2 Replies Latest reply on Sep 14, 2010 1:36 AM by Pontus Uggla
    Set dropdown indexes?
    Pontus Uggla Level 1
      Can i. like i do in html, set the indexes of a selectbox manually?
      <select>
           <option value="1">Foo</option>
           <option value="2">Bar</option>
      </select>
      What i do now is to set the index first and pregmatch it like:
      .add('item', '1. Foo');
      .add('item', '2. Bar');
      But its not very nice.
      From what i can tell index is protected. Is there a way around it?
      /Pontus
        • 1. Re: Set dropdown indexes?
          Marijan Tompa [tomaxxi] Level 4
          Hey!
          Yeah, It's typical HTML stuff. You can't do it in InDesign.
          You can retrieve index number from selected item like this:
          var myList = ["Item 1","Item 2","Item 3","Item 4"];
          var myWin = new Window('dialog', 'Test Dropdown');
          var myDrop = myWin.add('dropdownlist', undefined, myList);
          // get values
          myDropIndex = myDrop.selection.index;
          myDropValue = myDrop.selection;
          Or, you can create two dimensional array, pust first values into dropdown, and depending on selection.index, you retrieve desired value.
          Hope it helps!
          tomaxxi
          http://indisnip.wordpress.com/
          • 2. Re: Set dropdown indexes?
            What I do now, in my big project, is that i have an object like:
            [{id: 37, value: 'Foo'}, {id: 65, value: 'Bar'}]
            I set Foo and Bar and on selection I loop through and match the values and if they match i look at the id.
            But the values needs to be unique and it takes a few extra lines of code.
