1 Reply Latest reply on Jul 23, 2007 3:31 PM by Newsgroup_User
    RemoteObject failure to connect error
    TooManyNicknames
      I'm getting a "Couldn't establish a connection to 'javaWeatherInfo'" when trying to access a remote object with a destination ID of 'javaWeatherInfo'. The destination is defined in remoting-config.xml and associated class is in the WEB-INF/classes directory. I'm using Tomcat as a server. Anyone know what causes this error?
        • 1. Re: RemoteObject failure to connect error
          Level 7
          Many things could be the cause...
          1. If you're not programmatically creating your own ChannelSets, did you
          provide a -services command line argument pointing to the /WEB-INF/flex/services-config.xml
          file when compiling your Flex application?
          2. Are you sure that the hostname and port used to load the SWF are the same
          as the channel endpoint URLs? If they are not the same, do you have a crossdomain.xml
          policy file setup in the webroot?
          3. Did you check the server logs to see whether there were any configuration
          failures reported on server startup?
