2 Replies Latest reply on Sep 28, 2010 9:46 AM by zeroskillz
    create buttons in a datagrid with AS3
    Rale-Kay
      i´m developing an AIR-app. So far i have finished the datagrid (filled by a database) with a search funktion and some other things. Everything is made in Flash with AS3. Now i want some buttons in the last column of the dg but without using flex. I found some tutorials in the net but they are all with flex tags which i don´t understand and i don´t want to rebuild my app completely. Does anyone know a tutorial for Flash and AS3?
      regards
      Rale
        • 1. Re: create buttons in a datagrid with AS3
          Rale-Kay Level 1
          Does noone has an idea or a tip for me?
          • 2. Re: create buttons in a datagrid with AS3
            zeroskillz Level 3
            Sure, here's what I found a while back for CheckBoxes...I edited it for Buttons.
            Overview
            Make sure you have a button in the document library.
            You need to create a cutom cell rederer class to make the grid cells with buttons in them.
            You then need to add a column to your grid which uses the custom renderer.
            Custom Renderer Class
            Copy this into a new ActionScript file. Save it as ButtonCell.as in the same directory as your .fla file.
            package
                import fl.controls.Button;
                import fl.controls.listClasses.ICellRenderer;
                import fl.controls.listClasses.ListData;
                import flash.events.Event;
                import flash.events.MouseEvent;
                public class ButtonCell extends Button implements ICellRenderer
                    private var _listData:ListData;
                    private var _data:Object;
                    public function ButtonCell()
                        super();
                        addEventListener(MouseEvent.CLICK, onButtonClick);
                    public function set data(d:Object):void
                        _data = d;
                    public function get data():Object
                        return _data;
                    public function get listData():ListData
                        return _listData;
                    public function set listData(value:ListData):void
                        _listData = value;
                    override public function get selected():Boolean
                        return _selected;
                    override public function set selected(value:Boolean):void
                    public function onButtonClick(event:MouseEvent)
                        // do something
            In your .fla file make sure you have the imports:
            import fl.controls.DataGrid;
            import fl.controls.dataGridClasses.DataGridColumn;
            import fl.controls.listClasses.CellRenderer;
            import ButtonCell;
            Then, in your .fla file use this to create the column (where 'myDataGrid' is the name of your dataGrid instance):
            var btnCol:DataGridColumn = new DataGridColumn("buttonColumnTitle");
            btnCol.cellRenderer = ButtonCell;
            btnCol.editable = false;
            myDataGrid.addColumn(btnCol);
            To set the button label, just set the text like you would any other dataGrid cell:
            myDataGrid.addItem({buttonColumnTitle:"Button Label"})
            HTH!
            -Ted
