3 Replies Latest reply on Sep 17, 2010 1:00 PM by xbytor2
    Batch/Script 3D Model
    Bloobeet
      Hello,
      I have a Model/Scene in PS/CS5 and I'm looking to batch multiple versions with a different texture map applied to each.
      Here's the basic actions:
      Open "Model" / Load texture "Name_01" from list / Rasterize / Export as PNG using texture file's naming convention, "Name_01" / Repeat...
      This appears to be outside PS actions to accomplish.
      Any thoughts or scripting gurus to recommend?
      Thanks!
        • 1. Re: Batch/Script 3D Model
          xbytor2 Level 4
          Can you record an action that does what you want for a particular model and texture?
          If you can, it can be scripted. I bashed on the 3D stuff a bit and know that it has some quirks which is why I can't say without testing.
          • 2. Re: Batch/Script 3D Model
            Bloobeet Level 1
            Yes, but not entirely. I've got two hurdles...
            1. I'm referencing a new texture file for each instance of my model and using that texture file's naming convention as the final exported PNG. I realize that I could do a batch rename after the fact, so this is not my main issue.
            2. When doing this to a single file I can record an action for everything, but...
            Since the batch of files I'm processing is referenced in the middle of my action (Load "Name_01" as a new texture for model), I don't see how to interpret it into a workable batched script.
            This may require a combination of PS and Automator scripts, but that may be getting too heady for me alone.
            Any help would be great!
            • 3. Re: Batch/Script 3D Model
              xbytor2 Level 4
              Email me a copy of the single-file action and I'll see what can be done.
