4 Replies Latest reply on Sep 4, 2009 2:50 PM by r_josh4u
    Error #2032: Stream Error
    rc1981
      I have recently purchased the FlexBuilder2 and am developing an ASP.NET web application application which uses a flex application.
      My Flex application is using XML as the data source. The XML file is supposed to be loaded from a web location ("https"). The Flex application loads all the data correctly when I launch it in Firefox, but it gives the following error when I try to load it in IE6:
      event = flash.events.IOErrorEvent (@4e835b1)
      bubbles = false
      cancelable = false
      currentTarget = flash.net.URLLoader (@4b268b1)
      eventPhase = 2
      target = flash.net.URLLoader (@4b268b1)
      text = "Error #2032: Stream Error. URL: https://xyz.com/flex_data/standardfrontier.xml"
      type = "ioError"
      I am using FlexBuilder2 IDE to develop and run the Flex application.
      I am not sure why is this happening. I have tried setting the content expiration property in my webserver (IIS) which holds the XML file, to expire immidiately, but still no good.
      It works properly with FireFox, but, I need this application to load properly in IE6 as well.
      Any help will be highly appreciated.
      Thanks in Anticipation,
      Rahul
