1 Reply Latest reply on Sep 24, 2010 12:22 AM by Rajesh Yadav @ Tcs
    itemrenderer's control (combobox) data change from main app
    FlexPrashant Level 1
      Hi I have a reset button on my main app . and this app has a datagrid which is using a item
      renderer and inside this IR  i have a combo box control , Now user is selecting something in combo that is showing on Combo means combo box selected index change is working .
      Now I have a button in this app , now I want to reset all the values of form  .. so these all comboboxs should reset to their prompt ..
      I am not getting how to update the ItemRenderer ..
      here is the code
      <?xml version="1.0" encoding="utf-8" ?>
      <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" horizontalScrollPolicy="off">
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.collections.*;
      import flash.events.Event;
      import mx.controls.DataGrid;
      override public function set data(value:Object):void
      if(value != null)
      super.data = value;
      var colorLength:int = value.color.length;
      //show the comboBox
      if(colorLength > 1)
      colorChoices.visible=
      true;
      colorLabel.visible=
      false;
      //hide the comboBox and show the label
      else
      false;
      colorLabel.visible=
      true;
      colorChoices.selectedItem=data.selectedColor;
      public function changeHandler(event:Event): void
      data.selectedColor=String(colorChoices.selectedItem);
      IList(DataGrid(owner).dataProvider).itemUpdated(colorChoices.selectedItem);
      </mx:Script>
      <mx:ComboBox id="colorChoices" dataProvider="{data.color}" width="100%"
      change="changeHandler(event)" prompt="
      -select-"/>
      <mx:Label id="colorLabel" text="{colorChoices.selectedItem}" x="5" />
      </mx:Canvas>
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
      backgroundGradientColors="
      [0x990000, 0xffccff]"
      layout="
      vertical">
      <mx:Script>
      <![CDATA[
      import mx.collections.ItemResponder;
      import mx.controls.ComboBox;
      import mx.events.DataGridEvent;
      Bindable]
      private var musicPlayers:Array = [
      {product:
      "Z450", color: ['blue', 'pink', 'silver'], memory: "8 GB", selectedColor: 'blue'},
      {product:
      "ZR50", color: ['blue', 'pink', 'silver'], memory: "80 GB", selectedColor: 'black'},
      {product:
      "ZR250", color: ['blue', 'pink', 'silver'], memory: "120 GB", selectedColor: 'silver'},
      {product:
      "ZM10", color: ['blue', 'pink', 'silver'], memory: "4 GB", selectedColor: 'silver'},
      {product:
      "Z150", color: ['blue', 'pink', 'silver'], memory: "1 GB", selectedColor: 'yellow'},
      {product:
      "ZM450", color: ['blue', 'pink', 'silver'], memory: "30 GB", selectedColor: 'white'}
      protected function button1_clickHandler(event:MouseEvent):void
      // TODO Auto-generated method stub
      </mx:Script>
      <mx:DataGrid id="dg" dataProvider="{musicPlayers}" rollOverColor="0xCCCCCC">
      <mx:columns>
      <mx:DataGridColumn dataField="product" headerText="Product" width="100" />
      <mx:DataGridColumn dataField="color" headerText="Available Colors"
      id="
      dgcol" itemRenderer="DynRenderer" width="130" />
      <mx:DataGridColumn dataField="memory" headerText="Memory" width="80" />
      <mx:DataGridColumn dataField="selectedColor" headerText="Selected Color" width="120" />
      </mx:columns>
      </mx:DataGrid>
      <mx:HBox width="100%" >
      <mx:Spacer width="25%" />
      <mx:Button label="reset" click="button1_clickHandler(event)" />
      </mx:HBox>
      </mx:Application>
        • 1. Re: itemrenderer's control (combobox) data change from main app
          Rajesh Yadav @ Tcs Level 1
          Try this...
          <mx:Application
          layout="
          vertical" >
          <mx:Script>
          <![CDATA[
          import examples.DynamicData;
          import test.DynRenderer;
          import mx.collections.ArrayCollection;
          Bindable]
          private var musicPlayers:ArrayCollection = new ArrayCollection([{product:
          "Z450", color: ['blue', 'pink', 'silver'], memory: "8 GB", selectedColor: 'blue'}, {product:
          "ZR50", color: ['blue', 'pink', 'silver'], memory: "80 GB", selectedColor: 'black'}, {product:
          "ZR250", color: ['blue', 'pink', 'silver'], memory: "120 GB", selectedColor: 'silver'}, {product:
          "ZM10", color: ['blue', 'pink', 'silver'], memory: "4 GB", selectedColor: 'silver'}, {product:
          "Z150", color: ['blue', 'pink', 'silver'], memory: "1 GB", selectedColor: 'yellow'}, {product:
          for (var i:int=0; i < dg.dataProvider.length;i++)
          musicPlayers[i].selectedColor =
          "--Select--"
          musicPlayers.refresh();
          </mx:Script>
          dataProvider="
          {musicPlayers}"
          rollOverColor="
          0xCCCCCC">
          <mx:columns>
          headerText="
          Product"
          width="
          100"/>
          headerText="
          Available Colors"
          id="
          dgcol"
          itemRenderer="
          test.DynRenderer"
          width="
          130"/>
          headerText="
          Memory"
          width="
          80"/>
          headerText="
          Selected Color"
          width="
          120"/>
          </mx:columns>
          </mx:DataGrid>
          <mx:HBox width="100%">
          <mx:Spacer width="25%"/>
          <mx:Button label="reset" click="button1_clickHandler(event)"/>
          </mx:HBox>
          </mx:Application>
