2 Replies Latest reply on Sep 28, 2010 2:20 PM by BKBK
    Consuming webservices using CF8
    amigaNOR
      I recently upgraded to CF8 and I’m not able to consume webservices from my dev edition on my personal PC.
      I have tried making my own simple test webservice, but I’m not able to consume them using CF. (I’m able to consume the ws using .Net or Java, but not from CF itself).
      I always get the following error:
      org.apache.axis.ConfigurationException: org.xml.sax.SAXException: Fatal Error: URI=null Line=40: The string "--" is not permitted within comments.
      This is the code I’m using:
      <cfscript>
      wsargs = structnew();
      wsargs.proxyServer = "proxy";
      wsargs.proxyPort = "8080";
      ws = createObject("webservice","http://ws.fraudlabs.com/zipcodeworldUS_webservice.asmx?wsdl",wsargs);
      </cfscript>
      I know that the WSDL is ok since the WS works in .Net and Java. I also know that I can retrieve the wsdl using
      <cfhttp method="get" url="http://ws.fraudlabs.com/zipcodeworldUS_webservice.asmx?wsdl" result="myRes" proxyserver="proxy" proxyport="8080"/>
      So why do I get the “The string "--" is not permitted within comments.” error?
      I know that
      1. I get the same error for all ws I try to consume from CF, even simple test ws made using CF.
      2. The ws work, because I can consume them using .Net and Java.
      3. CFINVOKE gives me the same error
      Olav, Oslo, Norway
        • 1. Re: Consuming webservices using CF8
          Jo Corless
          Have you tried the other methods of connecting to a webservice?
          For instance by tag
          <cfinvoke
                        webservice="http://ws.fraudlabs.com/zipcodeworldUS_webservice.asmx?wsdl"
                        method="post"
                        returnvariable="httpResponse">
                          <cfinvokeargument name="parameters" value="<xmlToSend>"/>
          </cfinvoke>
          Or by building up the CFHTTP call directly
          <cfhttp
                      method="post"
                      result="httpResponse">
                      <cfhttpparam
                           type="header"
                           name="accept-encoding"
                          value="no-compression"
                      <cfhttpparam
                      type="header"
                      name="SOAPAction"
                      value="http://ws.fraudlabs.com/zipcodeworldUS_webservice"
                              When posting the SOAP body, use the CFHTTPParam type of
                              XML. This does two things: it posts the XML as a the BODY
                              and sets the mime-type to be XML.
                              NOTE: Be sure to Trim() your XML since XML data cannot be
                              parsed with leading whitespace.
                      <cfhttpparam
                          type="xml"
                          value="#trim( orderXML )#"
                  </cfhttp>
          I found fiddling around with all three methods of creating a webservice usually results in one that works
          Regards
          Joanne
          • 2. Re: Consuming webservices using CF8
            BKBK Adobe Community Professional & MVP
            add the line:
            wsargs.refreshWSDL="yes";
