21 Replies Latest reply on Feb 23, 2011 9:20 PM by Priyanka C Herur
    Fireworks CS5 Crashes
    Jeff Cairns
      SYSTEM: Mac OS X 10.6.4 / MacBook Pro - Intel Core 2 Duo @ 2.8 GHz - 4 GB RAM - over 100 GBf free drive space.
      PROBLEM:
      I upgraded to CS5 from CS4 a couple of days ago, but am now experiencing issues with crashes - multiple crashes with a particular key file. The file opens (albeit slowly) and I am able to see all the elements on the multiple embedded layers - as soon as I add any new elements and try to save, CS5 crashes. The file is not large - about 4.8 Mb.
      ATTEMPTED SOLUTIONS:
      Have tried reinstalling CS5 - used Adobe cleaner before reinstall - no joy - same result.
      Have tried clearing all prefs and restarting - same result.
      Have tried safe-boot - no joy - same crash.
      Have tried disabling fonts and cleaning same up - no change
      Have tried using backup versions of the file from a week or so in the past (when it worked) - same result - crash - although it takes a few minutes and a bit of work is done to the file before the crash occurs, in this case. But once the crash occurs, the file will immediately crash on the next launch and save.
      Frankly, I'm out of ideas. CS5 is unusable for me at this point. Considering rolling back to CS4.. but before I do so, would welcome any insight or suggestions.
      Thanks in advance. - Jeff
        • 1. Re: Fireworks CS5 Crashes
          Jeff Cairns Level 1
          Well.. as luck would have it we made one last attempt at solving the issue after posting to this forum and we seem to have nailed down the issue.
          Here is the cause and the solution - hopefully it helps someone else in the future.
          As it turns out the original file had a logo image in it that was developed using some text (in this case the font was Trebuchet MS - although we can't say if that is significant). The text had been turned into paths at some point using TEXT>CONVERT TO PATHS. Thereafter, the entire file had been resized upward by 2X to accommodate a different screen resolution (iPhone 4 vs iPhone orig). With a bunch of systematic trial and error removal of objects, then testing for the crash, we finally ID'd this object as the culprit.
          Anyway - Fireworks CS5 was gakking on this particular element. Once this logo object (with the text to paths conversion and upsizing) was removed, the file behaved normally.
          BTW - It turns out that the file was also misbehaving (crashing) on CS4 (although not as frequently).
          I hope this assists somebody in the future - I know we burned up about 2 days of time trying to nail it down (and of course we finally found the issue after almost giving up and posting the problem here.)
          -Jeff
          • 2. Re: Fireworks CS5 Crashes
            Jeff Cairns Level 1
            Looks like I spoke too soon - we were excited when we thought we had a fix (as per post above), but NOT SO.
            A couple of hours after the fix was made, Fireworks CS5 crashed again on the same file. Once the file crashes it is no longer possible to relaunch and do any work at all on the file. I give up - this is a nasty nasty problem.
            Any thoughts about what might be causing this would be greatly appreciated.
            THE CRASH LOG FOLLOWS: ..
            Process:         Adobe Fireworks CS5 [320]
            Path:            /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/Adobe Fireworks CS5
            Identifier:      com.macromedia.fireworks
            Version:         Adobe Fireworks CS5 version 11.0.0.484 (11.0.0)
            Code Type:       X86 (Native)
            Parent Process:  launchd [159]
            Date/Time:       2010-09-15 15:15:51.562 -0600
            OS Version:      Mac OS X 10.6.4 (10F569)
            Report Version:  6
            Interval Since Last Report:          197762 sec
            Crashes Since Last Report:           76
            Per-App Interval Since Last Report:  106393 sec
            Per-App Crashes Since Last Report:   38
            Anonymous UUID:                      04A1CD9E-BB1A-48C4-8879-45CF3F920273
            Exception Type:  EXC_BAD_ACCESS (SIGABRT)
            Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000bf7feb00
            Crashed Thread:  21
            Application Specific Information:
            abort() called
            Thread 0:  Dispatch queue: com.apple.main-thread
            0   com.adobe.psl                 0x043e56c2 0x4144000 + 2758338
            1   com.adobe.psl                 0x043d3b89 0x4144000 + 2685833
            2   com.adobe.psl                 0x0460b3a0 PSLForceImageRead + 308
            3   com.adobe.psl                 0x0460d919 PSLSetImageSize + 403
            4   com.adobe.psl                 0x0460d9a5 PSLSetImageCanvasSize + 61
            5   com.macromedia.fireworks      0x00b1df68 0x1000 + 11652968
            6   com.macromedia.fireworks      0x00a5e387 0x1000 + 10867591
            7   com.macromedia.fireworks      0x00a5ea23 0x1000 + 10869283
            8   com.macromedia.fireworks      0x0031e47f 0x1000 + 3265663
            9   com.macromedia.fireworks      0x009f734a 0x1000 + 10445642
            10  com.macromedia.fireworks      0x003b4392 0x1000 + 3879826
            11  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            12  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            13  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            14  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            15  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            16  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            17  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            18  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            19  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            20  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            21  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            22  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            23  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            24  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            25  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            26  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            27  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            28  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            29  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            30  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            31  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            32  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            33  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            34  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            35  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            36  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            37  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            38  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            39  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            40  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            41  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            42  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            43  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            44  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            45  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            46  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            47  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            48  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            49  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            50  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            51  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            52  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            53  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            54  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            55  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            56  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            57  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            58  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            59  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            60  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            61  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            62  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            63  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            64  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            65  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            66  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            67  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            68  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            69  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            70  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            71  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            72  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            73  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            74  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            75  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            76  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            77  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            78  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            79  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            80  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            81  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            82  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            83  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            84  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            85  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            86  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            87  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            88  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            89  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            90  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            91  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            92  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            93  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            94  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            95  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            96  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            97  com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            98  com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            99  com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            100 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            101 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            102 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            103 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            104 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            105 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            106 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            107 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            108 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            109 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            110 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            111 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            112 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            113 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            114 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            115 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            116 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            117 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            118 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            119 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            120 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            121 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            122 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            123 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            124 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            125 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            126 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            127 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            128 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            129 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            130 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            131 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            132 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            133 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            134 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            135 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            136 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            137 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            138 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            139 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            140 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            141 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            142 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            143 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            144 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            145 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            146 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            147 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            148 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            149 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            150 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            151 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            152 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            153 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            154 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            155 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            156 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            157 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            158 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            159 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            160 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            161 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            162 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            163 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            164 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            165 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            166 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            167 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            168 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            169 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            170 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            171 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            172 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            173 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            174 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            175 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            176 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            177 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            178 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            179 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            180 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            181 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            182 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            183 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            184 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            185 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            186 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            187 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            188 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            189 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            190 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            191 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            192 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            193 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            194 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            195 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            196 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            197 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            198 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            199 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            200 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            201 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            202 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            203 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            204 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            205 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            206 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            207 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            208 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            209 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            210 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            211 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            212 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            213 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            214 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            215 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            216 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            217 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            218 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            219 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            220 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            221 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            222 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            223 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            224 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            225 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            226 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            227 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            228 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            229 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            230 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            231 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            232 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            233 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            234 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            235 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            236 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            237 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            238 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            239 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            240 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            241 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            242 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            243 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            244 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            245 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            246 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            247 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            248 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            249 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            250 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            251 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            252 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            253 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            254 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            255 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            256 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            257 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            258 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            259 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            260 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            261 