20 Replies Latest reply on Apr 5, 2011 7:14 AM by gone3d
    DRM, NetGroup, SystemUpdater classes cannot be found
    aintnosleeves
      Today I've downloaded a fresh copy of Flash Builder Standalone, with Flex v4.1 coming installed with it. I'm trying to add OSMF swc to my existing project, but I keep running across the following errors:
      1046: Type was not found or was not a compile-time constant: DRMAuthenticationCompleteEvent.
      1046: Type was not found or was not a compile-time constant: DRMAuthenticationErrorEvent.
      1046: Type was not found or was not a compile-time constant: DRMErrorEvent.
      1046: Type was not found or was not a compile-time constant: DRMStatusEvent.
      1046: Type was not found or was not a compile-time constant: NetGroup.
      1046: Type was not found or was not a compile-time constant: SystemUpdater.
      I've followed the swc install instructions as carefully as possible, but it appears as though some swc that I've downloaded within the most recent version of Flash Builder is not up to date?
        • 1. Re: DRM, NetGroup, SystemUpdater classes cannot be found
          weizhangstrobe Level 2
          It looks like your playerglobal.swc is for a FlashPlayer 10.0 or earlier. What's your compiler settings?
          -Wei Zhang
          Senior Computer Scientist
          Adobe Systems, Inc.
          weizhang@adobe.com
          • 2. Re: DRM, NetGroup, SystemUpdater classes cannot be found
            aintnosleeves Level 1
            Again, this is a brand new install from a download today of the latest version of Flash Builder. It contains only Flex 3.5 and 4.1.
            I've set these values per instructions in OSMF 1.5 Release Notes s03.pdf:
            • 4. Set Require Flash Player version to 10.0.0.
            • *Flash Builder 4 users must change default SDK version to Flex 4.0 and check the “Use Flex 3 compatibility mode” checkbox to avoid compile errors.
            • The Flex 4.0 SDK ships with an earlier version of OSMF. If you want to use the Flex 4 SDK with the latest version of OSMF, you need to remove the older version of OSMF. To do so in Flash Builder 4, select File > Properties > Flex Build Path > Library path, select osmf.swc under Flex 4.0 SDK on the Library Path panel, and click the Remove button.
            What other information can I provide?
            • 3. Re: DRM, NetGroup, SystemUpdater classes cannot be found
              rshin Level 3
              Is your project an air application?
              Ryan
              • 4. Re: DRM, NetGroup, SystemUpdater classes cannot be found
                It is not, it's a normal flex app. I thought it might be because the projects were older ones and perhaps they pointed to some other playerglobal.swc in their .actionscriptProperties file, but I have created a new project and added simple code and I still see the same issue.
                I've been able to reproduce quite quickly with a fresh install of Flex Builder.
                1. Download the latest version of Flex Builder 4 for Mac
                2. Create new project.
                3. Follow instructions in OSMF 1.5 Sprint 3 Release Notes.pdf -
                  1. Select the project folder and choose File > Properties. In the Properties window, select Flex Compiler.
                  2. Verify the Flex SDK version. OSMF should work on any Flex SDK version, but the sample apps that we ship with may be created with Flex SDK 3.2 or above.
                  3. Set Require Flash Player version to 10.0.0. In order to install/update Flash player, please go to
                  4. Copy OSMF.swc on to your local machine.
                  5. In your Properties window of your project, select the Flex Build Path ‐> Library Path tab
                  6. Select Add SWC. Add OSMF and click Finish.
                  7. Flash Builder 4 users must change default SDK version to Flex 4.0 and check the “Use Flex 3 compatibility mode” checkbox to avoid compile errors.
                4. Use the following as application code:
                                  xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                     <fx:Declarations>
                          <!-- Place non-visual elements (e.g., services, value objects) here -->
                     </fx:Declarations>
                     <fx:Script>
                          <![CDATA[
                               import org.osmf.media.DefaultMediaFactory;
                               import org.osmf.media.MediaFactory;
                               var mediaFactory:MediaFactory = new DefaultMediaFactory()
                     </fx:Script>
                </s:Application>
                When I try to compile this, I cannot because of the errors I've listed above. I'm using flex 4.1, and this happens regardless of how I set the compatibility mode. Thoughts?
                • 5. Re: DRM, NetGroup, SystemUpdater classes cannot be found
                  This gets a little bit difficult for me to diagnose on paper. Would you mind packing up the whole project and sending it over to me so I can try to reproduce within my dev environment?
