..I have 2images in src/Images/1.jpg,2.jpg..
                What is the data provider to my repeater in this case?
                Flex code:
                <mx:VBox
                label="Theory" borderColor="#030704">
                <mx:Label
                text="Theory" id="lblTheory" fontSize="30" textDecoration="underline" fontFamily="Times New Roman" color="#ED4307"/>
                <mx:LinkBar
                dataProvider="{viewStack1}" direction="horizontal"
                height="
                29" textDecoration="underline"/>
                <mx:ViewStack
                id="viewStack1" height="600" width="800">
                <mx:Repeater
                <mx:VBox
                backgroundColor="#6B735B" label="{rp.currentItem.body_frag_title}" showEffect="{wipeRight}" hideEffect="{wipeLeft}">
                <mx:Label
                <mx:Text
                <mx:Image
                </mx:VBox>
                mx:Repeater>
                </mx:ViewStack>
                </mx:VBox>
                I have one big XML file..THe below is the smallest part among tha part....
                XML code part:
                body_frag>
                body_frag_title>
                body_frag_text>
                body_frag_text>
                body_frag>
                body_frag>
                body_frag_title>Relations
                body_frag_title>
                pic src="Images/1.jpg"></pic>
                body_frag_text>Persistent objects in a relational database exist as Relations
                Relations can be thought of as tables if the tables possess certain properties
                Normalisation is the process of creating tables that have the properties of relations, and no redundant data
                body_frag_text>
                body_frag>
                Webservice code:
                public
                string getTheory(string workBookName,string workPageName)
                XmlDocument xDoc = new XmlDocument();
                xDoc.Load(Server.MapPath(
                "modules_workbooks.xml"));
                XmlNode workBook = xDoc.SelectSingleNode(@"//workbooks/workbook[module_title=" + @"""" + (string)workBookName + @"""" + "]");
                XmlNodeList workPageNode = workBook.ChildNodes;
                StringBuilder str = new StringBuilder();
                foreach (XmlNode nx in workPageNode)
                if (nx.Name == "workpage")
                if (nx.Attributes["pagetitle"].Value == workPageName)
                try
                foreach (XmlNode n in nx)
                if (n.Name == "theory")
                str.Append(
                "<NewDataSet>");
                str.Append(n.InnerXml.ToString());
                str.Append(
                "</NewDataSet>");
                catch (Exception ex)
                throw (ex);
                return str.ToString();
                • 5. Re: display the image in flex using XML content???
                  I am using web services to get the data from XML..
                  <mx:WebService
                  id="
                  businessCatalystWebService"
                  wsdl="
                  http://localhost:57980/WebService1/Service.asmx?wsdl"
                  showBusyCursor="
                  true">
                  <mx:operation name="getMenu" resultFormat="object" result="handleMenu(event)"/>
                  <mx:operation name="getTheory" resultFormat="object" result="handleResult1(event)"/>
                  <mx:operation name="getObjectives" resultFormat="object" result="handleResult2(event)"/>
                  <mx:operation name="getPractices" resultFormat="object" result="handleResult3(event)"/>
                  <mx:operation name="getLinks" resultFormat="object" result="handleResult4(event)"/>
                  <mx:operation name="getAssessments" resultFormat="object" result="handleResult5(event)"/>
                  <mx:operation name="getModuleGuide" resultFormat="object" result="handleResult6(event)"/>
                  </mx:WebService>
                  The below is the handlefunction for getTheory
                  <mx:Application
                  xmlns:mx="http://www.adobe.com/2006/mxml" width="100%"
                  height="
                  100%" layout="absolute"
                  creationComplete="inIt()" viewSourceURL="
                  srcview/index.html"
                  backgroundImage="
                  C:\Users\h8069566\Documents\Flex Builder 3\XmlReading\src\wallpaper_1280x1024.jpg" backgroundColor="#97A5E3">
                  Bindable]
                  public var menuBarCollection:XMLListCollection;
                  public
                  function inIt():void
                  businessCatalystWebService.getMenu();
                  private function complete():void
                  pnl.visible =
                  true;
                  rp.dataProvider =
                  rp2.dataProvider =
                  rp3.dataProvider =
                  rp4.dataProvider =
                  rp5.dataProvider =
                  rp6.dataProvider =
                  lblMod.visible =
                  false;
                  lblAssess.visible =
                  false;
                  lblObj.visible =
                  false;
                  lblLinks.visible =
                  false;
                  lblPra.visible =
                  false;
                  lblTheory.visible =
                  false;
                  businessCatalystWebService.getTheory(menuItm,itemText);
                  businessCatalystWebService.getObjectives(menuItm,itemText);
                  businessCatalystWebService.getPractices(menuItm,itemText);
                  businessCatalystWebService.getLinks(menuItm,itemText);
                  businessCatalystWebService.getAssessments(menuItm,itemText);
                  businessCatalystWebService.getModuleGuide(menuItm,itemText);
                  public
                  function handleResult1(event:ResultEvent):
                  void
                  var queryxml:XML = new XML(event.result);
                  var xl:XMLListCollection = new XMLListCollection(queryxml.body_frag);
                  if(xl.length > 0)
                  rp.dataProvider = xl;
                  lblTheory.visible =
                  true;
                  I hope u understand the problem..please help me....
                  Thank you
                  • 6. Re: display the image in flex using XML content???
                    Hi anil,
                    You dont need to use the xml id that I have used (myXml) ....You just give the same dataprovider which you are assigning earliar to  your Repeater component.
                    But just replace only the Repeater component code which I have posted but give your own dataprovider which you are assigning earliar instead of myXml as I have used in my code...
                    Bhasker
                    • 7. Re: display the image in flex using XML content???
                      I tried the code which u have sent.
                      <mx:Image source="{rp.currentItem.pic.@src}"/>..
                      Image is not displaying with the above code..I think some problem with loading..I didn't understand what was the problem....