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            262 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            263 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            264 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            265 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            266 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            267 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            268 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            269 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            270 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            271 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            272 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            273 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            274 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            275 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            276 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            277 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            278 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            279 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            280 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            281 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            282 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            283 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            284 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            285 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            286 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            287 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            288 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            289 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            290 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            291 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            292 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            293 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            294 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            295 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            296 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            297 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            298 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            299 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            300 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            301 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            302 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            303 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            304 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            305 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            306 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            307 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            308 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            309 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            310 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            311 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            312 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            313 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            314 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            315 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            316 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            317 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            318 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            319 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            320 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            321 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            322 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            323 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            324 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            325 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            326 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            327 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            328 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            329 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            330 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            331 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            332 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            333 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            334 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            335 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            336 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            337 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            338 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            339 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            340 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            341 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            342 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            343 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            344 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            345 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            346 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            347 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            348 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            349 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            350 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            351 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            352 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            353 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            354 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            355 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            356 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            357 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            358 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            359 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            360 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            361 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            362 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            363 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            364 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            365 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            366 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            367 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            368 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            369 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            370 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            371 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            372 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            373 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            374 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            375 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            376 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            377 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            378 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            379 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            380 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            381 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            382 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            383 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            384 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            385 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            386 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            387 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            388 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            389 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            390 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            391 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            392 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            393 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            394 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            395 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            396 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            397 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            398 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            399 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            400 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            401 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            402 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            403 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            404 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            405 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            406 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            407 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            408 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            409 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            410 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            411 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            412 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            413 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            414 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            415 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            416 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            417 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            418 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            419 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            420 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            421 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            422 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            423 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            424 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            425 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            426 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            427 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            428 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            429 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            430 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            431 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            432 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            433 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            434 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            435 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            436 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            437 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            438 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            439 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            440 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            441 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            442 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            443 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            444 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            445 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            446 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            447 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            448 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            449 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            450 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            451 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            452 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            453 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            454 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            455 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            456 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            457 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            458 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            459 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            460 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            461 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            462 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            463 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            464 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            465 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            466 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            467 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            468 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            469 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            470 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            471 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            472 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            473 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            474 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            475 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            476 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            477 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            478 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            479 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            480 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            481 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            482 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            483 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            484 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            485 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            486 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            487 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            488 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            489 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            490 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            491 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            492 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            493 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            494 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            495 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            496 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            497 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            498 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            499 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            500 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            501 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            502 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            503 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            504 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            505 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            506 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            507 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            508 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            509 com.macromedia.fireworks      0x003c0a54 0x1000 + 3930708
            510 com.macromedia.fireworks      0x003aedf9 0x1000 + 3857913
            511 com.macromedia.fireworks      0x003b4442 0x1000 + 3880002
            Thread 1:  Dispatch queue: com.apple.libdispatch-manager
            0   libSystem.B.dylib             0x09106942 kevent + 10
            1   libSystem.B.dylib             0x0910705c _dispatch_mgr_invoke + 215
            2   libSystem.B.dylib             0x09106519 _dispatch_queue_invoke + 163
            3   libSystem.B.dylib             0x091062be _dispatch_worker_thread2 + 240
            4   libSystem.B.dylib             0x09105d41 _pthread_wqthread + 390
            5   libSystem.B.dylib             0x09105b86 start_wqthread + 30
            Thread 2:
            0   libSystem.B.dylib             0x090e015a semaphore_timedwait_signal_trap + 10
            1   libSystem.B.dylib             0x0910dca5 _pthread_cond_wait + 1066
            2   libSystem.B.dylib             0x0913c848 pthread_cond_timedwait_relative_np + 47
            3   ...ple.CoreServices.CarbonCore 0x0c4763b5 TSWaitOnConditionTimedRelative + 242
            4   ...ple.CoreServices.CarbonCore 0x0c4760f3 TSWaitOnSemaphoreCommon + 511
            5   ...ple.CoreServices.CarbonCore 0x0c49a34b TimerThread + 97
            6   libSystem.B.dylib             0x0910d81d _pthread_start + 345
            7   libSystem.B.dylib             0x0910d6a2 thread_start + 34
            Thread 3:
            0   libSystem.B.dylib             0x090e00fa mach_msg_trap + 10
            1   libSystem.B.dylib             0x090e0867 mach_msg + 68
            2   ...ple.CoreServices.CarbonCore 0x0c51f2c0 YieldToThread + 446
            3   ...ple.CoreServices.CarbonCore 0x0c51f3c3 SetThreadState + 134
            4   ...ple.CoreServices.CarbonCore 0x0c51f47e SetThreadStateEndCritical + 111
            5   libPowerPlant2.dylib          0x084d0b51 FW_PowerPlant::LThread::SemWait(FW_PowerPlant::LSemaphore*, long, QHdr&, unsigned char&) + 119
            6   libPowerPlant2.dylib          0x084cfb07 FW_PowerPlant::LSemaphore::BlockThread(long) + 61
            7   libPowerPlant2.dylib          0x084cfb6d FW_PowerPlant::LSemaphore::Wait(long) + 71
            8   libPowerPlant2.dylib          0x084d0f70 FW_PowerPlant::LThread::Cleanup::Run() + 32
            9   libPowerPlant2.dylib          0x084d194e FW_PowerPlant::LThread::DoEntry(void*) + 30
            10  ...ple.CoreServices.CarbonCore 0x0c51fa4f CooperativeThread + 309
            11  libSystem.B.dylib             0x0910d81d _pthread_start + 345
            12  libSystem.B.dylib             0x0910d6a2 thread_start + 34
            Thread 4:
            0   libSystem.B.dylib             0x090e0142 semaphore_wait_signal_trap + 10
            1   libSystem.B.dylib             0x0910dcbc _pthread_cond_wait + 1089
            2   libSystem.B.dylib             0x09156203 pthread_cond_wait + 48
            3   com.adobe.amt.services        0x0f768126 AMTConditionLock::LockWhenCondition(int) + 46
            4   com.adobe.amt.services        0x0f760db0 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 116
            5   com.adobe.amt.services        0x0f76818c AMTThread::Worker(void*) + 24
            Thread 5:
            0   libSystem.B.dylib             0x0910e066 __semwait_signal + 10
            1   libSystem.B.dylib             0x0910dd22 _pthread_cond_wait + 1191
            2   libSystem.B.dylib             0x0910f9b8 pthread_cond_wait$UNIX2003 + 73
            3   ...ple.CoreServices.CarbonCore 0x0c48aa3a TSWaitOnCondition + 126
            4   ...ple.CoreServices.CarbonCore 0x0c47638d TSWaitOnConditionTimedRelative + 202
            5   ...ple.CoreServices.CarbonCore 0x0c471d67 MPWaitOnQueue + 250
            6   com.macromedia.fireworks      0x00ae43cf 0x1000 + 11416527
            7   ...ple.CoreServices.CarbonCore 0x0c455dee PrivateMPEntryPoint + 68
            8   libSystem.B.dylib             0x0910d81d _pthread_start + 345
            9   libSystem.B.dylib             0x0910d6a2 thread_start + 34
            Thread 6:
            6   AdobeACE                      0x02ff46f1 0x2fba000 + 239345
            7   AdobeACE                      0x02ff40ed 0x2fba000 + 237805
            8   ...ple.CoreServices.CarbonCore 0x0c455dee PrivateMPEntryPoint + 68
            9   libSystem.B.dylib             0x0910d81d _pthread_start + 345
            10  libSystem.B.dylib             0x0910d6a2 thread_start + 34
            Thread 7:
            0   libSystem.B.dylib             0x0915849e accept$UNIX2003 + 10
            1   com.macromedia.fireworks      0x0098ff83 0x1000 + 10022787
            2   com.macromedia.fireworks      0x006e205b 0x1000 + 7213147
            3   com.macromedia.fireworks      0x0075dc40 0x1000 + 7720000
            4   com.macromedia.fireworks      0x0095f2f4 0x1000 + 9822964
            5   ...ple.CoreServices.CarbonCore 0x0c455dee PrivateMPEntryPoint + 68
            Thread 8:
            0   libSystem.B.dylib             0x0911d38a recvfrom$UNIX2003 + 10
            1   libSystem.B.dylib             0x0913d147 recv$UNIX2003 + 54
            2   ServiceManager-Launcher.dylib 0x189426cf Invoke + 54887
            3   ServiceManager-Launcher.dylib 0x1894176e Invoke + 50950
            4   ServiceManager-Launcher.dylib 0x1894061f Invoke + 46519
            5   ServiceManager-Launcher.dylib 0x18940671 Invoke + 46601
            6   ServiceManager-Launcher.dylib 0x189406fb Invoke + 46739
