0 Replies Latest reply on Sep 17, 2010 8:10 PM by vunnikri
    Excellent Way to Color Code Datagrid Rows!
    vunnikri
      I searched for a long time to find the method to color code datagrid rows based on row parameters. Found it, and thought i should share for the not so lucky ppl.
      So, here goes.
      STEP 1: Create your custom component.
      package it.RowColorDataGrid
      import flash.display.Sprite;
      import mx.collections.ArrayCollection;
      import mx.controls.DataGrid;
      public class RowColorDataGrid extends DataGrid
      public var rowColorFunction:Function;
      override protected function drawRowBackground(s:Sprite,
      rowIndex:int, y:Number, height:Number, color:uint, dataIndex:int):void
      if(rowColorFunction != null && dataProvider != null)
      var item:Object;
      if(dataIndex < dataProvider.length)
      item = dataProvider[dataIndex];
      if(item)
      color = rowColorFunction(item, rowIndex, dataIndex, color);
      super.drawRowBackground(s, rowIndex, y, height, color, dataIndex);
      STEP 2: Use the component in your UI.
      mx:Panel xmlns:mx="http://www.adobe.com/2006/mxml" width="100%" height="100%"
      xmlns:local="it.RowColorDataGrid.*" horizontalAlign="center" verticalAlign="middle" currentState="Initializing"
      creationComplete="controller.init(this)" xmlns:mate="http://mate.asfusion.com/">
      local:RowColorDataGrid id="recoverytbl" dataProvider="{parentApplication.model.requestlist}"
      rowColorFunction="calcRowColor" >
      <local:columns>
      <mx:DataGridColumn headerText="Recovery" dataField="name" />
      <mx:DataGridColumn headerText="Status" dataField="status" />
      </local:columns>
      </local:RowColorDataGrid>
      STEP 3: Function to set the color codes.
      private function calcRowColor(item:Object, rowIndex:int, dataIndex:int, color:uint):uint
      if(item.status == 'COMPLETED')
      return 0x49FFAD;
      else
      if(item.status == 'PAUSED')
      return 0xFFFF00;
      else
      if(item.status == 'ABORTED')
      return 0xAB82FF;
      else
      if(item.status == 'ERROR')
      return 0xFF3030;
      else
      return color;
