4 Replies Latest reply on Jul 25, 2007 2:50 AM by vrru
    Flex to AIR Conversion
    vrru
      Dear All
      Please provide some inputs regarding Flex Application into Air (Formally Apollo).As per My senario It is running separately .I would like convert a Flex based Application into AIR format.
      Thanks in Advance
      - vrru
        • 1. Flex to AIR Conversion
          connectricity Level 1
          There really isn't much conversion.
          I would suggest making a new AIR project in Flex and giving that project the same path on your drive as your Flex project.
          Then adjust the settings in the main.xml Flex will create for your AIR Application.
          Check all of your URLs to insure that they are absolute.
          Designate your primary mxml as the default application.
          Then simply publish as a deployable AIR file.
          All of this assumes that you have the Flex 2.0.1 SDK and then the Apollo SDK already installed.
          -Good Luck & Happy WebTopping ;)
          • 2. Re: Flex to AIR Conversion
            vrru Level 1
            ok Thank you for your info
            • 3. Re: Flex to AIR Conversion
              In addition to all the things that you have pointed out, how does one specify the setting for Flex Data Services in an AIR application ?
              • 4. Re: Flex to AIR Conversion
                vrru Level 1
                Hello ghiit,
                This question is also make me to think, In my point of view , we have to edit the settings like <mx:Application> in to <mx:windowedApplication> by comparing the two projects.If we change in mapping -xml then it will be converted into Air Application.