            7   ServiceManager-Launcher.dylib 0x1893aafe Invoke + 23190
            8   ServiceManager-Launcher.dylib 0x1893ace7 Invoke + 23679
            9   ServiceManager-Launcher.dylib 0x1893b8c7 Invoke + 26719
            10  ServiceManager-Launcher.dylib 0x1893b9c5 Invoke + 26973
            11  ServiceManager-Launcher.dylib 0x1893edb0 Invoke + 40264
            12  ServiceManager-Launcher.dylib 0x1893f059 Invoke + 40945
            13  ServiceManager-Launcher.dylib 0x1893f687 Invoke + 42527
            14  ServiceManager-Launcher.dylib 0x1893f884 Invoke + 43036
            15  ServiceManager-Launcher.dylib 0x18931826 Login + 1654
            16  ServiceManager-Launcher.dylib 0x18932c71 Login + 6849
            17  ServiceManager-Launcher.dylib 0x1893fdf3 Invoke + 44427
            18  ServiceManager-Launcher.dylib 0x18942341 Invoke + 53977
            19  libSystem.B.dylib             0x0910d81d _pthread_start + 345
            20  libSystem.B.dylib             0x0910d6a2 thread_start + 34
            Thread 9:
            3   com.adobe.adobeswfl           0x1c4a01af APXGetHostAPI + 2599055
            4   com.adobe.adobeswfl           0x1c239b0f APXGetHostAPI + 82415
            5   com.adobe.adobeswfl           0x1c4a029c APXGetHostAPI + 2599292
            6   com.adobe.adobeswfl           0x1c4a0307 APXGetHostAPI + 2599399
            7   com.adobe.adobeswfl           0x1c4a0426 APXGetHostAPI + 2599686
            Thread 10:
            Thread 11:
            3   com.adobe.adobeswfl           0x1c4a0177 APXGetHostAPI + 2598999
            4   com.adobe.adobeswfl           0x1c4bb0ee APXGetHostAPI + 2709454
            Thread 12:
            4   com.adobe.adobeswfl           0x1c6174b8 APXGetHostAPI + 4135832
            Thread 13:
            2   ...ia.Flash Player.authplaylib 0x1f2e8942 ExternalPlayer_Initialize + 1873594
            3   libSystem.B.dylib             0x0910d81d _pthread_start + 345
            4   libSystem.B.dylib             0x0910d6a2 thread_start + 34
            Thread 14:
            3   ...ia.Flash Player.authplaylib 0x1f11315c 0x1ee3a000 + 2986332
            4   ...ia.Flash Player.authplaylib 0x1f134a15 ExternalPlayer_Initialize + 87949
            5   ...ia.Flash Player.authplaylib 0x1f11355a 0x1ee3a000 + 2987354
            Thread 15:
            Thread 16:
            1   libSystem.B.dylib             0x09139c64 nanosleep$UNIX2003 + 188
            2   com.macromedia.fireworks      0x010a46b1 int (*functionptr_cast<int (*)(unsigned long long, cssm_data*)>(void*))(unsigned long long, cssm_data*) + 109105
            3   com.macromedia.fireworks      0x0109d313 int (*functionptr_cast<int (*)(unsigned long long, cssm_data*)>(void*))(unsigned long long, cssm_data*) + 79507
            4   com.macromedia.fireworks      0x010a47de int (*functionptr_cast<int (*)(unsigned long long, cssm_data*)>(void*))(unsigned long long, cssm_data*) + 109406
            5   libSystem.B.dylib             0x0910d81d _pthread_start + 345
            6   libSystem.B.dylib             0x0910d6a2 thread_start + 34
            Thread 17:
            2   com.apple.CoreFoundation      0x09403faf __CFRunLoopRun + 2079
            3   com.apple.CoreFoundation      0x09403094 CFRunLoopRunSpecific + 452
            4   com.apple.CoreFoundation      0x09402ec1 CFRunLoopRunInMode + 97
            5   com.apple.HIToolbox           0x0a95bf9c RunCurrentEventLoopInMode + 392
            6   com.apple.HIToolbox           0x0aae1faf RunCurrentEventLoop + 65
            7   com.macromedia.fireworks      0x00887134 0x1000 + 8937780
            8   com.macromedia.fireworks      0x0095f2f4 0x1000 + 9822964
            9   ...ple.CoreServices.CarbonCore 0x0c455dee PrivateMPEntryPoint + 68
            10  libSystem.B.dylib             0x0910d81d _pthread_start + 345
            11  libSystem.B.dylib             0x0910d6a2 thread_start + 34
            Thread 18:
            2   com.macromedia.fireworks      0x00ba9297 0x1000 + 12223127
            3   com.macromedia.fireworks      0x00ba936b 0x1000 + 12223339
            4   libSystem.B.dylib             0x0910d81d _pthread_start + 345
            5   libSystem.B.dylib             0x0910d6a2 thread_start + 34
            Thread 19:
            0   libSystem.B.dylib             0x090ff086 select$DARWIN_EXTSN + 10
            1   com.apple.CoreFoundation      0x0944380d __CFSocketManager + 1085
            2   libSystem.B.dylib             0x0910d81d _pthread_start + 345
            3   libSystem.B.dylib             0x0910d6a2 thread_start + 34
            Thread 20:
            2   libSystem.B.dylib             0x09139ba2 usleep$UNIX2003 + 61
            3   com.apple.AppKit              0x097eb1a1 -[NSUIHeartBeat _heartBeatThread:] + 2039
            4   com.apple.Foundation          0x089ab8d4 -[NSThread main] + 45
            5   com.apple.Foundation          0x089ab884 __NSThread__main__ + 1499
            Thread 21 Crashed:
            0   libSystem.B.dylib             0x0914d28e __semwait_signal_nocancel + 10
            1   libSystem.B.dylib             0x0914d172 nanosleep$NOCANCEL$UNIX2003 + 166
            2   libSystem.B.dylib             0x091c803a usleep$NOCANCEL$UNIX2003 + 61
            3   libSystem.B.dylib             0x091e9685 __abort + 136
            4   libSystem.B.dylib             0x091e96f5 abort_report_np + 0
            5   libSystem.B.dylib             0x091ba729 internal_catch_exception_raise + 114
            6   libSystem.B.dylib             0x091a3b0d _Xexception_raise + 222
            7   libSystem.B.dylib             0x091a3640 exc_server + 125
            8   com.macromedia.fireworks      0x00ba91a4 0x1000 + 12222884
            9   com.macromedia.fireworks      0x00ba9213 0x1000 + 12222995
            Thread 21 crashed with X86 Thread State (32-bit):
              eax: 0x0000003c  ebx: 0x0914d0d9  ecx: 0xb052dd7c  edx: 0x0914d28e
              edi: 0x32007844  esi: 0xb052ddd8  ebp: 0xb052ddb8  esp: 0xb052dd7c
               ss: 0x0000001f  efl: 0x00000247  eip: 0x0914d28e   cs: 0x00000007
               ds: 0x0000001f   es: 0x0000001f   fs: 0x0000001f   gs: 0x00000037
              cr2: 0xbf7feb00
            Binary Images:
                0x1000 -  0x1448ff1 +com.macromedia.fireworks Adobe Fireworks CS5 version 11.0.0.484 (11.0.0) <38213EBD-FDB0-FC20-40E8-87935A5386BB> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/Adobe Fireworks CS5
            0x1e81000 -  0x1ed4ffb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <4F2BFF03-01D2-A07D-E5E2-7F88D4C2DEC4> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
            0x1f1c000 -  0x1f82ffb +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <DD471011-9120-1BC2-F1B5-D6FF09D0859F> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
            0x1fb2000 -  0x1fb2ff7  com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
            0x1fb5000 -  0x22aefef  com.apple.QuickTime 7.6.6 (1742) <89720F2A-F33B-FF09-3D81-F9F25A99F3EB> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
            0x235a000 -  0x235aff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
            0x235d000 -  0x24fcfe7 +com.adobe.owl AdobeOwl version 3.0.81 (3.0.81) <9C261D9E-9BD7-5DE6-5676-AEEF4828D17B> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
            0x2565000 -  0x269dfe7 +WRServices ??? (???) <52CE5B97-1E6A-92A2-EA70-93511AB7EA2E> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
            0x26e3000 -  0x2750fef +FileInfo ??? (???) <4A4C74F9-CA83-B174-F56D-F7671DC61389> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
            0x276b000 -  0x2791ff6 +AdobeAXE8SharedExpat ??? (???) <5848BBCE-3A3E-66EE-5527-97A96F0CA4CC> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
            0x27a2000 -  0x27bdfff +AdobeBIB ??? (???) <3B3092DC-A296-9D1C-1922-D20E6A5A7D7E> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
            0x27c7000 -  0x281fff7 +AdobeXMP ??? (???) <73329999-C364-2451-6574-4D0277057D19> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
            0x282e000 -  0x2e5cfe7 +AdobeAGM ??? (???) <91D37E54-E985-47E1-2696-0BD7E4183132> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
            0x2fba000 -  0x30cefff +AdobeACE ??? (???) <DD291A17-ECF4-FE20-5837-AC1F5BC76940> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
            0x30f1000 -  0x33e3ff7 +AdobeCoolType ??? (???) <9FDD596D-9824-2BB9-5DA2-25DACAB6A324> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
            0x346b000 -  0x348cff7 +AdobeBIBUtils ??? (???) <E1FAA7A3-E807-DE5A-1F68-7A53780E8202> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
            0x3498000 -  0x34d4fff +AdobeARE ??? (???) <76851E91-2381-5D05-742C-BB24E4BAD276> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
            0x34dd000 -  0x38b5ff7 +AdobeMPS ??? (???) <13614867-4D80-EB74-FA7F-6136492478BA> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
            0x39e4000 -  0x4018feb +AdobePDFL ??? (???) <49D6D58A-1EBB-424A-4CB0-8F9691E0991D> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
            0x4144000 -  0x4e87fff +com.adobe.psl AdobePSL 12.0.0.7524 (12.0.0.7524) <CFBCB19A-03F7-D095-1F48-8D68F05A25C5> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
            0x51c6000 -  0x5250ff7 +com.adobe.AdobeScCore ScCore 4.1.7 (4.1.7.5522) <053A109E-3E3E-D3EE-7186-4920D927D2AD> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
            0x5293000 -  0x5376fef +AdobePDFPort ??? (???) <A2E6DCF7-283F-09E9-53AE-D5D84D020469> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
            0x53ab000 -  0x53aeff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <FFDDAB7A-220F-7344-F12B-010CA0C41DAB> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
            0x53b4000 -  0x5445ff7 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <581475CC-C039-1B42-49BA-71811D8B4E15> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
            0x5464000 -  0x5e14fff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <02108DEA-3DD2-14BE-DAEB-BE522B619C1D> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
            0x5e17000 -  0x5ee4ff3 +libicui18n.dylib.36.0 36.0.0 (compatibility 36.0.0) <08F15219-7F35-574E-7725-1ACAA1B18A00> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ICUInternationalization.framework/Versions/3.6/libicui18n.dyl ib.36.0
            0x5f47000 -  0x6021fef +libicuuc.dylib.36.0 36.0.0 (compatibility 36.0.0) <5EE72009-40B3-7FB7-3A49-576AEDE0D400> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6/libicuuc.dylib.36.0
            0x6061000 -  0x6decfe7 +com.adobe.illustrator 382 (15.0.0) <64F68532-0311-6BBA-1F50-246CAF917549> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
            0x7bd1000 -  0x7c15fff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <69EDC44E-D7BB-A259-282D-C42725AE0E26> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPort
            0x7c78000 -  0x7cbefff +FilterPort ??? (???) <23FAE9D1-9376-1E71-21F7-D3EB2BFD50EE> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/FilterPort.framework/Versions/A/FilterPort
            0x7d33000 -  0x7d33fff +SPBasic ??? (???) <5D1760D8-C910-C641-0BC9-CF74A1A5190D> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
            0x7d37000 -  0x7f1dff7 +com.adobe.linguistic.LinguisticManager 5.0.0 (11309) <CA1D50A3-F965-F8B2-76B9-007F290C5791> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
            0x7fab000 -  0x8078fe7 +AdobeAXEDOMCore ??? (???) <F76D74DC-FD5A-9783-C447-2E58773DA7E1> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
            0x80e7000 -  0x825fffb +com.adobe.PlugPlug 2.0.0.746 (2.0.0.746) <08AD22E3-34C0-6749-E497-616C66A246AD> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
            0x8303000 -  0x8320fef +libCurl.dylib ??? (???) <1BA6E2DE-EF14-D50A-4697-035AE07875D7> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/libCurl.dylib
            0x8328000 -  0x833eff4 +libChar16.dylib ??? (???) <19B0479C-72B1-EE14-6385-7F655DEC0F02> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/libChar16.dylib
            0x8346000 -  0x8369fe0 +libCoreTypes.dylib ??? (???) <F5306147-FFBD-2826-D356-B26258DBFA09> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/libCoreTypes.dylib
            0x8379000 -  0x8380ffc  com.apple.carbonframeworktemplate 1.0 (1.0) <0D270CC7-B715-943E-2B4F-5C9B5775505A> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/NetIO.framework/Versions/A/NetIO
            0x838c000 -  0x838ffff +Dioxide.dylib ??? (???) <BCE94F23-4CCA-20FB-79A8-DE7925879DCD> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/Dioxide.dylib
            0x8397000 -  0x839dffc +libfwutility.dylib ??? (???) <6A723D9E-A60B-56EE-2B8D-B91991793749> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/libfwutility.dylib
            0x83a4000 -  0x83f4fff +com.macromedia.javascript Javascript version 1.0 (1.0) <540CB029-3946-8E41-BD91-AED6F73C86B7> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/Javascript.framework/Versions/A/Javascript
            0x8409000 -  0x8416fff +com.macromedia.moa Moa version 1.0 (1.0) <3C4B7F42-5A5D-78E7-B1DC-DAA06A99CCB2> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/Moa.framework/Versions/A/Moa
            0x841f000 -  0x8426fff +com.macromedia.morefiles MoreFiles version 1.0 (1.0) <36115C66-79A3-5DB9-B36B-8D655B46FC76> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/MoreFiles.framework/Versions/A/MoreFiles
            0x842d000 -  0x8511fe3 +libPowerPlant2.dylib ??? (???) <964FB3D7-B7EE-94EB-FD95-4AE90C657A4A> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/libPowerPlant2.dylib
            0x8644000 -  0x864affb +com.macromedia.testframework 1.0 (1.0) <ED14FA00-1C6F-D433-1EEB-833BB4402B2B> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/uwchar.framework/Versions/A/uwchar
            0x864e000 -  0x864eff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
            0x8656000 -  0x88bafef  com.apple.security 6.1.1 (37594) <3F68A006-6B30-85D5-1A75-8D748F72A6D5> /System/Library/Frameworks/Security.framework/Versions/A/Security
            0x8995000 -  0x8c05ffb  com.apple.Foundation 6.6.3 (751.29) <E77D3906-99F4-FEF4-FBB0-86FB3C94073E> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
            0x8d14000 -  0x8d6fff7  com.apple.framework.IOKit 2.0 (???) <A013B850-6ECB-594A-CBD6-DB156B11871B> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
            0x8d8e000 -  0x8d92ffc +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <E6437929-0E69-8A56-E69F-F64305E82DD9> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
            0x8d99000 -  0x8db1fef +libgiff.dylib ??? (???) <8F90552B-3D11-2B1E-D1BA-A109FEB99969> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/libgiff.dylib
            0x8db9000 -  0x8dd7fe7 +com.macromedia.png LibPNG version 1.0 (1.0) <2DBA0A3F-4F01-7474-0FED-3021382D635F> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/LibPNG.framework/Versions/A/LibPNG
            0x8ddf000 -  0x8dedfeb +com.macromedia.zlib ZLib version 1.0 (1.0) <EEA4CFAF-A748-FA72-91F0-ADE7A1BE9FA7> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ZLib.framework/Versions/A/ZLib
            0x8df2000 -  0x8df2ff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
            0x8df5000 -  0x8df5ff7  com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
            0x8dfd000 -  0x8e01ffd +com.yourcompany.yourcocoaframework ??? (1.0) <7EF7A82E-0AAE-0022-3B15-7C50F1C550C1> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ASEFramework.framework/Versions/A/ASEFramework
            0x8e06000 -  0x8f07fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
            0x8f2b000 -  0x8f32ff2 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.0) <F966C78A-3CC1-8678-B3B7-B0A2B118343A> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
            0x8f42000 -  0x8f48fef +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.0) <8837A972-1EBE-CAA9-473A-CD157F17163D> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
            0x8f59000 -  0x8fd6fff +AdobeOwlCanvas ??? (???) <65B2E680-4F43-BE46-2290-3500758D1BF7> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/AdobeOwlCanvas
            0x8ff2000 -  0x8ffdff3 +com.adobe.boost_filesystem.framework boost_filesystem version 5.0.0 (5.0.0.0) <90B8B4E3-6C44-D110-1545-1A34EB14B22D> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
            0x9011000 -  0x9013ffb +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.0) <0C4D56E8-9593-4C4A-4A7E-BEAEDE1CA131> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
            0x901a000 -  0x9084fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
            0x90df000 -  0x9285feb  libSystem.B.dylib 125.2.0 (compatibility 1.0.0) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib
            0x9306000 -  0x93b3fe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
            0x93c7000 -  0x9541fe3  com.apple.CoreFoundation 6.6.3 (550.29) <00373783-3744-F47D-2191-BEEA658F0C3D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
            0x9639000 -  0x9f19ff7  com.apple.AppKit 6.6.6 (1038.29) <6F28C335-6DC2-AE0E-B79A-F256DBD0BB45> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
            0xa3b2000 -  0xa467fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
            0xa4ad000 -  0xa4b4ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <6877F0D8-0DCF-CB98-5304-913667FF50FA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
            0xa4bb000 -  0xa4c9ff7  com.apple.opengl 1.6.9 (1.6.9) <4F06C166-00CF-5ACF-77E3-5A960A5E8AD3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
            0xa4d1000 -  0xa4d4fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
            0xa4d7000 -  0xa605fe7  com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
            0xa669000 -  0xa795fff  com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <F0D7256E-0914-8E77-E37B-9720430422AB> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
            0xa7fb000 -  0xa7fcff7  com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <959DFFAE-A06B-7FF6-B713-B2076893EBBD> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
            0xa801000 -  0xa8dcfe7  com.apple.DesktopServices 1.5.7 (1.5.7) <A69072AD-C47E-A00D-4A69-6E46A7FB2119> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
            0xa927000 -  0xac4bfef  com.apple.HIToolbox 1.6.3 (???) <0A5F56E2-9AF3-728D-70AE-429522AEAD8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
            0xad8b000 -  0xb0f3ff7  com.apple.QuartzCore 1.6.2 (227.22) <4288F0D2-0C87-F054-C372-8764B44DE024> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
            0xb1c2000 -  0xb1ccffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
            0xb1d5000 -  0xb21bff7  libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
            0xb228000 -  0xb3aafe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <2314BD12-0821-75BB-F3BC-98D324CFD30A> /usr/lib/libicucore.A.dylib
            0xb40c000 -  0xb41afe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
            0xb41f000 -  0xb463ff3  com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
            0xb482000 -  0xb4fdfe7  com.apple.audio.CoreAudio 3.2.2 (3.2.2) <51D0E2DC-B15F-AF6C-70D8-026DDAD4E2A5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
            0xb52f000 -  0xb538ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
            0xb542000 -  0xb542ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
            0xb546000 -  0xb558ff7  com.apple.MultitouchSupport.framework 205.34 (205.34) <813475E3-B323-9405-F758-DDA1F5D63B20> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
            0xb565000 -  0xbd54557  com.apple.CoreGraphics 1.545.0 (???) <DCED8E1A-7504-C31A-B6EF-98BFF1A61060> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
            0xbe1c000 -  0xbfd6fe3  com.apple.ImageIO.framework 3.0.3 (3.0.3) <A93A514B-C1BF-21D0-FB03-CB775DE4FFAA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
            0xc030000 -  0xc091fe7  com.apple.CoreText 3.1.0 (???) <1372DABE-F183-DD03-03C2-64B2464A4FD5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
            0xc0c9000 -  0xc164ff7  com.apple.ApplicationServices.ATS 275.11.1 (???) <5FF65EC7-F512-530A-7771-3DE240EE6E43> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
            0xc18b000 -  0xc23bff3  com.apple.ColorSync 4.6.3 (4.6.3) <AA1076EA-7665-3005-A837-B661260DBE54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
            0xc272000 -  0xc2c3ff7  com.apple.HIServices 1.8.0 (???) <10C85B88-C6AF-91DB-2546-34661BA35AC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
            0xc2ed000 -  0xc2feff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
            0xc30b000 -  0xc3b3ffb  com.apple.QD 3.35 (???) <B80B64BC-958B-DA9E-50F9-D7E8333CC5A2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
            0xc3e0000 -  0xc3f4ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
            0xc402000 -  0xc416fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
            0xc41f000 -  0xc42bff7  libkxld.dylib ??? (???) <322A4B52-8305-3081-6B74-813C3A87A56D> /usr/lib/system/libkxld.dylib
            0xc42f000 -  0xc74ffeb  com.apple.CoreServices.CarbonCore 861.13 (861.13) <52803668-3669-36BD-57DD-078FBA835081> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
            0xc7c3000 -  0xc86cff7  com.apple.CFNetwork 454.9.8 (454.9.8) <DB2A5C33-E833-1B3A-4DE0-5FF172B2048B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
            0xc8d0000 -  0xc914fe7  com.apple.Metadata 10.6.3 (507.10) <630494FA-3BB3-EDD3-E10B-8DAAF4831E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
            0xc93b000 -  0xca05fef  com.apple.CoreServices.OSServices 357 (357) <CF9530AD-F581-B831-09B6-16D9F9283BFA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
            0xca64000 -  0xcae4feb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
            0xcb18000 -  0xcb4bff7  com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
            0xcb63000 -  0xcc00fe3  com.apple.LaunchServices 362.1 (362.1) <885D8567-9E40-0105-20BC-42C7FF657583> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
            0xcc3f000 -  0xcc65fff  com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
            0xcc7c000 -  0xcc89ff7  com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
            0xcc92000 -  0xcd4bfe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
