2 Replies Latest reply on Sep 14, 2010 8:26 AM by Bart Burkhardt
    Flex Builder 4 and import WSDL (ASP.NET Webservice) it doesn't look good
    Bart Burkhardt
      We are testing Flex Builder 4 WSDL import generate from (ASP.NET Webservice)
      Altough interesting that now the generated value objects have bindable properties, there are some serious problems;
      1. The code generation doesn't create the SOAP credentials header classes and methods, how do we solve this? (prefer not to create a soap header manually)
      2. When the WSDL has a complex type with a return property without a type, it used to generate a class with property with type Object. With Flex Builder 4 this no longer works, it just skips the property!, leaving a gap in the Object.
      Are you also seeing these problems?, got a solution?, please let me know,
      Bart
