3 Replies Latest reply on Sep 15, 2010 2:13 PM by kglad
    Print in flash
    SpiritOfTheWinds Level 1
      Hello,
      For my work I have to introduce a Print button that will prints everything that is in the cart. However, I never did anything of that sort in Flash, so I might need a bit of help.
      For now, I did a bit of research about how to do it and I do understand I'll have to use PrintJob with another MovieClip... but I need a bit of explanations about a few things.
      First, in the cart (which can be printed), there are several "items" that have the same informations, such as the name, the price, comments, etc.
      Do I have to create one MC that contains informations on one row and add it to the AddPage of PrintJob (I will have 5 MC [5 pages] if I have 5 items in cart), or add all the items into the same MC?
      Also, the flash is horizontal (1920x1280). Do I have to change the orientation of the PrintJob to print in landscape?
      Plus, how to know if the text is far enought of the margins? Do I have to consider the margins in the MC and thus puts a good distance between the borders of the MC and my content?
      Adding a "page" to the PrintJob, how does it work? Is it a real "paper page"?
      I hope you understand what I mean by that, I can give more details if needed but I can't give the source (.fla).
      About what I want to print on paper:
      CompanyName
      OrderDate: 2010-08-09
      And other pertinent info
      Item ------- Price ------- Comment
      CD1 ------- $19,99 ----- Blabla
      CD2 ------- $29,99 ----- Bloblo
      "-" being spaces (since I can't use it here). Of course, every column are different TextFields (I just can't do it here in text).
      Thank you!
      Nathalie
        • 1. Re: Print in flash
          a movieclip passed using addPage() should be laid out just like the paper/electronic page you want to print.   whatever you want to appear in print should be added to a movieclip that will be passed in the addPage() method.  each movieclip passed using addPage() will appear as a seperate printed page.
          if you want a movieclip to print landscape, change your printjob to landscape.
          • 2. Re: Print in flash
            Either it doesn't work or the option I'm trying is not working. To not use paper, I try to "print" my flash as a document image (other print option available) and when I click "Print", nothing is saved on my hard drive... but I do use the .addPage(...) and .send().
            If it's the option that's not working, is there a better way to test out the printing instead of using paper? I still haven't tested with paper, I don't want to use 60 pages to test out the print...
            Thanks!
            • 3. Re: Print in flash
              i use doPDF to print to a pdf.  works well for me.