            0xcd59000 -  0xcd96ff7  com.apple.SystemConfiguration 1.10.2 (1.10.2) <398BB007-41FD-1A30-26D8-CB86ED5E467E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
            0xcdb3000 -  0xcddbff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
            0xcde6000 -  0xce2ffe7  libTIFF.dylib ??? (???) <9CFF48CC-4852-4D06-17AC-3C947C824159> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
            0xce3a000 -  0xce3eff7  libGIF.dylib ??? (???) <3ECD4D2C-40FE-E9A0-A2D2-E36D1C00D3A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
            0xce43000 -  0xce5eff7  libPng.dylib ??? (???) <36A3D75E-5178-4358-7F02-444E276D61AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
            0xce65000 -  0xce67ff7  libRadiance.dylib ??? (???) <AB06F616-E3EA-5966-029A-8AA44BBE5B28> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
            0xce6b000 -  0xce8fff7  libJPEG.dylib ??? (???) <5CE96981-6B2A-D15B-4A17-E7BD329095B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
            0xce96000 -  0xcf73ff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
            0xcf81000 -  0xcf81ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
            0xcf84000 -  0xcfc6ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
            0xcfcf000 -  0xd03eff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
            0xd047000 -  0xd45dff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
            0xd49f000 -  0xd8d4ff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
            0xda5a000 -  0xdb4cff7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <D2C86308-F998-C83D-F49B-CD484D4EFE6A> /usr/lib/libcrypto.0.9.8.dylib
            0xdb9e000 -  0xdb9fff7  com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
            0xdba3000 -  0xdc59ffb  libFontParser.dylib ??? (???) <067DC1A2-764B-41EA-B07E-4205472749B7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
            0xdce9000 -  0xdd21ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <76C02F5C-98FD-BD64-B5FB-C698FB76EA25> /usr/lib/libcups.2.dylib
            0xdd2e000 -  0xdd4efe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
            0xdd58000 -  0xdd58ff7  com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
            0xdd5b000 -  0xdd65fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
            0xdd6d000 -  0xddbdff7  com.apple.framework.familycontrols 2.0.1 (2010) <B9762E20-543D-13B9-F6BF-E8585F04CA01> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
            0xddd4000 -  0xde82ff3  com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
            0xdeac000 -  0xdecaff7  com.apple.CoreVideo 1.6.1 (45.4) <E0DF044D-BF31-42CE-B690-FD1FCE07E64A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
            0xdee1000 -  0xdf12ff7  libGLImage.dylib ??? (???) <9340012D-595A-6243-9C97-7D30D76D9D9E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
            0xdf1a000 -  0xdf3bfe7  com.apple.opencl 12.1 (12.1) <DA2AC3FA-ED11-2D10-21E9-7BDF4778B228> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
            0xdf44000 -  0xdf48ff7  IOSurface ??? (???) <66E11D8E-CF4B-EFD0-37F9-20177C647021> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
            0xdf50000 -  0xdf93ff7  libGLU.dylib ??? (???) <2093A1FB-67BD-39E0-CDE5-A97A77BDDBCE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
            0xdfa1000 -  0xdfacff7  libGL.dylib ??? (???) <B87E0676-F5EF-8DA3-6DEE-13C43B3832A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
            0xdfbb000 -  0xe0c7ff7  libGLProgrammability.dylib ??? (???) <1B315838-F477-5416-7504-67EC3433AD4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
            0xe0e6000 -  0xe0e9ff7  libCoreVMClient.dylib ??? (???) <CA0BA8DC-0159-A808-A300-750358A6970C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
            0xe0ee000 -  0xe0f2ff7  libGFXShared.dylib ??? (???) <2D32BDBF-C941-93FD-E233-F03D28DB9E94> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
            0xe0f7000 -  0xe179ffb  SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
            0xe1b0000 -  0xe1b5ff7  com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
            0xe1bd000 -  0xe1d5ff7  com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
            0xe1e6000 -  0xe233feb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
            0xe24f000 -  0xe271fef  com.apple.DirectoryService.Framework 3.6 (621.3) <05FFDBDB-F16B-8AC0-DB42-986965FCBD95> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
            0xe27b000 -  0xe28bff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
            0xe292000 -  0xe298fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
            0xe2a0000 -  0xe2a3ffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
            0xe2a8000 -  0xe30cffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
            0xe32e000 -  0xe343fff  com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
            0xe359000 -  0xe39cff7  com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
            0xe3c5000 -  0xe3e1fe3  com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
            0xe3f1000 -  0xe3f3ff7  com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
            0xe3f8000 -  0xe436ff7  com.apple.QuickLookFramework 2.2 (327.4) <88A59C42-A200-FCB6-23EC-E848D0E14963> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
            0xe459000 -  0xe54dff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <9EC28185-D26F-533F-90C4-FBAA13A15947> /usr/lib/libiconv.2.dylib
            0xe55b000 -  0xe60bff7 +libCrypto.dylib ??? (???) <7743860E-1E20-BC36-8443-53A4DC91A879> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/libCrypto.dylib
            0xe657000 -  0xe678ffc +libSSL.dylib ??? (???) <202C3E7F-DBBB-4AF1-FFA7-7DDD19A17938> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/libSSL.dylib
            0xe685000 -  0xe6c5ff7  com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
            0xf07b000 -  0xf07cff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
            0xf0b1000 -  0xf0b2ff7  ATSHI.dylib ??? (???) <A7A8E224-2579-BD3B-7281-86342D077252> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
            0xf713000 -  0xf71eff7  libCSync.A.dylib 543.50.0 (compatibility 64.0.0) <4FA0CE4A-BDE5-0E3D-37F0-03B41F0C2637> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
            0xf72a000 -  0xf736ff7 +com.rogueamoeba.audio_hijack_server.hermes 2.2.7 (2.2.7) <6FE15386-2335-501B-618E-BAF958F386BE> /usr/local/hermes/modules/Instant Hijack Server.hermesmodule/Contents/MacOS/Instant Hijack Server
            0xf743000 -  0xf7aafea +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <EE468E2C-A6BD-E2EE-7ABE-69168B143B44> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
            0x13e9c000 - 0x13f0cfeb +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <50675115-BEDC-72F9-C42D-374196E83EC2> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
            0x13f1a000 - 0x13f22fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
            0x14183000 - 0x14195fff +com.adobe.pip ??? (5.0.0.2021) <5251926B-C2C0-282C-B3A9-94A9FEF0FCB8> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
            0x1419e000 - 0x14315fe7  GLEngine ??? (???) <0FC1F7CA-5C84-A7F6-105B-169383B50A94> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
            0x14347000 - 0x1474cfe7  libclh.dylib 3.1.1 C  (3.1.1) <4A445142-1AD3-2F3C-FF95-E835B49B33DE> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
            0x14818000 - 0x1483bfe7  GLRendererFloat ??? (???) <D71788AA-645A-02CF-201F-E44F073F98D7> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
            0x14873000 - 0x14c21fe3  com.apple.RawCamera.bundle 3.3.0 (533) <05A38D21-8556-434C-8BAA-850A6EC99B37> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
            0x14d1f000 - 0x14d60ff7  libRIP.A.dylib 543.50.0 (compatibility 64.0.0) <8BAE1FC1-A478-F151-17C7-2D5DE470AC4F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
            0x14d6f000 - 0x14daafeb  libFontRegistry.dylib ??? (???) <A102F61F-25D5-001A-20C3-56304C585072> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistry.dylib
            0x154ad000 - 0x154b0ff7  libCGXType.A.dylib 543.50.0 (compatibility 64.0.0) <3B49AED9-0DBA-9D21-F9AC-8784363AD762> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
            0x15665000 - 0x15696ff3  libTrueTypeScaler.dylib ??? (???) <7601D717-236D-8F4E-91F5-E69BB2920478> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libTrueTypeScaler.dylib
            0x15a20000 - 0x15a49feb +com.adobe.ape adbeapecore version 3.1.70.10055 (3.1.70.10055) <F3239526-C171-AD3C-835E-FC9998EEFB28> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
            0x15a59000 - 0x15a92ffb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <C64CCBDC-B8E9-45E8-53E7-8577CFE9F2F0> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
            0x15b5c000 - 0x15b62ff7  libCGXCoreImage.A.dylib 543.50.0 (compatibility 64.0.0) <94F66BA6-A4E8-63A4-1B70-EFAA4C75D668> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
            0x15ca9000 - 0x15cbbff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <026B8702-B0A6-1D90-BBD6-AAAD2E14810D> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
            0x15ce9000 - 0x15ce9ff7  com.apple.quartzframework 1.5 (1.5) <CEB78F00-C5B2-3B3F-BF70-DD6D578719C0> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
            0x15d06000 - 0x15d14fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <8F5FA7F7-840D-C5EF-C6E6-E2AF7CE43CD2> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
            0x15d72000 - 0x15d77ff7  libFontStreams.A.dylib 543.50.0 (compatibility 64.0.0) <9D14A07D-1EA2-77D6-C0ED-DB73107750E2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
            0x16028000 - 0x16029ff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
            0x162a6000 - 0x162acff7  com.apple.qldisplay.NSImage 2.2 (327.4) <A505AEB1-C67D-900D-E4E4-8ED411BC3DFB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/Resources/DisplayBundles/NSImage.qldisplay/Contents/MacOS/NSImage
            0x17c22000 - 0x17c2afff  com.apple.carbonbundletemplate 1.0 (1.0) <CF59539F-6DC9-3B0B-FBD4-509DA74AEBE3> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/JSExtensions/AIRext.bundle/Contents/MacOS/AIRext
            0x17c77000 - 0x17c9dff2  com.apple.carbonbundletemplate 3.0.2,4677 (3.0.2) <7FA5A69A-976D-A44A-5679-F4E00912304B> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/JSExtensions/MMNotes.bundle/Contents/MacOS/MMNotes
            0x17cc1000 - 0x17cc9fff +com.macromedia.bmpimportexport 1.0 (1.0) <A2D04F1D-3150-8E7A-6C3D-EB48C582C261> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/BMP Import Export.bundle/Contents/MacOS/BMP Import Export
            0x17cd0000 - 0x17ceeff7 +com.macromedia.mix_services MIX Services version 1.0 (1.0) <A2E68C22-D23E-165E-0A57-E6BA9B9D5B2D> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/Mix Services.bundle/Contents/MacOS/MIX Services
            0x17d01000 - 0x17d06ffb +com.macromedia.pict PICT Import Export version 1.0 (1.0) <5B7C5D2E-E7E5-9486-FC7D-8757F26AC4AA> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/PICT Import Export.bundle/Contents/MacOS/PICT Import Export
            0x17d0d000 - 0x17d11fff +com.macromedia.targa Targa Import version 1.0 (1.0) <FB1FC0D2-B47B-A054-C026-66A5E8BB31DD> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/Targa Import.bundle/Contents/MacOS/Targa Import
            0x17d17000 - 0x17d59fef +com.macromedia.tiff TIFF Import Export version 1.0 (1.0) <2ABEC8A4-B15C-1B8D-53B3-DFDDC8A0851B> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/Tiff Import Export.bundle/Contents/MacOS/Tiff Import Export
            0x17d66000 - 0x17d6bfeb +com.macromedia.twain TwainAgent version 1.0 (1.0) <FDFAD6E4-D5F4-A773-9A1B-5DAC9B464075> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/TwainAgent.bundle/Contents/MacOS/TwainAgent
            0x17d71000 - 0x17d77ff7  org.twain.dsm 1.9.4 (1.9.4) <1EF840DB-CB48-5207-7535-D82EBC0FCD5F> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
            0x17d7e000 - 0x17d81fff +com.macromedia.wbmp WBMP Import Export version 1.0 (1.0) <E3A57AC0-D6E8-7619-74AD-E7B1ADB99B94> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/WBMP Import Export.bundle/Contents/MacOS/WBMP Import Export
            0x183e0000 - 0x183e6ff7  com.apple.DisplayServicesFW 2.2.2 (251) <6E4020F6-4DD0-F137-F226-F396807E3C3B> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
            0x184ab000 - 0x184afff3  com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) <5570694E-039D-7970-6083-1C8A7B7C937B> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
            0x1892f000 - 0x18952fe7 +ServiceManager-Launcher.dylib ??? (???) <12CEC4C0-8682-A5FD-BAD4-A3E4A4F6218A> /Library/Application Support/Adobe/CS5ServiceManager/lib/ServiceManager-Launcher.dylib
            0x1895f000 - 0x1899fff3  com.apple.securityinterface 4.0.1 (37214) <BBC88C96-8827-91DC-0CF6-7CB639183395> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
            0x189c0000 - 0x189d0ff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
            0x18d00000 - 0x18d27ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
            0x18d45000 - 0x18d4bffb  com.apple.audio.AppleHDAHALPlugIn 1.8.7 (1.8.7f1) <0FE8B697-6D19-69C6-FA94-E18064ACFAEC> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
            0x197d4000 - 0x197deff7  com.apple.HelpData 2.0.4 (34) <9128FFEB-0F6C-B273-FCF4-D87A20227345> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
            0x1ab00000 - 0x1abd1fe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <8FDB4C40-D453-DA53-2A66-9A53998AB23C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
            0x1ac0f000 - 0x1adeaff3  libType1Scaler.dylib ??? (???) <6FBA8250-3271-6ED4-052D-E27C2136E38F> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libType1Scaler.dylib
            0x1b0c9000 - 0x1b411fe7 +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.0) <3D6B5526-68C6-AB1B-B98F-326F18EA44F0> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/dvaadameve.framework/dvaadameve
            0x1b909000 - 0x1ba85fe7 +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.0) <4BC4AD81-2341-CCA5-6972-F9C2B8C7B097> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
            0x1bbf9000 - 0x1bedffff +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.0) <3F61310E-8DF6-5E42-878E-E6A696BDD0AF> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
            0x1c1f5000 - 0x1d04ffeb +com.adobe.adobeswfl ??? (2.0.0.10053) <D591B8C9-2C4A-CF9E-0FCE-B80A844270E0> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/Ado beSWFL
            0x1d20e000 - 0x1d287ff7  com.apple.PDFKit 2.5.1 (2.5.1) <CEF13510-F08D-3177-7504-7F8853906DE6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
            0x1d2bd000 - 0x1d400fef  com.apple.QTKit 7.6.6 (1742) <98ECA8E3-73F0-D21B-8B7E-8FE651E29A7F> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
            0x1d4b6000 - 0x1d50efe7  com.apple.datadetectorscore 2.0 (80.7) <A40AA74A-9D13-2A6C-5440-B50905923251> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
            0x1d537000 - 0x1d591fe7  com.apple.CorePDF 1.3 (1.3) <696ADD5F-C038-A63B-4732-82E4109379D7> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
            0x1d5c0000 - 0x1d7ebff3  com.apple.QuartzComposer 4.1 (156.16) <578A1842-8B62-00BF-B2E8-4C0AA8E6A938> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
            0x1d8cc000 - 0x1daaefff  com.apple.imageKit 2.0.3 (1.0) <BF2ECA4D-FCD8-AD5D-E100-22370F2C7EE0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
            0x1db80000 - 0x1dbeeff7  com.apple.QuickLookUIFramework 2.2 (327.4) <5B6A066B-B867-D3A3-BDEE-3D68FA5385B4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
            0x1dc2a000 - 0x1dc5aff7  com.apple.MeshKit 1.1 (49.2) <ECFBD794-5D36-4405-6184-5568BFF29BF3> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
            0x1dc79000 - 0x1de70feb  com.apple.JavaScriptCore 6533.18 (6533.18.1) <EE3897A8-E1C0-DE28-A631-4B0C32DF737B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
            0x1deca000 - 0x1df20ff7  com.apple.MeshKitRuntime 1.1 (49.2) <F1EAE9EC-2DA3-BAFD-0A8C-6A3FFC96D728> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
            0x1df50000 - 0x1e052fef  com.apple.MeshKitIO 1.1 (49.2) <34322CDD-E67E-318A-F03A-A3DD05201046> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
            0x1e0b9000 - 0x1e0f6ff7  com.apple.CoreMedia 0.484.11 (484.11) <0346F9E5-AEFE-B751-7D85-88D156C01385> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
            0x1e111000 - 0x1e23dffb  com.apple.MediaToolbox 0.484.11 (484.11) <B93B175A-2039-2FD2-FBE4-22C9F8C9E223> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
            0x1e2a1000 - 0x1e75affb  com.apple.VideoToolbox 0.484.11 (484.11) <6AB58081-F7C4-46F9-2C05-CFED9E38F0A0> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
            0x1e802000 - 0x1e848ffb  com.apple.CoreMediaIOServices 130.0 (1035) <F5E6F93D-6844-9FD7-8769-44503DFD5363> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
            0x1e869000 - 0x1e8e1fef  com.apple.AppleVAFramework 4.9.20 (4.9.20) <D8B544CB-9E32-81C2-59BD-C5DDB66DA621> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
            0x1e8ea000 - 0x1e929ff7  com.apple.ImageCaptureCore 1.0.2 (1.0.2) <18E338B0-D82E-2ADC-FB9E-8909E765C41B> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
            0x1ee3a000 - 0x1f4cfffb +com.macromedia.Flash Player.authplaylib 10.0.0.508 (1.0.1d333) <02A2245F-4883-4AA8-B06C-47704216613B> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
            0x1f618000 - 0x1f641fe3  com.apple.audio.CoreAudioKit 1.6.1 (1.6.1) <7FFBD485-5251-776A-CC44-4470DD84112B> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
            0x20000000 - 0x20098fe7  edu.mit.Kerberos 6.5.10 (6.5.10) <8B83AFF3-C074-E47C-4BD0-4546EED0D1BC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
            0x3319e000 - 0x331c8ff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
            0x331e1000 - 0x33217fff  libtidy.A.dylib ??? (???) <DDFAB560-3883-A6A2-7BDD-D91730982B48> /usr/lib/libtidy.A.dylib
            0x3d000000 - 0x3d073fff  com.apple.iLifeMediaBrowser 2.1.5 (368) <30261504-7533-5424-DD15-32739DED6FB0> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowse r
            0x40000000 - 0x400d1fe7 +AdobeJP2K ??? (???) <2ABF10A7-540A-06C8-21FA-186263931DF9> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
            0x4ded2000 - 0x4e009ff7  com.apple.CoreAUC 6.04.01 (6.04.01) <B6E035A9-8DA2-82FC-9C2F-F57B9B62BE5F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
            0x4eac0000 - 0x4fa10fe3  com.apple.QuickTimeComponents.component 7.6.6 (1742) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponent s
            0x64b00000 - 0x64b07ff3  com.apple.print.framework.Print 6.1 (237.1) <97AB70B6-C653-212F-CFD3-E3816D0F5C22> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
            0x8f050000 - 0x8f711fef  com.apple.GeForceGLDriver 1.6.18 (6.1.8) <2E4BD283-8E9B-6AB7-2945-F92F5015DA02> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
            0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld
            0xb0000000 - 0xb000fff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <24B39C2F-79B0-BDE3-C6D0-1F0E943070C7> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
            0xba300000 - 0xba301fe7  libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <00220471-9241-ECB6-DE8C-072E8806198E> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
            0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <12C58901-CCF3-4E8E-30CA-92A10CD55DF1> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
            0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <7FFF4AFA-6522-C7D5-760F-A8F13D6EF032> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
            0xeab00000 - 0xeab10fe7  libConverter.dylib 169.1.0 (compatibility 1.0.0) <116CF161-A391-45BC-81B5-0954C87C8ABB> /System/Library/Printers/Libraries/libConverter.dylib
            0xfa100000 - 0xfa192fe3  com.apple.print.framework.PrintCore 6.2 (312.5) <7729B4D7-D661-D669-FA7E-510F93F685A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
            0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib
            Model: MacBookPro5,3, BootROM MBP53.00AC.B03, 2 processors, Intel Core 2 Duo, 2.8 GHz, 4 GB, SMC 1.48f2
            Graphics: NVIDIA GeForce 9600M GT, NVIDIA GeForce 9600M GT, PCIe, 512 MB
            Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
            Memory Module: global_name
            AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.91.27)
            Bluetooth: Version 2.3.7f1, 2 service, 19 devices, 1 incoming serial ports
            Network Service: AirPort, AirPort, en1
            Serial ATA Device: Hitachi HTS545050B9SA02, 465.76 GB
            Serial ATA Device: MATSHITADVD-R   UJ-868
            USB Device: My Book, 0x1058  (Western Digital Technologies, Inc.), 0x1100, 0x26200000
            USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0x26500000
            USB Device: Hub, 0x05ac  (Apple Inc.), 0x9122, 0x24100000
            USB Device: Keyboard Hub, 0x05ac  (Apple Inc.), 0x1006, 0x24130000
            USB Device: Microsoft® 2.4GHz Transceiver v4.0, 0x045e  (Microsoft Corporation), 0x0745, 0x24133000
            USB Device: Apple Keyboard, 0x05ac  (Apple Inc.), 0x0220, 0x24132000
            USB Device: Apple Cinema HD Display, 0x05ac  (Apple Inc.), 0x921e, 0x24120000
            USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8507, 0x24400000
            USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000
            USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8213, 0x06110000
            USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x0236, 0x04600000
            USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x04500000
            • 3. Re: Fireworks CS5 Crashes
              Sarthak Singhal Adobe Employee
              Hi Jeff,
              To investigate further on the crashes and its roots, we will need the file which is making the app unstable. We will also need to know the exact steps which is leading to crash. If you can see the crash again, can you record the screen capturing all the steps on video and sharing all these files with us?
