10 Replies Latest reply on Sep 15, 2010 11:52 PM by jd_ice
    Store duplicate Array values to another Array
    jd_ice
      Hi flex coders,
      As the title says it all, how will I do this in flex? Like for example I have the values 1,1,1,2,2,3. All the duplicated entries need not to be remove but will just be stored in another collection.
      Need some light. Please help!
      Best Regards!
        • 1. Re: Store duplicate Array values to another Array
          rootsounds Level 4
          Would a 2D array make sense?
          • 2. Re: Store duplicate Array values to another Array
            Arun Ganesh Level 3
            Try this,
            var originalArray:Array = [1,2,3,4,2,1,3,3]
            var dupArray:Array = originalArray.slice(0,originalArray.length);
            dupArray=fRemoveDup(dupArray);
            private function fRemoveDup(ac:Array) : Array
                            var i : int;
                            var j : int;
                            for (i = 0; i < ac.length - 1; i++)
                                for (j = i + 1; j < ac.length; j++)
                                    if (ac[i] === ac[j])
                                        ac.splice(j, 1);
                            return ac;
            Kindly mark it, If this is helpful.
            • 3. Re: Store duplicate Array values to another Array
              jd_ice Level 1
              Yeah surely. Can you show me how to do it?
              • 5. Re: Store duplicate Array values to another Array
                jd_ice Level 1
                The way I want it is like this output
                originalArray = new Array(1,1,1,2,2,3)
                output:
                outArr[0] = new Array(1,1,1)
                outArr[1] = new Array(2,2)
                outArr[2] = new Array(3)
                like these ones..
                • 6. Re: Store duplicate Array values to another Array
                  jd_ice Level 1
                  Actually a 2D is what I have. Here's what I got so far.
                  var arr:Array = arrGroup.source as Array;
                  var currentValue:*='';
                  var tempArray:Array;
                  var newArray:Array = new Array();
                  var num:uint = 0;
                  var current:*='';
                  arr.forEach(
                  function(item:*,index:uint,array:Array):void
                  if(currentValue != item["key"])
                  tempArray = new Array();
                  currentValue = item["key"];
                  current = currentValue;
                  if(current == item["key"])
                  var obj:Object = new Object();
                  obj["label"]   = item["label"];
                  obj["key"] = item["key"];
                  tempArray.push(obj);
                  if(tempArray.length > 0){
                  newArray[num] = tempArray;
                  num++;
                  The output is like this.
                         outArr:Array = new Array();
                  outArr[1] = new Array(1,1,1)
                  outArr[2] = new Array(1,1,1)
                  outArr[3] = new Array(2,2)
                  outArr[4] = new Array(2,2)
                  outArr[5] = new Array(3)
                  Depending on the duplicate occurence it's also creating the same number of extractions.
                  So how would do this to look it more like this
                  • 7. Re: Store duplicate Array values to another Array
                    rootsounds Level 4
                    What about creating an associative array where you have keys that give you values representing occurences?
                    Example:
                    myArray[2] = 3; //3 occurences of the key 2
                    myArray["dummy"] = 1; //1 occurence of the key "dummy"
                    • 8. Re: Store duplicate Array values to another Array
                      jd_ice Level 1
                      Please help me review my code to see possible insertions of your idea. Wew, stuck to this the for a couple of hours, I think I should grab a bite first. Will check on this later. Thanks anyways.
                      • 9. Re: Store duplicate Array values to another Array
                        Arun Ganesh Level 3
                        try this,
                                         var distinctArray:Array = originalArray.slice(0,originalArray.length);
                                         distinctArray=fRemoveDup(distinctArray);
                                         var dupCollection:Array=seperateDuplicates(originalArray,distinctArray);
                                     private function seperateDuplicates(orgArray:Array,distinctArray:Array):Array{
                                         var aCollection:Array=[];
                                         for (var i:int = 0; i < distinctArray.length; i++){
                                             var tArray:Array = [];
                                           for (var j:int = 0; j < orgArray.length; j++){
                                                   if(orgArray[j]==distinctArray[i])
                                                       tArray.push(orgArray[j]);
                                            aCollection.push(tArray);
                                         return aCollection;
                                    private function fRemoveDup(arr:Array):Array{
                                         var dupArr:Array = new Array();
                                         arr.sort();
                                         for (var i:int = 0; i < arr.length; i++){
                                           if (arr[i] == arr[i + 1])  continue;
                                          dupArr[dupArr.length] = arr[i];
                                         return(dupArr);
                        • 10. Re: Store duplicate Array values to another Array
                          jd_ice Level 1
                          I got it. What I miss is actually the removing of duplicates. Thanks for the help! Til next time!