                  -Wei Zhang
                  Adobe Systems, Inc.
                  weizhang@adobe.com
                  • 6. Re: DRM, NetGroup, SystemUpdater classes cannot be found
                    Can be found here: http://benporterfield.com/player.fxp
                    Let me know if you need it in another format.
                    • 7. Re: DRM, NetGroup, SystemUpdater classes cannot be found
                      rshin Level 3
                      If you haven't done so, please make sure the project is compiled with approproriate SDK.  You seemed already checked this however, mentioning this again because I have seen this before. The case was the project automatically set to Flex SDK 3.5 when imported or created.
                      After changing to Flex SDK 4.0 the compiler error has gone.
                      Go to properties of the application that throws the compiler errors.  Go to Actionscript Compiler > Flex SDK version > Select Use Default SDK (currently "Flex 4.0/4.1") (or you can use  a specific SDK for the right one.
                      If it doesn't solve this, yes please send the project files to Wei.
                      Ryan
                      • 8. Re: DRM, NetGroup, SystemUpdater classes cannot be found
                        Thanks Ryan and Wei for the responses. I've attached a link to download the exported project in a comment above.
                        In the case of the project I sent, I have not messed with the flex sdk it uses, it's still set to the default for a new project that is set when you first in stall Flash Builder, which appears to be Use Default SDK (4.1).
                        Anything else I can do to assist?
                        • 9. Re: DRM, NetGroup, SystemUpdater classes cannot be found
                          Another note - updating the project to use the latest SDK (4.1.0.16706) from the Flex site did not resolve the issue.
                          Also - I saw the same issue in Eclipse with the Flash Builder plugin.
                          Anything I can do in the meantime to just get my project moving?
                          • 10. Re: DRM, NetGroup, SystemUpdater classes cannot be found
                            Andrian Cucu Adobe Employee
                            For using FlashPlayer 10.1 features like DRM, with the latest Flash Builder 4 and Flex 4.1 SDK you need to follow these steps:
                            1. Go to project Properties for OSMF
                            2. Select Flex Library Compiler
                            3. Verify that you use Flex 4.1 (i can see that you already do)
                            4. Select 'Use specific version' and set it to 10.1.0
                            5. Additional compiler arguments:
                            -define CONFIG::LOGGING true -define CONFIG::FLASH_10_1 true
                            (having logging set to true is always handy for troubleshooting).
                            If you use StrobeMediaPlayback, OSMFPlayer or a custom player, you need to have the settings above match.
                            You might need to check this for any other OSMF plugins, or samples that you use.
                            Hope this helps,
                            Andrian
                            • 11. Re: DRM, NetGroup, SystemUpdater classes cannot be found
                              This does resolve the issue! Although, I'm not modifying project properties for OSMF, I'm modifying the project that is including the OSMF swc.
                              I would suggest making this much clearer in the OSMF instructions. Nowhere in the instructions does it explain to set the Flash Player to 10.1 (in fact, it states clearly to set it to 10.0) or add these config options. It states that it will work with any version of Flex, which is not true when using the latest version of Flash Builder without these additional undocumented steps.
                              Thanks for all the quick responses to help me find the fix.
                              • 12. Re: DRM, NetGroup, SystemUpdater classes cannot be found
                                rshin Level 3
                                Thanks for pointing that out.  That's because that is only for SDK 4.1 case to set FP to 10.1.  For SDK 4.0, selecting "Use minium version required by SDK" in Adobe Flash player options works.   We will update the steps in next release as you suggested.
                                Ryan
                                • 13. Re: DRM, NetGroup, SystemUpdater classes cannot be found
                                  greg•hamer
                                  Hi Ryan,
                                  Does DynamicStreamingSample require FP 10.1?
                                  In order to successfully import that project into Flash Builder, I did need to follow the steps in Andrian's post to clear errors.  Steps including the changes setting 'Use specific version' to 10.1.0.
                                  Another issue that may need to be addressed in that project (readme.txt or otherwise), is that after following the steps in Andrian's post I also needed to clear further errors by making the following changes in DynamicStreamingSample.css (in 2 instances of @font-face {}):
                                  src: local("Verdana");
                                  To:
                                  src: url("C:/WINDOWS/Fonts/verdana.ttf");
                                  I made the changes above after the compiler returned the following error (2 instances):
                                  Resource
                                  Description
                                  exception during transcoding: Cannot embed local font 'Verdana' as CFF. The CSS @font-face 'local()' syntax is not supported. Please specify a path directly to a font file using the 'url()' syntax. For [Embed] syntax the 'systemFont' attribute is not supported. Please specify a path directly to a font file using the 'source' attribute.