              You can send me a link to all these files privately also(just send me a private message via this forum), if you are uncomfortable with sharing it here.
              ..Sarthak
              blogs.adobe.com/sarthak
              • 4. Re: Fireworks CS5 Crashes
                Jeff Cairns Level 1
                Hi Sarthak,
                Thanks for the response - I have sent you a "Private Message" with instructions on how to recreate the issue and a link to the subject file.
                Regards - Jeff
                • 5. Re: Fireworks CS5 Crashes
                  Jeff Cairns Level 1
                  To solve this issue - we ended up rebuilding the original file (many hours of work). The newly rebuilt file functioned flawlessly for a couple of days with numerous updates/adjustments and subsequent saves.
                  Unfortunately, the new version started crashing this afternoon during a save process and it too is no longer usable. We have incremental backups for each and every save (as well as hourly backups).
                  Pulling an old version of the file (3 hours old) and trying to open and save it - causes a crash - It now appears that NO version of this particular file opens and saves without crashing anymore. BUT, oddly, other FW documents do open and behave properly.
                  Based on this - we are inclined to believe there is a problem with FW itself, rather than a simply corrupted file. So ... we have performed the following:
                  • deleted the FW prefs. No joy. Crashes continue
                  • Reinstalled FW CS5 - yet again - No joy.
                  • 6. Re: Fireworks CS5 Crashes
                    Thanks Jeff for sharing the files. We have been able to reproduce the issue and will look into it.
                    ..Sarthak
                    • 7. Re: Fireworks CS5 Crashes
                      Jeff Cairns Level 1
                      Hi Sarthak,
                      Two other pieces of information that may or may not be helpful to your engineers when looking at this issue.
                      1.) The working copy of this file was kept on a Dropbox folder locally.. so it was constantly syncing with the Dropbox online backup service on each and every save. I doubt this is significant, but thought you should be aware.
                      2.) As I mentioned previously, we have a pretty rigorous incremental backup strategy in house, so we had several versions of backups of the file. (Both on Dropbox and via Time-Machine). When the file initially crashes, we try to recover from a backup - but each time, we discover that the backups exhibit the same crashing behaviour despite the fact that at the time they were archived, the file was behaving properly. (Very odd.)
                      Also - after Sunday's repeated file crash/corruption, we have rebuilt the file for a third time. To do this, we create a new blank document, then open the crash/corrupted file (latest copy) and methodically copy and paste each and every layer and sub-layer from the corrupt file to the new blank file. This results in a seemingly stable version of the file that (for now) does not crash on save. Needless, to say it's a time consuming task. This was the same strategy that kept us moving forward for the past couple of days on the file that has now become corrupted.
                      Let me know if you want us to send a copy of the rebuilt non-crashing file for comparison purposes.
                      Regards - Jeff
                      • 8. Re: Fireworks CS5 Crashes
                        Sure Jeff. It might help us to understand the issue.
                        ..Sarthak
                        • 9. Re: Fireworks CS5 Crashes
                          Jeff Cairns Level 1
                          Well - we've been able to run FW CS5 with no issues for the past couple of week s- BUT - once again today we have another file that started crashing and we are no longer able to work with it. The file has become corrupted in some manner - behaviour is the same as per previous - Crashes constantly on SAVE action.
                          I do hope there is a fix coming for this most aggravating issue.
                          • 10. Re: Fireworks CS5 Crashes
                            Andrew Odri
                            Hello,
                            I am experiencing similar issues, with very sporadic results.
                            PROBLEM:
                            Fireworks CS5 began crashing on launch consistently. I rmoved the *.plist files in hopes that this would remedy the situation, but it did not. I tried switching to a blank user account, and Fireworks would actually launch. However, whenever a file was opened, Fireworks would crash once again. All of this was about 2 weeks ago. Just now I tried once more, and now Firworks launches, but crashes whenever I open a file. Even if I try to open the "About Frieworks.." dialog, the application crashes.
                            ATTEMPTED SOLUTIONS:
                            Tried the solutions listed here: http://discussions.apple.com/thread.jspa?threadID=2153647
                            Tried removing all the preferences.
                            Tried launching Fireworks CS5 as a new user.
                            Reinstalled Fireworks from Master Collection installer.
                            Reinstalled from an isolated version of Fireworks CS5 downloaded from the adobe.com website as a trial.
                            I am in the same boat as Jeff now. I cannot use Fireworks anymore, and this is really affecting all aspects of how I work. I really need a solution, and based on Google searches for solutions, it seems that I am not the only. I'm sure there have been many crash reports on this... Can we please have access to a workaround or a fix? Thanks!
                            • 11. Re: Fireworks CS5 Crashes
                              Andrew Odri Level 1
                              Here is the crash report:
                              Process:         Adobe Fireworks CS5 [79874]
                              Path:            /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/Adobe Fireworks CS5
                              Identifier:      com.macromedia.fireworks
                              Version:         ??? (???)
                              Code Type:       X86 (Native)
                              Parent Process:  launchd [119]
                              Date/Time:       2011-02-21 16:47:47.244 -0800
                              OS Version:      Mac OS X 10.6.6 (10J567)
                              Report Version:  6
                              Interval Since Last Report:          1073351 sec
                              Crashes Since Last Report:           11
                              Per-App Interval Since Last Report:  548 sec
                              Per-App Crashes Since Last Report:   4
                              Anonymous UUID:                      E4128542-17D5-4DD3-9622-C8DDDE737936
                              Exception Type:  EXC_BAD_ACCESS (SIGBUS)
                              Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
                              Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                              Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
                              0   com.apple.CoreFoundation           0x982c0df0 CFNumberGetValue + 128
                              1   Adobe Fireworks CS5                0x00838b3d 0x1000 + 8616765
                              2   Adobe Fireworks CS5                0x0083b849 0x1000 + 8628297
                              3   Adobe Fireworks CS5                0x0083b902 0x1000 + 8628482
                              4   Adobe Fireworks CS5                0x0083aa80 0x1000 + 8624768
                              5   Adobe Fireworks CS5                0x0089d8d4 0x1000 + 9029844
                              6   Adobe Fireworks CS5                0x0088f804 0x1000 + 8972292
                              7   libPowerPlant2.dylib               0x08115156 FW_PowerPlant::LCarbonApp::ObeyCommand(long, void*) + 44
                              8   libPowerPlant2.dylib               0x080d4312 FW_PowerPlant::LDocApplication::ObeyCommand(long, void*) + 96
                              9   Adobe Fireworks CS5                0x0089af35 0x1000 + 9019189
                              10  libPowerPlant2.dylib               0x080d282b FW_PowerPlant::LCommander::ProcessCommand(long, void*) + 73
                              11  Adobe Fireworks CS5                0x008a1617 0x1000 + 9045527
                              12  Adobe Fireworks CS5                0x008a512c 0x1000 + 9060652
                              13  com.apple.HIToolbox                0x95f9eecf DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
                              14  com.apple.HIToolbox                0x95f9e196 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
                              15  com.apple.HIToolbox                0x95fc0a07 SendEventToEventTarget + 52
                              16  com.apple.HIToolbox                0x95fecfd3 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
                              17  com.apple.HIToolbox                0x96011cc0 SendMenuCommandWithContextAndModifiers + 66
                              18  com.apple.HIToolbox                0x96011c75 SendMenuItemSelectedEvent + 121
                              19  com.apple.HIToolbox                0x96011b80 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
                              20  com.apple.HIToolbox                0x95fe134a MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 454
                              21  com.apple.HIToolbox                0x96193997 MenuSelect + 190
                              22  com.apple.HIToolbox                0x9614c9f4 HIMenuBar::HandleMouseEvent(OpaqueEventRef*) + 92
                              23  com.apple.HIToolbox                0x95f9f4cb HIObject::EventHook(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 173
                              24  com.apple.HIToolbox                0x95f9eecf DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
                              25  com.apple.HIToolbox                0x95f9e196 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
                              26  com.apple.HIToolbox                0x95fc0a07 SendEventToEventTarget + 52
                              27  com.apple.HIToolbox                0x95fd25e3 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1417
                              28  com.apple.HIToolbox                0x95f9f320 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
                              29  com.apple.HIToolbox                0x95f9e196 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
                              30  com.apple.HIToolbox                0x95fc0a07 SendEventToEventTarget + 52
                              31  com.apple.HIToolbox                0x96149d2b ToolboxEventDispatcher + 86
                              32  com.apple.HIToolbox                0x96149e63 RunApplicationEventLoop + 243
                              33  Adobe Fireworks CS5                0x008a138c 0x1000 + 9044876
                              34  Adobe Fireworks CS5                0x00003596 0x1000 + 9622
                              Thread 1:  Dispatch queue: com.apple.libdispatch-manager
                              0   libSystem.B.dylib                  0x90f9a982 kevent + 10
                              1   libSystem.B.dylib                  0x90f9b09c _dispatch_mgr_invoke + 215
                              2   libSystem.B.dylib                  0x90f9a559 _dispatch_queue_invoke + 163
                              3   libSystem.B.dylib                  0x90f9a2fe _dispatch_worker_thread2 + 240
                              4   libSystem.B.dylib                  0x90f99d81 _pthread_wqthread + 390
                              5   libSystem.B.dylib                  0x90f99bc6 start_wqthread + 30
                              Thread 2:
                              0   libSystem.B.dylib                  0x90f7415a semaphore_timedwait_signal_trap + 10
                              1   libSystem.B.dylib                  0x90fa1ce5 _pthread_cond_wait + 1066
                              2   libSystem.B.dylib                  0x90fd0ac8 pthread_cond_timedwait_relative_np + 47
                              3   ...ple.CoreServices.CarbonCore     0x97f34ecd TSWaitOnConditionTimedRelative + 242
                              4   ...ple.CoreServices.CarbonCore     0x97f34c0b TSWaitOnSemaphoreCommon + 511
                              5   ...ple.CoreServices.CarbonCore     0x97f58e33 TimerThread + 97
                              6   libSystem.B.dylib                  0x90fa185d _pthread_start + 345
                              7   libSystem.B.dylib                  0x90fa16e2 thread_start + 34
                              Thread 3:
                              0   libSystem.B.dylib                  0x90f740fa mach_msg_trap + 10
                              1   libSystem.B.dylib                  0x90f74867 mach_msg + 68
                              2   ...ple.CoreServices.CarbonCore     0x97fde0d0 YieldToThread + 446
                              3   ...ple.CoreServices.CarbonCore     0x97fde1d3 SetThreadState + 134
                              4   ...ple.CoreServices.CarbonCore     0x97fde28e SetThreadStateEndCritical + 111
                              5   libPowerPlant2.dylib               0x08126b51 FW_PowerPlant::LThread::SemWait(FW_PowerPlant::LSemaphore*, long, QHdr&, unsigned char&) + 119
                              6   libPowerPlant2.dylib               0x08125b07 FW_PowerPlant::LSemaphore::BlockThread(long) + 61
                              7   libPowerPlant2.dylib               0x08125b6d FW_PowerPlant::LSemaphore::Wait(long) + 71
                              8   libPowerPlant2.dylib               0x08126f70 FW_PowerPlant::LThread::Cleanup::Run() + 32
                              9   libPowerPlant2.dylib               0x0812794e FW_PowerPlant::LThread::DoEntry(void*) + 30
                              10  ...ple.CoreServices.CarbonCore     0x97fde85f CooperativeThread + 309
                              11  libSystem.B.dylib                  0x90fa185d _pthread_start + 345
                              12  libSystem.B.dylib                  0x90fa16e2 thread_start + 34
                              Thread 4:
                              0   libSystem.B.dylib                  0x90f74142 semaphore_wait_signal_trap + 10
                              1   libSystem.B.dylib                  0x90fa1cfc _pthread_cond_wait + 1089
                              2   libSystem.B.dylib                  0x90fea46f pthread_cond_wait + 48
                              3   com.adobe.amt.services             0x1d9f5126 AMTConditionLock::LockWhenCondition(int) + 46
                              4   com.adobe.amt.services             0x1d9eddb0 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 116
                              5   com.adobe.amt.services             0x1d9f518c AMTThread::Worker(void*) + 24
                              Thread 5:
                              0   libSystem.B.dylib                  0x90fa20a6 __semwait_signal + 10
                              1   libSystem.B.dylib                  0x90fa1d62 _pthread_cond_wait + 1191
                              2   libSystem.B.dylib                  0x90fa39f8 pthread_cond_wait$UNIX2003 + 73
                              3   ...ple.CoreServices.CarbonCore     0x97f4951e TSWaitOnCondition + 126
                              4   ...ple.CoreServices.CarbonCore     0x97f34ea5 TSWaitOnConditionTimedRelative + 202
                              5   ...ple.CoreServices.CarbonCore     0x97f30873 MPWaitOnQueue + 250
                              6   Adobe Fireworks CS5                0x00ae43cf 0x1000 + 11416527
                              7   ...ple.CoreServices.CarbonCore     0x97f1485a PrivateMPEntryPoint + 68
                              8   libSystem.B.dylib                  0x90fa185d _pthread_start + 345
                              9   libSystem.B.dylib                  0x90fa16e2 thread_start + 34
                              Thread 6:
                              6   AdobeACE                           0x02c4a6f1 0x2c10000 + 239345
                              7   AdobeACE                           0x02c4a0ed 0x2c10000 + 237805
                              8   ...ple.CoreServices.CarbonCore     0x97f1485a PrivateMPEntryPoint + 68
                              9   libSystem.B.dylib                  0x90fa185d _pthread_start + 345
                              10  libSystem.B.dylib                  0x90fa16e2 thread_start + 34
                              Thread 7:
                              0   libSystem.B.dylib                  0x90fec70a accept$UNIX2003 + 10
                              1   Adobe Fireworks CS5                0x0098ff83 0x1000 + 10022787
                              2   Adobe Fireworks CS5                0x006e205b 0x1000 + 7213147
                              3   Adobe Fireworks CS5                0x0075dc40 0x1000 + 7720000
                              4   Adobe Fireworks CS5                0x0095f2f4 0x1000 + 9822964
                              5   ...ple.CoreServices.CarbonCore     0x97f1485a PrivateMPEntryPoint + 68
                              Thread 8:
                              0   libSystem.B.dylib                  0x90fb15fe recvfrom$UNIX2003 + 10
                              1   libSystem.B.dylib                  0x90fd13c7 recv$UNIX2003 + 54
