1 Reply Latest reply on Sep 14, 2010 2:41 PM by Flex harUI
    datagrid and combobox
    RosieGp
      Hi all,
      I have two issues...
      First is that my combobox in datagrid is not populating...
      Here is the code:
      private
      function openWindow():void
      var testWindow:TitleWindow = new TitleWindow();
      testWindow=TitleWindow(PopUpManager.createPopUp(
      this, test, true));
      testWindow["Id"]=testDG.selectedItem.ID;
      private
      function handle_returnTestAC(e:ResultEvent):void
      testArray=ArrayCollection(e.result);
      <mx:DataGrid
      toolTip="Click for Description" id="testDG" dataProvider="{testAC}" doubleClickEnabled="true" eventClick="openWindow()">
      <mx:columns>
      <mx:DataGridColumn dataField="ID" headerText="ID" />
      <mx:DataGridColumn dataField="Michigan_Produce" headerText="Michigan Produce" />
      <mx:DataGridColumn headerText="Type" dataField="TypeName">
      <mx:itemRenderer>
      <mx:Component>
      <mx:ComboBox prompt="Type" dataProvider="(testArray)" labelField="TypeName"/>
      </mx:Component>
      </mx:itemRenderer>
      </mx:DataGridColumn>
      </mx:columns>
      </mx:DataGrid>
      If i call this combobox outside the Datagrid it works:
      <mx:ComboBox
      id="cmb" dataProvider="{testAC}" labelField="TypeName" prompt="Type"/>
      2. Problem is that how do I make "Type" DataGridColumn not double click enabled. as when I make a selection in the combobox it does not open the pop up...
      I'll really appreciate any help... thanks...