                                  Path
                                  /DynamicStreamingSample/src
                                  Location
                                  line 23
                                  Type
                                  Flex Problem
                                  btw, Thank you to you and all of the OSMF team on this great sprint release  :-)
                                  Also, does the OSMF bugbase support entry of bugs on the sample applications?
                                  Warmest regards,
                                  g
                                  • 14. Re: DRM, NetGroup, SystemUpdater classes cannot be found (cont. - Flash CS4)
                                    greggdilorenzo2010
                                    Hello to the forum,
                                    I am trying to recreate examples based on:
                                    http://cookbooks.adobe.com/post_Playing_Multiple_Pieces_of_Media__Concurrently__wi-17640.h tml?w=rel
                                    I have downloaded the OSMF.swc and placed it in the proper libs folder.
                                    I publish the example and get:
                                    1046: Type was not found or was not a compile-time constant: DRMStatusEvent.1046: Type was not found or was not a compile-time constant: DRMStatusEvent.
                                    (there are two flvs in the example)
                                    On the publish tab, following the previous instructions on these forum posts I have added at
                                    FLASH:SETTINGS:CONFIG CONSTANTS:
                                    yet I still get the above errors. I am interested in exploring OSMF, but this issue is preventing me.
                                    (On this workstation I have WIN XPSP3 and I have Flash CS4 with Flash Player 10,0,2,54 and debug player YES, with all other constants YES.)
                                    Please advise,
                                    Gregg Di Lorenzo
                                    • 15. Re: DRM, NetGroup, SystemUpdater classes cannot be found (cont. - Flash CS4)
                                      rshin Level 3
                                      Greg h,
                                      I don't think DynamicStreamingSample app requires 10.1 compilation however, indeed, css syntax may have changed from FB3 to FB4 as I also see them in a couple sample apps in FB4.   We are in the process of converting the sample apps from FB3 to FB4, so they will be addressed.   Thanks for bring that up!
                                      Greggdilorenzo,
                                      If I am reading right, you are using Flash CS4?  I assuemed you've downloaded the lastest OSMF.swc posted.
                                      I would suggest to update playerglobalr.swc and your FP to the latest (10.1) to see that resolves the compilation.
                                      Ryan
                                      • 16. Re: DRM, NetGroup, SystemUpdater classes cannot be found (cont. - Flash CS4)
                                        greggdilorenzo2010 Level 1
                                        Hello Ryan,
                                        Thank you for the quick follow up.
                                        Yes I updated all the swc's and I am using Flash CS4 with the very latest Flash Player: Version 10,2,161,22.
                                        Any further ideas, FYI: I just cleared all caches, tried to reintall the player from adobe.com, and it says "you already have the latest version".
                                        I would really like to start experimenting with OSMF.
                                        Gregg
                                        • 17. Re: DRM, NetGroup, SystemUpdater classes cannot be found (cont. - Flash CS4)
                                          One more note - as far as playglobalr.swc see:
                                          http://forums.adobe.com/thread/423432
                                          I tried once more to reinstall everything, and even contacted rblank.com,
                                          still no resolution.
                                          A little frustrating because this framework seems so promising and is just what I am looking for.
                                          If any one has any further ideas, please reply.
                                          Gregg
                                          • 18. Re: DRM, NetGroup, SystemUpdater classes cannot be found (cont. - Flash CS4)
                                            On updating to Flash CS5 the DRM problem disappeared.
                                            Now the work can begin.
                                            • 19. Re: DRM, NetGroup, SystemUpdater classes cannot be found
                                              flexdeveloper.eu
                                              I've been experiencing similar problems with an identical list of errors. Downloading the Flex 4.1 SDK and compiling against that made the problem go away... though I think it could be helpful to have some basic prerequisites documented on the Strobe Media Playback source download page (i.e FP 10.1 and SDK 4.1 required)
                                              • 20. Re: DRM, NetGroup, SystemUpdater classes cannot be found
                                                gone3d Level 1
                                                I just upgraded to OSMF 1.5 in Flash Builder CS5 using the 4.1 SDK with the  latest production build and got the same errors.  I added the  CONFIG::FLASH_10_1 compile argument and it resolved the problem - but  I'm a little annoyed that by even setting the specific version to 10.1.0  it still required the argument.  Is this something that will be  required in future versions of the OSMF.swc?