                              2   ServiceManager-Launcher.dylib      0x2330a6cf Invoke + 54887
                              3   ServiceManager-Launcher.dylib      0x2330976e Invoke + 50950
                              4   ServiceManager-Launcher.dylib      0x2330861f Invoke + 46519
                              5   ServiceManager-Launcher.dylib      0x23308671 Invoke + 46601
                              6   ServiceManager-Launcher.dylib      0x233086fb Invoke + 46739
                              7   ServiceManager-Launcher.dylib      0x23302afe Invoke + 23190
                              8   ServiceManager-Launcher.dylib      0x23302ce7 Invoke + 23679
                              9   ServiceManager-Launcher.dylib      0x233038c7 Invoke + 26719
                              10  ServiceManager-Launcher.dylib      0x233039c5 Invoke + 26973
                              11  ServiceManager-Launcher.dylib      0x23306db0 Invoke + 40264
                              12  ServiceManager-Launcher.dylib      0x23307059 Invoke + 40945
                              13  ServiceManager-Launcher.dylib      0x23307687 Invoke + 42527
                              14  ServiceManager-Launcher.dylib      0x23307884 Invoke + 43036
                              15  ServiceManager-Launcher.dylib      0x232f9826 Login + 1654
                              16  ServiceManager-Launcher.dylib      0x232fac71 Login + 6849
                              17  ServiceManager-Launcher.dylib      0x23307df3 Invoke + 44427
                              18  ServiceManager-Launcher.dylib      0x2330a341 Invoke + 53977
                              19  libSystem.B.dylib                  0x90fa185d _pthread_start + 345
                              20  libSystem.B.dylib                  0x90fa16e2 thread_start + 34
                              Thread 9:
                              3   com.adobe.adobeswfl                0x24fa2d5f APXGetHostAPI + 2567887
                              4   com.adobe.adobeswfl                0x24d441ef APXGetHostAPI + 82783
                              5   com.adobe.adobeswfl                0x24fa2e4c APXGetHostAPI + 2568124
                              6   com.adobe.adobeswfl                0x24fa2eb7 APXGetHostAPI + 2568231
                              7   com.adobe.adobeswfl                0x24fa2f9b APXGetHostAPI + 2568459
                              Thread 10:
                              Thread 11:
                              3   com.adobe.adobeswfl                0x24fa2d27 APXGetHostAPI + 2567831
                              4   com.adobe.adobeswfl                0x2511806b APXGetHostAPI + 4096475
                              Thread 12:
                              4   com.adobe.adobeswfl                0x24fbd6de APXGetHostAPI + 2676814
                              Thread 13:
                              2   ...ia.Flash Player.authplaylib     0x27cae942 ExternalPlayer_Initialize + 1873594
                              3   libSystem.B.dylib                  0x90fa185d _pthread_start + 345
                              4   libSystem.B.dylib                  0x90fa16e2 thread_start + 34
                              Thread 14:
                              3   ...ia.Flash Player.authplaylib     0x27ad915c 0x27800000 + 2986332
                              4   ...ia.Flash Player.authplaylib     0x27afaa15 ExternalPlayer_Initialize + 87949
                              5   ...ia.Flash Player.authplaylib     0x27ad955a 0x27800000 + 2987354
                              Thread 15:
                              Thread 16:
                              1   libSystem.B.dylib                  0x90fcdee5 nanosleep$UNIX2003 + 188
                              2   Adobe Fireworks CS5                0x010a46b1 int (*functionptr_cast<int (*)(unsigned long long, cssm_data*)>(void*))(unsigned long long, cssm_data*) + 109105
                              3   Adobe Fireworks CS5                0x0109d313 int (*functionptr_cast<int (*)(unsigned long long, cssm_data*)>(void*))(unsigned long long, cssm_data*) + 79507
                              4   Adobe Fireworks CS5                0x010a47de int (*functionptr_cast<int (*)(unsigned long long, cssm_data*)>(void*))(unsigned long long, cssm_data*) + 109406
                              5   libSystem.B.dylib                  0x90fa185d _pthread_start + 345
                              6   libSystem.B.dylib                  0x90fa16e2 thread_start + 34
                              Thread 17:
                              2   com.apple.CoreFoundation           0x982d737f __CFRunLoopRun + 2079
                              3   com.apple.CoreFoundation           0x982d6464 CFRunLoopRunSpecific + 452
                              4   com.apple.CoreFoundation           0x982d6291 CFRunLoopRunInMode + 97
                              5   com.apple.HIToolbox                0x95fcc004 RunCurrentEventLoopInMode + 392
                              6   com.apple.HIToolbox                0x96152017 RunCurrentEventLoop + 65
                              7   Adobe Fireworks CS5                0x00887134 0x1000 + 8937780
                              8   Adobe Fireworks CS5                0x0095f2f4 0x1000 + 9822964
                              9   ...ple.CoreServices.CarbonCore     0x97f1485a PrivateMPEntryPoint + 68
                              10  libSystem.B.dylib                  0x90fa185d _pthread_start + 345
                              11  libSystem.B.dylib                  0x90fa16e2 thread_start + 34
                              Thread 18:
                              0   libSystem.B.dylib                  0x90f99a12 __workq_kernreturn + 10
                              1   libSystem.B.dylib                  0x90f99fa8 _pthread_wqthread + 941
                              2   libSystem.B.dylib                  0x90f99bc6 start_wqthread + 30
                              Thread 0 crashed with X86 Thread State (32-bit):
                                eax: 0xa0a768ac  ebx: 0x982c0d81  ecx: 0x00000000  edx: 0x00000016
                                edi: 0xbfffdde4  esi: 0x00000000  ebp: 0xbfffd9b8  esp: 0xbfffd850
                                 ss: 0x0000001f  efl: 0x00010283  eip: 0x982c0df0   cs: 0x00000017
                                 ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
                                cr2: 0x00000000
                              Binary Images:
                                  0x1000 -  0x1448ff1 +Adobe Fireworks CS5 ??? (???) <38213EBD-FDB0-FC20-40E8-87935A5386BB> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/Adobe Fireworks CS5
                               0x1e82000 -  0x1ed5ffb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <4F2BFF03-01D2-A07D-E5E2-7F88D4C2DEC4> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                               0x1f1d000 -  0x1f83ffb +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <DD471011-9120-1BC2-F1B5-D6FF09D0859F> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                               0x1fb3000 -  0x2152fe7 +com.adobe.owl AdobeOwl version 3.0.81 (3.0.81) <9C261D9E-9BD7-5DE6-5676-AEEF4828D17B> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                               0x21bb000 -  0x22f3fe7 +WRServices ??? (???) <52CE5B97-1E6A-92A2-EA70-93511AB7EA2E> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                               0x2339000 -  0x23a6fef +FileInfo ??? (???) <4A4C74F9-CA83-B174-F56D-F7671DC61389> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
                               0x23c1000 -  0x23e7ff6 +AdobeAXE8SharedExpat ??? (???) <5848BBCE-3A3E-66EE-5527-97A96F0CA4CC> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
                               0x23f8000 -  0x2413fff +AdobeBIB ??? (???) <3B3092DC-A296-9D1C-1922-D20E6A5A7D7E> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                               0x241d000 -  0x2475ff7 +AdobeXMP ??? (???) <73329999-C364-2451-6574-4D0277057D19> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                               0x2484000 -  0x2ab2fe7 +AdobeAGM ??? (???) <91D37E54-E985-47E1-2696-0BD7E4183132> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                               0x2c10000 -  0x2d24fff +AdobeACE ??? (???) <DD291A17-ECF4-FE20-5837-AC1F5BC76940> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                               0x2d47000 -  0x3039ff7 +AdobeCoolType ??? (???) <9FDD596D-9824-2BB9-5DA2-25DACAB6A324> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                               0x30c1000 -  0x30e2ff7 +AdobeBIBUtils ??? (???) <E1FAA7A3-E807-DE5A-1F68-7A53780E8202> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                               0x30ee000 -  0x312afff +AdobeARE ??? (???) <76851E91-2381-5D05-742C-BB24E4BAD276> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                               0x3133000 -  0x350bff7 +AdobeMPS ??? (???) <13614867-4D80-EB74-FA7F-6136492478BA> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                               0x363a000 -  0x3c6efeb +AdobePDFL ??? (???) <49D6D58A-1EBB-424A-4CB0-8F9691E0991D> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
                               0x3d9a000 -  0x4addfff +com.adobe.psl AdobePSL 12.0.0.7524 (12.0.0.7524) <CFBCB19A-03F7-D095-1F48-8D68F05A25C5> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                               0x4e1c000 -  0x4ea6ff7 +com.adobe.AdobeScCore ScCore 4.1.7 (4.1.7.5522) <053A109E-3E3E-D3EE-7186-4920D927D2AD> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                               0x4ee9000 -  0x4fccfef +AdobePDFPort ??? (???) <A2E6DCF7-283F-09E9-53AE-D5D84D020469> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
                               0x5001000 -  0x5004ff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <FFDDAB7A-220F-7344-F12B-010CA0C41DAB> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                               0x500a000 -  0x509bff7 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <581475CC-C039-1B42-49BA-71811D8B4E15> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
                               0x50ba000 -  0x5a6afff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <02108DEA-3DD2-14BE-DAEB-BE522B619C1D> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
                               0x5a6d000 -  0x5b3aff3 +libicui18n.dylib.36.0 36.0.0 (compatibility 36.0.0) <08F15219-7F35-574E-7725-1ACAA1B18A00> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ICUInternationalization.framework/Versions/3.6/libicui18n.dylib.36.0
                               0x5b9d000 -  0x5c77fef +libicuuc.dylib.36.0 36.0.0 (compatibility 36.0.0) <5EE72009-40B3-7FB7-3A49-576AEDE0D400> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6/libicuuc.dylib.36.0
                               0x5cb7000 -  0x6a42fe7 +com.adobe.illustrator 382 (15.0.0) <64F68532-0311-6BBA-1F50-246CAF917549> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
                               0x7827000 -  0x786bfff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <69EDC44E-D7BB-A259-282D-C42725AE0E26> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPort
                               0x78ce000 -  0x7914fff +FilterPort ??? (???) <23FAE9D1-9376-1E71-21F7-D3EB2BFD50EE> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/FilterPort.framework/Versions/A/FilterPort
                               0x7989000 -  0x7989fff +SPBasic ??? (???) <5D1760D8-C910-C641-0BC9-CF74A1A5190D> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
                               0x798d000 -  0x7b73ff7 +com.adobe.linguistic.LinguisticManager 5.0.0 (11309) <CA1D50A3-F965-F8B2-76B9-007F290C5791> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                               0x7c01000 -  0x7ccefe7 +AdobeAXEDOMCore ??? (???) <F76D74DC-FD5A-9783-C447-2E58773DA7E1> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                               0x7d3d000 -  0x7eb5ffb +com.adobe.PlugPlug 2.0.0.746 (2.0.0.746) <08AD22E3-34C0-6749-E497-616C66A246AD> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                               0x7f59000 -  0x7f76fef +libCurl.dylib ??? (???) <1BA6E2DE-EF14-D50A-4697-035AE07875D7> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/libCurl.dylib
                               0x7f7e000 -  0x7f94ff4 +libChar16.dylib ??? (???) <19B0479C-72B1-EE14-6385-7F655DEC0F02> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/libChar16.dylib
                               0x7f9c000 -  0x7fbffe0 +libCoreTypes.dylib ??? (???) <F5306147-FFBD-2826-D356-B26258DBFA09> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/libCoreTypes.dylib
                               0x7fcf000 -  0x7fd6ffc  com.apple.carbonframeworktemplate 1.0 (1.0) <0D270CC7-B715-943E-2B4F-5C9B5775505A> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/NetIO.framework/Versions/A/NetIO
                               0x7fe2000 -  0x7fe5fff +Dioxide.dylib ??? (???) <BCE94F23-4CCA-20FB-79A8-DE7925879DCD> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/Dioxide.dylib
                               0x7fed000 -  0x7ff3ffc +libfwutility.dylib ??? (???) <6A723D9E-A60B-56EE-2B8D-B91991793749> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/libfwutility.dylib
                               0x7ffa000 -  0x804afff +com.macromedia.javascript Javascript version 1.0 (1.0) <540CB029-3946-8E41-BD91-AED6F73C86B7> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/Javascript.framework/Versions/A/Javascript
                               0x805f000 -  0x806cfff +com.macromedia.moa Moa version 1.0 (1.0) <3C4B7F42-5A5D-78E7-B1DC-DAA06A99CCB2> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/Moa.framework/Versions/A/Moa
                               0x8075000 -  0x807cfff +com.macromedia.morefiles MoreFiles version 1.0 (1.0) <36115C66-79A3-5DB9-B36B-8D655B46FC76> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/MoreFiles.framework/Versions/A/MoreFiles
                               0x8083000 -  0x8167fe3 +libPowerPlant2.dylib ??? (???) <964FB3D7-B7EE-94EB-FD95-4AE90C657A4A> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/libPowerPlant2.dylib
                               0x829a000 -  0x82a0ffb +com.macromedia.testframework 1.0 (1.0) <ED14FA00-1C6F-D433-1EEB-833BB4402B2B> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/uwchar.framework/Versions/A/uwchar
                               0x82a4000 -  0x82a8ffc +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <E6437929-0E69-8A56-E69F-F64305E82DD9> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                               0x82af000 -  0x82c7fef +libgiff.dylib ??? (???) <8F90552B-3D11-2B1E-D1BA-A109FEB99969> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/libgiff.dylib
                               0x82cf000 -  0x82edfe7 +com.macromedia.png LibPNG version 1.0 (1.0) <2DBA0A3F-4F01-7474-0FED-3021382D635F> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/LibPNG.framework/Versions/A/LibPNG
                               0x82f5000 -  0x8303feb +com.macromedia.zlib ZLib version 1.0 (1.0) <EEA4CFAF-A748-FA72-91F0-ADE7A1BE9FA7> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ZLib.framework/Versions/A/ZLib
                               0x8308000 -  0x830cffd +com.yourcompany.yourcocoaframework ??? (1.0) <7EF7A82E-0AAE-0022-3B15-7C50F1C550C1> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ASEFramework.framework/Versions/A/ASEFramework
                               0x8311000 -  0x8318ff2 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.0) <F966C78A-3CC1-8678-B3B7-B0A2B118343A> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                               0x8328000 -  0x832efef +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.0) <8837A972-1EBE-CAA9-473A-CD157F17163D> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                               0x833f000 -  0x83bcfff +AdobeOwlCanvas ??? (???) <65B2E680-4F43-BE46-2290-3500758D1BF7> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/AdobeOwlCanvas
                               0x83d8000 -  0x83e3ff3 +com.adobe.boost_filesystem.framework boost_filesystem version 5.0.0 (5.0.0.0) <90B8B4E3-6C44-D110-1545-1A34EB14B22D> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                               0x83f7000 -  0x83f9ffb +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.0) <0C4D56E8-9593-4C4A-4A7E-BEAEDE1CA131> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                               0x8400000 -  0x84b5fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
                               0x84fb000 -  0x85abff7 +libCrypto.dylib ??? (???) <7743860E-1E20-BC36-8443-53A4DC91A879> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/libCrypto.dylib
                               0x85f7000 -  0x8618ffc +libSSL.dylib ??? (???) <202C3E7F-DBBB-4AF1-FFA7-7DDD19A17938> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/MacOS/libSSL.dylib
                               0x8625000 -  0x8665ff7  com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
                               0x990d000 -  0x990eff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                              0x1d9b2000 - 0x1d9c5ff7 +com.rogueamoeba.audio_hijack_server.hermes 2.2.8 (2.2.8) <750B9380-6255-E5AB-261A-57FE733634C7> /usr/local/hermes/modules/Instant Hijack Server.hermesmodule/Contents/MacOS/Instant Hijack Server
                              0x1d9d0000 - 0x1da37fea +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <EE468E2C-A6BD-E2EE-7ABE-69168B143B44> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
                              0x1dab8000 - 0x1dabbffb +com.Logitech.Control Center.Scroll Enhancer Loader 3.1.0 (3.1.0) <2F7F3421-9C99-1B20-E0D7-75CE73A97F05> /Library/InputManagers/LCC Scroll Enhancer Loader/LCC Scroll Enhancer Loader.bundle/Contents/MacOS/LCC Scroll Enhancer Loader
