2 Replies Latest reply on Sep 17, 2010 6:42 AM by Anton Pierhagen
    Dynamic parameters in addEventListener method
    Anton Pierhagen
      Hi all,
      I've got an question. I would like to make dynamic parameters for the method addEventListener. Like the example below
      var temp:String = "class.method";
      schermObject.addEventListener(MouseEvent.CLICK, temp);
      But this do not work.
      It needs a function Object. But i hadn't figure out how to make a dynamic function object with the
      correct method in it.
      so....
      Does anybody knows how to pull this off?
      kind regards,
      Anton Pierhagen
        • 1. Re: Dynamic parameters in addEventListener method
          BhaskerChari Level 4
          Hi Anton Pierhagen,
          There is no direct way for doing this , but there is nice work aorund for this as shown below:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="init()">
          <mx:Script>
          <![CDATA[
            private function init():void
             schermObjectBtn.addEventListener(MouseEvent.CLICK, function (event:MouseEvent):void{
                         callAnotherFunction(event,temp);
            private function callAnotherFunction(event:MouseEvent, temp:String):void
          </mx:Script>
          <mx:Button id="schermObjectBtn" label="Click ME"/>
          </mx:Application>
          If this post answers your question or helps, please kindly mark it as such.
          Bhasker Chari
          • 2. Re: Dynamic parameters in addEventListener method
            Anton Pierhagen Level 1
            And how do you call in that function the function of the temp variable?
                     temp ?
