3 Replies Latest reply on Sep 15, 2010 10:01 PM by BhaskerChari
    How do you use a repeater
    AVKRFLEX
        How do you use a repeater?..what is the use of the repeaters.
      Thanks & Regards,
      Anderson.
        • 1. Re: How do you use a repeater
          UbuntuPenguin Level 4
          If you are using Flex 4 you should look into DataGroups.
          • 2. Re: How do you use a repeater
            RKaster
            I would think in most cases itemRenderers would trump the use of a Repeater. Originally I used repeaters, but I quickly learned that itemRenderers do the job much more efficiently and effectively.
            I would look that up if you got the time, or maybe your're already aware of them.
            • 3. Re: How do you use a repeater
              BhaskerChari Level 4
              Hi Anderson,
              Flex Repeater is basically a loop function in mxml. You give the repeater a data provider (A collection of data), and the repeater will iterate over that collection and display the MXML components within the repeater.
              The Repeater class is the runtime object that corresponds to the <mx:Repeater> tag. It creates multiple instances of its subcomponents based on its dataProvider. The repeated components can be any standard or custom controls or containers.
              Bhasker