                              0x1dac0000 - 0x1dacafff +com.unsanity.smartcrashreports Smart Crash Reports version 1.5 (1.5) <7E3E7D42-BB62-6D09-E262-0140BA963851> /Library/InputManagers/Smart Crash Reports/Smart Crash Reports.bundle/Contents/MacOS/Smart Crash Reports
                              0x1dad7000 - 0x1dad7ff7 +net.sourceforge.SafariAdBlockLoader 0.4.0 RC3 (0.4.0 RC3) <8E9A6641-9CE7-5416-DC84-883DB8BAFDDA> /Library/InputManagers/Safari AdBlock/Safari AdBlock Loader.bundle/Contents/MacOS/Safari AdBlock Loader
                              0x1dadb000 - 0x1dadbfff +com.ksuther.chax.loader ??? (2.2.1) <D767CBF1-668B-AC0D-4E47-64582F411674> /Library/InputManagers/Chax/Chax.bundle/Contents/MacOS/Chax
                              0x1dae0000 - 0x1dae1fff +com.ecamm.pluginloader Ecamm Plugin Loader v1.0.5 (1.0.5) /Library/InputManagers/Ecamm/Ecamm Plugin Loader.bundle/Contents/MacOS/Ecamm Plugin Loader
                              0x1dae6000 - 0x1dafeff7 +com.delicioussafari.DeliciousSafari 1.7 (110) <B57AF2AA-8A7C-9E9A-16EA-B647D29736CF> /Library/InputManagers/DeliciousSafari/DeliciousSafari.bundle/Contents/MacOS/DeliciousSafari
                              0x1db15000 - 0x1db85feb +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <50675115-BEDC-72F9-C42D-374196E83EC2> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                              0x1db93000 - 0x1db9bfff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
                              0x1dc56000 - 0x1dc7ffeb +com.adobe.ape adbeapecore version 3.1.65.7508 (3.1.65.7508) <E0F7666B-921D-C4D6-63B3-E8B445D26892> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
                              0x1dfd0000 - 0x1e407fef  com.apple.RawCamera.bundle 3.6.0 (558) <CCF48B69-6B02-B0A5-45DF-5C5327AD16F0> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                              0x1eb1a000 - 0x1eb1bfe7  libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <917C387A-1F4E-F72C-514D-862CF11A822C> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
                              0x1f2e1000 - 0x1f31affb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <C64CCBDC-B8E9-45E8-53E7-8577CFE9F2F0> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
                              0x1f5f9000 - 0x1f5feff7  libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <4591F641-2C45-64A2-6C1C-C1722076B7F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libFontStreams.A.dylib
                              0x1f69a000 - 0x1f6a8fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <07211458-FD06-9FEF-3DF4-2E5F0304D4BC> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                              0x1f6b8000 - 0x1f6caff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <8D606435-1A3C-FE0B-824A-1386809FFFF5> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                              0x1fb6a000 - 0x1fb6fffb +com.macromedia.pict PICT Import Export version 1.0 (1.0) <5B7C5D2E-E7E5-9486-FC7D-8757F26AC4AA> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/PICT Import Export.bundle/Contents/MacOS/PICT Import Export
                              0x21070000 - 0x21078fff  com.apple.carbonbundletemplate 1.0 (1.0) <CF59539F-6DC9-3B0B-FBD4-509DA74AEBE3> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/JSExtensions/AIRext.bundle/Contents/MacOS/AIRext
                              0x2107e000 - 0x21082fff +com.macromedia.targa Targa Import version 1.0 (1.0) <FB1FC0D2-B47B-A054-C026-66A5E8BB31DD> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/Targa Import.bundle/Contents/MacOS/Targa Import
                              0x210de000 - 0x21104ff2  com.apple.carbonbundletemplate 3.0.2,4677 (3.0.2) <7FA5A69A-976D-A44A-5679-F4E00912304B> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/JSExtensions/MMNotes.bundle/Contents/MacOS/MMNotes
                              0x21128000 - 0x21130fff +com.macromedia.bmpimportexport 1.0 (1.0) <A2D04F1D-3150-8E7A-6C3D-EB48C582C261> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/BMP Import Export.bundle/Contents/MacOS/BMP Import Export
                              0x21137000 - 0x21155ff7 +com.macromedia.mix_services MIX Services version 1.0 (1.0) <A2E68C22-D23E-165E-0A57-E6BA9B9D5B2D> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/Mix Services.bundle/Contents/MacOS/MIX Services
                              0x21168000 - 0x211aafef +com.macromedia.tiff TIFF Import Export version 1.0 (1.0) <2ABEC8A4-B15C-1B8D-53B3-DFDDC8A0851B> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/Tiff Import Export.bundle/Contents/MacOS/Tiff Import Export
                              0x211b7000 - 0x211bcfeb +com.macromedia.twain TwainAgent version 1.0 (1.0) <FDFAD6E4-D5F4-A773-9A1B-5DAC9B464075> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/TwainAgent.bundle/Contents/MacOS/TwainAgent
                              0x211c2000 - 0x211c8ff7  org.twain.dsm 1.9.4 (1.9.4) <1EF840DB-CB48-5207-7535-D82EBC0FCD5F> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
                              0x211cf000 - 0x211d2fff +com.macromedia.wbmp WBMP Import Export version 1.0 (1.0) <E3A57AC0-D6E8-7619-74AD-E7B1ADB99B94> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/WBMP Import Export.bundle/Contents/MacOS/WBMP Import Export
                              0x21327000 - 0x2132bff3  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <F402CF88-D96C-42A0-3207-49759F496AE8> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
                              0x2133a000 - 0x2135bfe8 +org.movino.MovinoQT 1.01 ($Rev: 136 $) (1.01 ($Rev: 136 $)) <05645C37-6315-4807-0067-4C084089C61D> /Library/QuickTime/MovinoQT.component/Contents/MacOS/MovinoQT
                              0x21564000 - 0x2156affb  com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <82BFF5E9-2B0E-FE8B-8370-445DD94DA434> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
                              0x22e56000 - 0x22e7afe7  GLRendererFloat ??? (???) <1274B762-2FB9-48FE-EAFD-C459B2B4BECC> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
                              0x232f7000 - 0x2331afe7 +ServiceManager-Launcher.dylib ??? (???) <12CEC4C0-8682-A5FD-BAD4-A3E4A4F6218A> /Library/Application Support/Adobe/CS5ServiceManager/lib/ServiceManager-Launcher.dylib
                              0x23932000 - 0x23c7afe7 +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.0) <3D6B5526-68C6-AB1B-B98F-326F18EA44F0> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/dvaadameve.framework/dvaadameve
                              0x24172000 - 0x242eefe7 +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.0) <4BC4AD81-2341-CCA5-6972-F9C2B8C7B097> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                              0x24462000 - 0x24748fff +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.0) <3F61310E-8DF6-5E42-878E-E6A696BDD0AF> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                              0x24a5e000 - 0x24a87fe3  com.apple.audio.CoreAudioKit 1.6.1 (1.6.1) <7FFBD485-5251-776A-CC44-4470DD84112B> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
                              0x24d00000 - 0x25b19fc3 +com.adobe.adobeswfl ??? (2.0.0.7489) <C954CA64-9B28-A7FA-E391-C1C6524F1639> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/AdobeSWFL
                              0x27800000 - 0x27e95ffb +com.macromedia.Flash Player.authplaylib 10.0.0.508 (1.0.1d333) <02A2245F-4883-4AA8-B06C-47704216613B> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/PlugIns/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
                              0x29cd1000 - 0x29e49fe7  GLEngine ??? (???) <3A6C5513-7428-2242-2892-B429C72343CB> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                              0x29f42000 - 0x2a3acfe7  com.apple.driver.AppleIntelGMAX3100GLDriver 1.6.26 (6.2.6) <885552BA-499B-02A2-7B0D-5A7A77D3AEC2> /System/Library/Extensions/AppleIntelGMAX3100GLDriver.bundle/Contents/MacOS/AppleIntelGMAX3100GLDriver
                              0x90003000 - 0x90027ff7  libJPEG.dylib ??? (???) <46AF3A0F-2B8D-87B9-62D4-0905678A64DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                              0x90028000 - 0x90049fe7  com.apple.opencl 12.3 (12.3) <DEA600BF-4F54-66B5-DB2F-DC57FD518543> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                              0x9004a000 - 0x9004aff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                              0x90058000 - 0x9007afef  com.apple.DirectoryService.Framework 3.6 (621.9) <F2EEE9D7-D4FB-14F3-E647-ABD32754F557> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                              0x90094000 - 0x900d3ff7  com.apple.ImageCaptureCore 1.0.3 (1.0.3) <7E02D104-F31C-CF72-71B4-DA5DF7B48337> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                              0x900d4000 - 0x900d4ff7  com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                              0x900d5000 - 0x900d8ffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
                              0x900d9000 - 0x900e5ff7  libkxld.dylib ??? (???) <F0E915AD-6B32-0D5E-D24B-B188447FDD23> /usr/lib/system/libkxld.dylib
                              0x90108000 - 0x90401fef  com.apple.QuickTime 7.6.6 (1756) <F08B13B6-31D7-BD18-DA87-A0CDFCF13B8F> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
                              0x90402000 - 0x90406ff7  IOSurface ??? (???) <D849E1A5-6B0C-2A05-2765-850EC39BA2FF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                              0x90407000 - 0x904bdff7  libFontParser.dylib ??? (???) <33F62EE1-E457-C6FD-369E-E86745B94A4B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
                              0x904be000 - 0x90550fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
                              0x90551000 - 0x90597ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
                              0x90598000 - 0x905e8ff7  com.apple.framework.familycontrols 2.0.2 (2020) <AF7F86F1-F7BF-CBA8-7A4A-D8F7A19F9601> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                              0x9061c000 - 0x90748ffb  com.apple.MediaToolbox 0.484.20 (484.20) <D67788A2-B772-C5DB-B12B-173B2F8EE40B> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                              0x90749000 - 0x9078bff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
                              0x9078e000 - 0x907b8ff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                              0x907b9000 - 0x907cefff  com.apple.ImageCapture 6.0.1 (6.0.1) <E7ED2AC1-834C-A44E-531E-EC05F0496DBF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
                              0x907cf000 - 0x907d9fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
                              0x907da000 - 0x907daff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
                              0x907db000 - 0x907f6ff7  libPng.dylib ??? (???) <E14178E0-B92D-94EA-DACB-04F346D7534C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                              0x9080c000 - 0x9083cff7  com.apple.MeshKit 1.1 (49.2) <ECFBD794-5D36-4405-6184-5568BFF29BF3> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
                              0x9083d000 - 0x9083dff7  com.apple.quartzframework 1.5 (1.5) <CEB78F00-C5B2-3B3F-BF70-DD6D578719C0> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                              0x908b1000 - 0x908b1ff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                              0x908b2000 - 0x9095affb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
                              0x9095c000 - 0x909b9ff7  com.apple.framework.IOKit 2.0 (???) <A769737F-E0D6-FB06-29B4-915CF4F43420> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                              0x909ba000 - 0x909bdfe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
                              0x90a9b000 - 0x90aafffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
                              0x90ab0000 - 0x90abeff7  com.apple.opengl 1.6.12 (1.6.12) <9F13B279-F289-18AC-5D86-DCD52BAF087D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                              0x90af7000 - 0x90b1dffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
                              0x90b1e000 - 0x90b30ff7  com.apple.MultitouchSupport.framework 207.10 (207.10) <E1A6F663-570B-CE54-0F8A-BBCCDECE3B42> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
                              0x90c2d000 - 0x90c87fe7  com.apple.CorePDF 1.3 (1.3) <696ADD5F-C038-A63B-4732-82E4109379D7> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                              0x90c88000 - 0x90cbefff  libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
                              0x90d2b000 - 0x90d32ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <6877F0D8-0DCF-CB98-5304-913667FF50FA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                              0x90da8000 - 0x90db8ff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
                              0x90db9000 - 0x90e0aff7  com.apple.HIServices 1.8.2 (???) <F6EAC2D1-902A-9374-FC4B-43B50E054416> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
                              0x90e96000 - 0x90f31ff7  com.apple.ApplicationServices.ATS 4.4 (???) <ECB16606-4DF8-4AFB-C91D-F7947C26040F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
                              0x90f73000 - 0x9111aff7  libSystem.B.dylib 125.2.1 (compatibility 1.0.0) <62291026-D016-705D-DC1E-FC2B09D47DE5> /usr/lib/libSystem.B.dylib
                              0x9115e000 - 0x911abfeb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
                              0x9122a000 - 0x91336ff7  libGLProgrammability.dylib ??? (???) <A077BFEA-19C6-9F48-2F36-8E4E55376F49> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
                              0x91337000 - 0x91377ff3  com.apple.securityinterface 4.0.1 (40418) <26D84A83-F5B9-93CF-71BB-0712698181EE> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                              0x9138b000 - 0x913ceff7  com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
                              0x913cf000 - 0x913d2ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <B624AACE-991B-0FFA-2482-E69970576CE1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
                              0x913d3000 - 0x9144dfff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <F7C9B01D-45AD-948B-2D26-9736524C1A33> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                              0x9144e000 - 0x91466ff7  com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
                              0x91467000 - 0x9146bff7  libGIF.dylib ??? (???) <DA5758A4-71B0-DD6E-7402-B7FB15387569> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                              0x9146c000 - 0x9156dfe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
                              0x9156e000 - 0x91649feb  com.apple.DesktopServices 1.5.9 (1.5.9) <CED00AC1-924B-0E45-7D5E-1CEA8929F5BE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
                              0x91762000 - 0x91781ff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                              0x91782000 - 0x91783ff7  com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
                              0x91839000 - 0x9186bfe3  libTrueTypeScaler.dylib ??? (???) <6E9D1A50-330E-F1F4-F93D-9ECC8A61B21A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
                              0x9186c000 - 0x918c2ff7  com.apple.MeshKitRuntime 1.1 (49.2) <F1EAE9EC-2DA3-BAFD-0A8C-6A3FFC96D728> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
                              0x918c3000 - 0x918d3ff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
                              0x918fb000 - 0x918fbff7  com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                              0x9193d000 - 0x9212c557  com.apple.CoreGraphics 1.545.0 (???) <1AB39678-00D5-FB88-3B41-93D78348E0DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                              0x92265000 - 0x92266ff7  com.apple.audio.units.AudioUnit 1.6.5 (1.6.5) <BE4C2495-B758-AD22-DCC0-56A6791E948E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                              0x92267000 - 0x924cafff  com.apple.security 6.1.1 (37594) <B6F2A8BF-C1B7-A0E2-83FB-4FF265E9BDDC> /System/Library/Frameworks/Security.framework/Versions/A/Security
                              0x924cb000 - 0x924d5ff7  com.apple.HelpData 2.0.4 (34) <9128FFEB-0F6C-B273-FCF4-D87A20227345> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                              0x924d6000 - 0x9251ffe7  libTIFF.dylib ??? (???) <AC1FC806-F7F4-174B-375F-FE5D6008666C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                              0x92520000 - 0x92551ff7  libGLImage.dylib ??? (???) <E3EC8E92-4DDD-E7B8-3D38-C5A5160A4930> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                              0x92552000 - 0x925cbff7  com.apple.PDFKit 2.5.1 (2.5.1) <CEF13510-F08D-3177-7504-7F8853906DE6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
                              0x925cc000 - 0x92636fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
                              0x92637000 - 0x92638ff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
