0 Replies Latest reply on Sep 17, 2010 9:17 AM by DavideBarranca
    CSXSInterface and embedded JSX
    DavideBarranca
      Hello,
      I know, from the Zak Nelson cookbook, how to embed and then call a jsx:
      [ Embed (source= "myScript.jsx" , mimeType= "application/octet-stream" )]
      private static var myScriptClass:Class;
      var jsxInterface:HostObject = HostObject.getRoot(HostObject.extensions[0]);
      jsxInterface.eval( new myScriptClass().toString());
      I've used this method in a Photoshop CS5 extension, that I have to port to CS4 - so I need to use the old way:
      CSXSInterface.instance.evalScript("myFunction", "myParameter");
      which work for functions inside a jsx exactly named as the swf panel. (see the Photoshop panel developer's guide)
      I'd rather like to embed several JSX:
      Embed (source= "myScript2.jsx" , mimeType= "application/octet-stream" )]
      private static var myScriptClass2:Class;
      and then call functions in them via CSXSInterface.
      I've tried something like:
      myScriptClass.CSXSInterface.instance.evalScript("myFunction", "myParameter");
      without any luck.
      What's the correct syntax for such call? (if there's one...)
      Thanks in advance,
      Davide
