• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Configure PHP Service
New Here ,
Sep 17, 2010 Sep 17, 2010
I tried to configure PHP to access a mySQL DB. After installing the Zend Framework (on a QNAP 659 device) I had to update php.ini to find the path. Now I get one step further, but the message above message appears.
I am using FlashBuilder 4 and used the wizard "Connect to Data/Service...".
The php looks like:
<?php
class EmployeeService {
    public function getEmployees() {
        $connection = mysqli_connect ("localhost", "root", "root", "test", 8888) or die(mysqli_connect_error());
        $sql = "SELECT * FROM employees";
        $result = mysqli_query ($connection, $sql) or die('Query failed: ' . mysqli_error($connection));
        $rows = array();
        while ($row = mysqli_fetch_object ($result)) {
            $rows[] = $row;
        return $rows;
The SQL-DB is accessable via phpMyAdmin. All seems to look fine.
Can someone give me a hint where to search?
Thanks Wolfram
Views
402
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Sep 28, 2010 Sep 28, 2010
LATEST
Did you check the amf_config.ini file?  It says to set the production value to false instead of true.  There is also a zend_path setting in there, make sure that is pointing to the library folder inside your Zend folder.
Votes
Translate
Translate
Report
Report
