9 Replies Latest reply on Sep 24, 2010 12:47 AM by jimfid45
    Perfect wavy curve
    jimfid45 Level 1
      I do not like using the pen tool, I can never get it just right. What I want to do
      is create a perfect wavy curve. I picture starting with a rectangular vector shape
      and then push part of it up and then part of it down to create the wave. I am including
      a typical result with the pen tool the top image above and what I want to do in the
      image at the botom.  I am not interested in a Pen tool solution.
      So if you follow along with the grey rectangle, push the lower red dot up and then push the upper red dot down. This would then
      form a curve or ellipse ( you specify the radius of curvature ) for either red dot.
        • 1. Re: Perfect wavy curve
          jimfid45 Level 1
          After I posted this, I found this link
          which is an add-on to a CAD program. As you can see
          creating a wavy curve is very easy.
          So I am thinking something native to Fireworks or maybe some extension to Fireworks?
          • 2. Re: Perfect wavy curve
            Linda Nicholls Level 4
            There is such an extension. It's called the Wave Autoshape.
            • 3. Re: Perfect wavy curve
              jimfid45 Level 1
              Hi Linda,
              The auto shape you referenced is already installed in my Fireworks CS5.  I have played around with it for a few days
              and let me show you the problem.
              The image above is close to what I want but the problem is what you see above is the result
              of the stroke being set to 7 and no fill color. I was hoping since I have exactly what I want
              there was a way to change the stroke to a gradient. So imagine a stroke of say  200 pixels
              and then your choice of radial or linear gradients or any gradient. If you mess around with the
              fill color with a gradient and no fill color  you get this below:
              This again is not what I want.
              So then I tried what you see below:
              The above is the result of  a single wave with stroke of 3 and no fill color. And then
              duplicated and then finally using the line tool to close it off. So there are 4 pieces
              total. The problem with the above is I cannot get a fill color assigned to the interior
              of the shape.
              • 4. Re: Perfect wavy curve
                pixlor Level 4
                Fun with vectors!
                I have CS3, so the menu items may be in different places for you.
                Turn on your grid and add snap to grid (it helps).
                Put in a long, narrow rectangle.
                Go to Modify > Alter Path > Simplify (this makes the rectangle a "regular" path).
                Select the pen tool and click along the top and bottom of the rectangle to add points at 1/4, 1/2, and 3/4.
                Use the sub-selection  tool (white arrow) to move the points at 1/4 up and the points at 3/4 down.
                Now you have a sawtooth line, but it can be made curved.
                Go to Windows > Others Path.
                Under Point: Edit: there's an icon that is a curved line with a point.
                Click each of the points you moved up or down, and this icon.
                Depending on how much you move the points, you may want to tweak the inner points so the peaks are narrower. Adjust from the inner part of the curve on both sided.
                Here's what I got (FW doc), inner curves are not tweaked, so you can see the peaks appear wider than the center. You'll want to experiment with how many grid squares you move the points. You can also adjust the handles on the points.
                • 5. Re: Perfect wavy curve
                  pixlor Level 4
                  Oh... And you can put a gradient on it.
                  Drat. The forum software seems to be converting to bitmap .pngs. Here's a FW doc: http://drop.io/FWpixlor/asset/wavylinec-png
                  • 6. Re: Perfect wavy curve
                    jimfid45 Level 1
                    Thanks to Linda and Pixlor. I did say without using the pen tool initially, hoping there was some one-step tool.
                    But I actually did get it (pen tool)  to work with Pixlor's post.
                    2 waves  I created below, which I am happy with.
                    Thanks to both of you again,
                    • 7. Re: Perfect wavy curve
                      pixlor Level 4
                      Hey! Those are really nice!
                      I'm glad you got something you like. Fireworks' vector drawing tools are rather minimal. If you need to do more stuff like this, and don't have or want to invest in Illustrator, you might check out Inkscape (freeware).
                      With vector drawing software you can usually make a single simple line and apply a stroke of the right shape. If needed, you can then change the stroked line to a shape. Drawing programs are really better suited for more advanced drawing than Fireworks. (Er... )
                      Also, depending on what you need you could look for dingbat or ornament fonts. Check dafont and FontSquirrel. Characters can be converted to shapes and edited, too.
                      • 8. Re: Perfect wavy curve
                        richiebee0448654 Level 1
                        You can create perfect curves just with the pen tool.  The key to smoothness is simplicity.  Create your curves with the least number of points possible.
                        This was created with the pen tool and just two points (one on each end).
                        1. Select the pen tool and create a straight line.  Do this by clicking a first point, then double clicking a second point.  You should end up with something like this...
                        2. Select the sub-select tool. Click on the first point you created, then hold down Alt and drag.  A curve point should automatically appear and create a nice curve from your first point.
                        3.  Now do the same thing with the other point, but drag up instead of down.  Your line should be parallel to the line you created from your first point.  What you will find with the second point is that the first time you select and drag, a handle will appear, but nothing will change from your underlying shape.  This is because from each point, there are two curve handles, and their selection follows the direction your shape was created. If there's only a connection on one side of the point (as there is with this particular shape), one of the handles is essentially redundant.  You can safely drag the redundant handle without it having an adverse effect on your shape.
                        4. Now you have a nice curved shape with the minimal number of points.  This simplicity ensures a nice smooth result. Now, just apply a fancy stroke to it... in this case, I chose Calligraphy > Basic.  I went into the editor (Stroke Options > Edit Stroke > Shape) and changed the default angle until it created the shape I was looking for.
                        There are numerous other things I could have done, including Modify > Alter Path > Expand Stroke which will give me a shape I can fill and use many styles on.  For example...
                        Apologies for the long post...  wish I had some capture software like Camtasia (but cheap or free).  If anyone knows of any that works with Windows 7 64 bit, please let me know.
                        Don't be scared of the pen tool.  It's functionality is really simple.  That's a strength, not a weakness.
                        • 9. Re: Perfect wavy curve
                          jimfid45 Level 1
                          Hi richiebee,
                          I wanted to thank-you for the time you spent demonstrating with the pen tool.
