1 Reply Latest reply on Aug 15, 2007 1:47 PM by jmryan
    Need help with Flex 2 and XML
    onstar509
      I have a Flex 2 front and back end, and it is fed with an XML file on the server. My problem is that while using the back end to make changes to the XML file, I do not know how to save the XML file again, so I may display the front end with the updated XML after the save. Any information would help, thanks. BGR
        • 1. Re: Need help with Flex 2 and XML
          jmryan Level 1
          I know doing a pushback to the client requires Flex Data Services, but since I don't use FDS I can't tell you exactly how. But look in the documentation about "pushing" data to the client. Once you've figured out how to do that, you can trigger that push once you've finished editing the xml file. You may want to ask over in the FDS forum.
