3 Replies Latest reply on Sep 14, 2010 8:25 AM by rtalton
    RegExp
    Agent-96
      I have a regular expression from which I want to validate a String.   I can get this to work in Java but not in Flex.
      The Flex (Actionscript) code is:
      var stringToCheck:String = "someString";
      var pattern:RegExp =  new RegExp("([A-Z]|[a-z]|\\*|@|[0-9]|_|$|\\-)*");
      trace(stringToCheck.search(pattern));
      This always returns 0 regardless of the input string.
      What I am hoping is that I can determine if I have a valid string such as 'thisIsValid' or an invalid string such as 'this#is#invalid'
      I have also created another simple test, which I can't get to work:
      var pattern:RegExp =  new RegExp("([A-Z])*");
      if(pattern.test(inputMe.text)) {
          trace("MATCH " + inputMe.text);
      } else {
          trace("NO MATCH " + inputMe.text);
      trace(inputMe.text + " - " + inputMe.text.search(pattern));
      pattern.test is always true, regardless of the input string, and inputMe.text.search(pattern) always returns 0, regardless of input string (including no input string!)
      Clearly I don't understand how RegEx works in flex, as I always seem to get exactly the same result regardless of expression or input string.  Any help of this would be much appreciated.