                              0x92752000 - 0x92756ff7  libGFXShared.dylib ??? (???) <9E14BE2F-C863-40E9-41A6-1BE9045663A0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                              0x9278f000 - 0x92afaff7  com.apple.QuartzCore 1.6.3 (227.34) <CC1C1631-D8D1-D416-171E-A1683274E479> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                              0x92afb000 - 0x92b76fff  com.apple.AppleVAFramework 4.10.12 (4.10.12) <89C4EBE2-FE27-3160-0BD1-D0C2ED5F3605> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                              0x92b77000 - 0x93030ffb  com.apple.VideoToolbox 0.484.20 (484.20) <E7B9F015-2569-43D7-5268-375ED937ECA5> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                              0x93031000 - 0x9303ffe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
                              0x93040000 - 0x93054fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
                              0x93055000 - 0x930b9ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
                              0x930ba000 - 0x930bcff7  com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
                              0x930bd000 - 0x931c1fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <BDEFA030-5E75-7C47-2904-85AB16937F45> /usr/lib/libcrypto.0.9.8.dylib
                              0x944cd000 - 0x944d6ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                              0x945dd000 - 0x946a7fef  com.apple.CoreServices.OSServices 357 (357) <CF9530AD-F581-B831-09B6-16D9F9283BFA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
                              0x946a8000 - 0x947d6fe7  com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                              0x947d7000 - 0x947e4ff7  com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                              0x9480a000 - 0x9480aff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                              0x9480b000 - 0x94813ff7  com.apple.DisplayServicesFW 2.3.0 (283) <48D94761-7340-D029-99E3-9BE0262FAF22> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                              0x94814000 - 0x948acfe7  edu.mit.Kerberos 6.5.10 (6.5.10) <8B83AFF3-C074-E47C-4BD0-4546EED0D1BC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                              0x948ad000 - 0x948b3fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
                              0x948b4000 - 0x948b9ff7  com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                              0x948ba000 - 0x94957fe3  com.apple.LaunchServices 362.2 (362.2) <F3952CAB-322F-A12F-57AF-8B91B1D76DDE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
                              0x94958000 - 0x94a9bfef  com.apple.QTKit 7.6.6 (1756) <4D809734-4E1B-8E18-C825-86C5422FC3DC> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                              0x94acf000 - 0x94b13ff3  com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                              0x94b14000 - 0x94b94feb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
                              0x94c36000 - 0x9506bff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
                              0x9506c000 - 0x95073ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
                              0x95074000 - 0x950a7ff7  com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
                              0x950a8000 - 0x950e6ff7  com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                              0x950e7000 - 0x95194fe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
                              0x95195000 - 0x951d6ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <16DAE1A5-937A-1CA2-D98F-2AF958B62993> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                              0x951d7000 - 0x952a8fe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <8FDB4C40-D453-DA53-2A66-9A53998AB23C> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
                              0x95cf5000 - 0x95ed7fff  com.apple.imageKit 2.0.3 (1.0) <B4DB05F7-01C5-35EE-7AB9-41BD9D63F075> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
                              0x95ed8000 - 0x95f82fe7  com.apple.CFNetwork 454.11.5 (454.11.5) <D8963574-285A-3BD6-6B25-07D39C6F67A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                              0x95f97000 - 0x962bbfef  com.apple.HIToolbox 1.6.4 (???) <4699C8BB-DE74-C530-564B-D131F74C9B54> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
                              0x962bc000 - 0x96475feb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <C145139E-24C4-5A3D-B17C-809D528354B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
                              0x964ca000 - 0x96505feb  libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
                              0x96506000 - 0x96522fe3  com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
                              0x96523000 - 0x9654aff7  com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
                              0x9654b000 - 0x965f9ff3  com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
                              0x965fa000 - 0x96637ff7  com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                              0x96638000 - 0x9672cff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <9EC28185-D26F-533F-90C4-FBAA13A15947> /usr/lib/libiconv.2.dylib
                              0x9672d000 - 0x96766ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <E0D512DD-365D-46A0-F50C-435BC250424F> /usr/lib/libcups.2.dylib
                              0x96767000 - 0x96787fe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
                              0x96788000 - 0x97068ff7  com.apple.AppKit 6.6.7 (1038.35) <ABC7783C-E4D5-B848-BED6-99451D94D120> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                              0x97069000 - 0x9747fff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
                              0x97480000 - 0x9765bff3  libType1Scaler.dylib ??? (???) <A7AB841A-3F40-E0B8-ADDD-44014C7287C9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
                              0x9765c000 - 0x97667ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <CB2510BD-A5B3-9D90-5917-C73F6ECAC913> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
                              0x97791000 - 0x97791ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
                              0x97792000 - 0x97a05fe7  com.apple.Foundation 6.6.4 (751.42) <ACC0BAEB-C590-7052-3AB2-86C207C3D6D4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                              0x97a06000 - 0x97a2eff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
                              0x97a2f000 - 0x97b5efe3  com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5) <0A0F68E5-4806-DB51-764B-D97554B801AD> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                              0x97e93000 - 0x97ed7fe7  com.apple.Metadata 10.6.3 (507.15) <A23633F1-E913-66C2-A073-E2B174C09B18> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
                              0x97eee000 - 0x9820eff3  com.apple.CoreServices.CarbonCore 861.23 (861.23) <B08756E4-32C5-CC33-0268-7C00A5ED7537> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
                              0x9820f000 - 0x98215fe7  com.apple.CommerceCore 1.0 (6) <41C2A87D-93D8-56C1-9292-0400699F23C1> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
                              0x98216000 - 0x9826efe7  com.apple.datadetectorscore 2.0 (80.7) <A40AA74A-9D13-2A6C-5440-B50905923251> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
                              0x9827f000 - 0x98289ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
                              0x9829a000 - 0x98415fe7  com.apple.CoreFoundation 6.6.4 (550.42) <C78D5079-663E-9734-7AFA-6CE79A0539F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                              0x98553000 - 0x985f2fff  com.apple.Bluetooth 2.3.8 (2.3.8f7) <2F9EAC9C-ECD2-21CD-8957-BFFD20E2A772> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                              0x985f3000 - 0x985f3ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                              0x985f4000 - 0x987f1ff7  com.apple.JavaScriptCore 6533.19 (6533.19.1) <85A6BFDD-CBB6-7490-748D-8EA8B9B7FDD8> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                              0x987f2000 - 0x988cfff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
                              0x988d8000 - 0x98991fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
                              0x98992000 - 0x989d9ffb  com.apple.CoreMediaIOServices 134.0 (1160) <D4F40A28-4E31-3210-7C2B-59D8A1903FB2> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
                              0x989da000 - 0x989e5ff7  libGL.dylib ??? (???) <48405993-0AE9-292B-6705-C3525528682A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                              0x98e1e000 - 0x98eceff3  com.apple.ColorSync 4.6.3 (4.6.3) <AA1076EA-7665-3005-A837-B661260DBE54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
                              0x98ecf000 - 0x98f51ffb  SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                              0x98f52000 - 0x98fb3fe7  com.apple.CoreText 3.5.0 (???) <BB50C045-25F5-65B8-B1DB-8CDAEF45EB46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
                              0x98fb4000 - 0x990b6fef  com.apple.MeshKitIO 1.1 (49.2) <34322CDD-E67E-318A-F03A-A3DD05201046> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
                              0x99294000 - 0x99416fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <35DB7644-0780-D2AB-F6A9-45F28D2D434A> /usr/lib/libicucore.A.dylib
                              0x9961f000 - 0x99622ff7  libCoreVMClient.dylib ??? (???) <973B9E1F-70B3-2E76-B14B-E57F306AD2DF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                              0x99645000 - 0x996b3ff7  com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
                              0x996b4000 - 0x99723ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
                              0x99724000 - 0x99761ff7  com.apple.CoreMedia 0.484.20 (484.20) <105DDB24-E45F-5473-99E1-B09FDEAE4500> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
                              0x99765000 - 0x99990ff3  com.apple.QuartzComposer 4.2 ({156.28}) <08AF01DC-110D-9443-3916-699DBDED0149> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
                              0x999e2000 - 0x999e4ff7  libRadiance.dylib ??? (???) <10048B4A-2AE8-A4E2-21B8-C6E7A8C5B76F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                              0x999e5000 - 0x99a28ff7  libGLU.dylib ??? (???) <BB66EDB2-D5FE-61C9-21BE-747F9862819C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                              0x99a2f000 - 0x99a40ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
                              0xb0000000 - 0xb000fff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <24B39C2F-79B0-BDE3-C6D0-1F0E943070C7> /Applications/Adobe Fireworks CS5/Adobe Fireworks CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                              0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <B339B85B-1B6D-81D8-1281-7B8C8A517329> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                              0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <EF3E3210-927F-DB9F-4CD4-4039A2AE2F84> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                              0xeab00000 - 0xeab10fe7  libConverter.dylib 169.1.0 (compatibility 1.0.0) <116CF161-A391-45BC-81B5-0954C87C8ABB> /System/Library/Printers/Libraries/libConverter.dylib
                              0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <62291026-D016-705D-DC1E-FC2B09D47DE5> /usr/lib/libSystem.B.dylib
                              • 12. Re: Fireworks CS5 Crashes
                                Priyanka C Herur
                                Hi Andrew,
                                We are investigating this issue and it looks like Fireworks crash that you've encountered is different from that of Jeff's. It would be of great help if you could share the file which caused Fireworks to crash. We would also like to know the steps to reproduce it.
                                Thank you.
                                -Priyanka.
                                • 13. Re: Fireworks CS5 Crashes
                                  Awasu Design LLC
                                  Hi Priyanka.
                                  We too are having a similar problem with Fireworks CS5 crashing. We used to utilize Dropbox but are now on a MacMini Server and connect via wi-fi. Users are saving files to their desktop and moving back to the server at the end of each day. The more typical crash occurs while exporting a FW file to PDF. Our other issue happens when trying to simply save the FW file. The standard "Application quite unexpectedly" error occurs and we lose any unsaved changes. We have three full time employees working in FW so you could imagine the teams frustrations. Due to the nature and sensitivity of our files, we can't upload any client work but can try to edit some of the content down to be more ambiguous.
                                  Roberto T
                                  • 14. Re: Fireworks CS5 Crashes
                                    Andrew Odri Level 1
                                    Hi Priyanka,
                                    It crashes with every file I open, *.gif, *.jpg, flat *.png, Firworks *.png, everything. As I mentioned in my previous post, it happens if I do not open any files, and just open the "About Dreamweaver" dialog box. Also as I previously mentioned, it was crashing before the load screen even appeared, but that has stopped for some reason. I have tried uninstallling other software, removing startup items, reinstaling Fireworks, removing the preferences, a lot of different things. As I mentioned, when it was crashing on staryup, I was able to open Fireworks under another user account, but it would crash when any file was opened.
                                    I can send a video vis Dropbox if that would help...
                                    Tyanks, Andrew
                                    • 15. Re: Fireworks CS5 Crashes
                                      Sarthak Singhal Adobe Employee
                                      @Roberto,
                                      It will be good if you could remove the confidential data from the file and send it to us. You could even send the file via a private message. Once the file is with us, we will keep it confidential for engineering purposes only.
                                      If possible, please create a video of the workflow leading to a crash and then share it with us.
                                      ..Sarthak
                                      • 16. Re: Fireworks CS5 Crashes
                                        @Andrew
                                        "About Dreamweaver"? I am a little confused now.
                                        Please send in the video for us to investigate it further. We already have the crash log you have sent earlier, but it will be nice if you can send the new crash logs as well.
                                        ..Sarthak
                                        • 17. Re: Fireworks CS5 Crashes
                                          Andrew Odri Level 1
                                          Sorry, I mean't "About Fireworks...", I had mentioned that in my original post. I will post up a video and the logs now.
                                          • 19. Re: Fireworks CS5 Crashes
                                            Linda Nicholls Level 4
                                            You've got 15 other programs open when you attempt to open Fireworks. Try it again after shutting them down.
                                            • 20. Re: Fireworks CS5 Crashes
                                              Andrew Odri Level 1
                                              Hi Linda,
                                              I don't know if you had a chance to read through what I posted previously, but it is availble here: http://forums.adobe.com/message/3484893#3484893. It details many of the things I have tried. But I will repeat them once again. I have this wothout apps running. I have tried this after removing all of my startup items. I have tried this under a vanilla user account with nothing running. I have removed the *.plist. I have removed all the preferences. I reinstalled Creative Suite. I downloaded an isolated version of Fireroks and tried.
                                              I am sorry if I made a typo earlier, but please read the supplied documentation I provided. I will supply reasonable information if it requested to help remedy the problem, but if I am going to get the typical "reboot you computer" responses, please don't bother replying. Or at least the read the whole thing.
                                              Thanks, Andrew
                                              • 21. Re: Fireworks CS5 Crashes
                                                Priyanka C Herur Level 1
                                                Hey Andrew,
                                                Thanks for the video and the report.
                                                Is this crash intermittent or do you encounter this crash every time you launch FW and follow the steps that you've mentioned?
                                                I would even like to know which other applications were running when you encountered this crash.
                                                It would be of great help if you could provide us with the above mentioned information to reproduce the crash.
                                                Priyanka.
