3 Replies Latest reply: Sep 21, 2010 12:47 PM by T_Townrampage RSS
    Need to randomize MP3 player
    T_Townrampage Community Member
      Hello guys.
      I have a simple mp3 player in AS2 and I need a way to randomize the songs.
      Here is my AS2 code.
      __________________________________________________________________________________________ ____________________________________
      var s:Sound = new Sound();
      s.onSoundComplete = playTracks;
      s.setVolume(75);
      var sa:Array = new Array();
      var cps:Number = -1;
      var pos:Number;
      ////load the xml data for the mp3 tracks
      var xml:XML = new XML();
      xml.ignoreWhite = true;
      xml.onLoad = function()
          var nodes:Array = this.firstChild.childNodes;
          for(var i=0;i<nodes.length;i++)
              sa.push(new list(nodes[i].attributes.url, nodes[i].attributes.artist, nodes[i].attributes.track));
          playTracks();
      /////your xml file is called here, if you change the name of your xml file also change it here
      xml.load("tracks.xml");
      ///function for playing your tracks, note that the volume is currently set to 75, 100 =max, 0=mute
      function playTracks():Void
          s = new Sound();
          s.setVolume(75);
          mute.gotoAndStop("on");
          if(cps == sa.length - 1)
              cps = 0;
              s.loadSound(sa[cps].earl, true);
          else
              s.loadSound(sa[++cps].earl, true);
          info.info2.trackInfo.text = sa[cps].track + " " ;
          info.info2.trackInfo2.text = sa[cps].artist + " " ;
          onOff.gotoAndStop("pause");
          textPos = 0;
      ///function for playing the previous track
      function playPrevious():Void
         s = new Sound();
         s.setVolume(75);
         if(cps == 0)
            cps = sa.length-1;
         else
            s.loadSound(sa[--cps].earl, true);
      ///function  pauses the music
      function musicOff():Void
          pos = s.position;
          s.stop();
      ///function for continuing play
      function musicOn():Void
          s.start(pos/1000);
      /////this determines rollover states depending on what position the on/off toggle is in,
      //currently I'm not using rollover states for my buttons, but you can add them if you like.
      onOff.onRollOver = function()
          if(this._currentframe == 1) this.gotoAndStop("pauseOver");
          else this.gotoAndStop("playOver");
      /////this determines the postion of the pause/play toggle
      onOff.onRollOut = onOff.onReleaseOutside = function()
          if(this._currentframe == 10) this.gotoAndStop("pause");
          else this.gotoAndStop("play");
      ////on release of the pause/play toggle this determines wether to pause or resume play
      onOff.onRelease = function()
              this._parent.musicOff();
          alphaTween = new mx.transitions.Tween (equ, "_alpha",
          mx.transitions.easing.Regular.easeOut, 100, 0, 0.75,
          true);
          else
              this._parent.musicOn();
          mx.transitions.easing.Regular.easeOut, 0, 100, 0.75,
          true);
      ////rollover states for the next button, again I'm not using any
      next.onRollOver = function()
          this.gotoAndStop("nextOver");
      next.onRollOut = next.onReleaseOutside = function()
          this.gotoAndStop("next");
      ///this determines wether the equalizer has an alpha of 0, if it does the equalizer will return to 100%
      ///when the next button is pressed
      next.onRelease = function()
          this._parent.playTracks();
              if(equ._alpha == 0)
          mx.transitions.easing.Regular.easeOut, 0, 100, 2,
          true);
          else
      ///when the prev button is pressed
      prev.onRelease = function() {
           playPrevious();
                   if(equ._alpha == 0)
          true);
          else
      Thanks for any help!!
