3 Replies Latest reply on Nov 9, 2007 12:03 AM by AGsMM
    command line build problem
    TheMarcus7 Level 1
      We have a large help project I'm migrating to RoboHelp 6 (nearly 3000 topics, 12 chms plus a master file). We generate using a script that calls the command-line option. One of the projects fails during command line processing, even though I can build it from within the GUI without fail. When I run the command line command, this is the message that is returned:
      "D:\quartus\robohelp\subs\reference>"d:\Adobe\RoboHelp 6.0\RoboHTML\RHCL.exe" reference.xpj
      Adobe (R) RoboHelp Project Command Line Compiler version 6.00.099
      Copyright (C) 2006 Adobe Macromedia Software LLC. All rights reserved.
      Project: D:\quartus\robohelp\subs\reference\reference.xpj
      Layout: Microsoft HTML Help.
      Output: D:\quartus\robohelp\reference.chm.
      Scanning project for compilation....
      Error: Failed to scan all the project files. Please use RoboHelp to recover the project.
      Unexpected Error: Failed to prepare single source data for RHCL. Please try to compile it in RoboHTML."
      If I open the project in the GUI and compile it, then compile from the command line, it works fine. But if I clear the directory, run the NGCMD.exe command and get the files out and run the RHCL.exe, I get the same error message.
