1. Re: Message index has been modified outside DW
MurraySummers Sep 16, 2010 12:58 PM (in response to TCarp)Yeah - it confuses me too!
But I have long since learned to ignore it....
2. Re: Message index has been modified outside DW
Lawrence_Cramer Sep 16, 2010 1:32 PM (in response to TCarp)Here's the reason... If you have index.htm open in Dreamweaver, then you open the template file from which the index file was generated, and you update and save the template file Dreamweaver runs a function in the background that updates the associated files.
So this is a case of the "right hand not knowing what the left is doing" - For your opened file Dreamweaver thinks someone else edited it. Like Murray said - it doesn't make sense, but this is what happens. To be safe, if you are going to edit a template file, first make sure that all the files based on this template have been saved and closed. Then you'll avoid this little foible.
Lawrence Cramer - *Adobe Community Professional*
http://www.Cartweaver.com
Shopping Cart for Adobe Dreamweaver
available in PHP, ColdFusion, and ASPStay updated - http://blog.cartweaver.com
3. Re: Message index has been modified outside DW
MurraySummers Sep 16, 2010 1:38 PM (in response to Lawrence_Cramer)Sorry, Lawrence, but I disagree. DW is at least smart enough not to be fooled by this. There is something else going on that I have never taken the time to diagnose....
4. Re: Message index has been modified outside DW
TCarp Sep 16, 2010 2:31 PM (in response to MurraySummers)As noted before, the problem isn't that big a deal. It's clear the template update impacted the index file (which is open).
Let me know if you want further data.
Tom
