I’m attempting to compile a number of RoboHelp 8 projects into .chm files as part of a nightly build process
Is there a way to pass the Conditional Build Tags (CBT) as parameters to the RHCL.exe on the command line to product different products from the same sources?
Currently the different output .chm files are being created manually using the RoboHelp UI.
Is there some sort of configuration file or maybe I have to run a script to change the Document.Condition property?
If so can I do that from the command line? A sample would be useful.
The help on the RHCL command line is scant, to say the least!
RodP42
Have you checked the help? It says you can use the -l option to produce a particular layout. So provided it has been setup with the appropriate CBT statement, that would meet your need. Read about it here.
![]() | The RoboColum(n) | ![]() | @robocolumn | ![]() | Colum McAndrew |
