2 Replies Latest reply on Sep 20, 2010 3:59 AM by aditi_bk
    Buttons not accessible
    aditi_bk Level 1
      I have several buttons within a flash file. The hierarchy is this:
      mainmcholder ----> workmc ---> service1mc
      All three are separate swf's loaded into holders. Now within service1mc, there are several buttons..clicking any buttons loads another external swf, related to that button, within an emtpy movieclip which is placed above these buttons. Now when one button is clicked, all the buttons are disabled and dimmed. When the user closes the external button-related swf, all buttons are enabled and _alpha is made 100 again.
      Everything works fine till the external button-related swf is closed. The buttons are disabled and dimmed, but when the swf is closed, the buttons are inaccessible.
      I have placed the code within onLoadInit(), wherein the external swf (_mc), has an event listener attached to it. When the event is dispatched, (which is successfully completed), a function is executed, which is enabling the buttons. The function is also getting executed, but the buttons are not reachable. It seems to be a path issue.
      The code is :
      _mc.addEventListener("end", endClip);
      function endClip() {
      trace("in function endclip");
      var j:Number = 1;
      while (j<=23) {
      this._parent.folioholdermc["img"+j]._alpha = 100;
      trace("img"+j + " alpha " + this.folioholdermc["img"+j]._alpha);
      this._parent.folioholdermc["img"+j].enabled = false;
      j++;
      trace("img"+j+" fixed");
      the output shows
      img1 alpha undefined
      img2 alpha undefined
      and so on...
      I have used the same path for disabling them, and that seems to work. What could be wrong???
        • 1. Re: Buttons not accessible
          It is probably just a targeting issue.  Between these two lines of code you are trying to target the same things using different paths, so I imagine one or both of them is incorrect...
          Try tracing this._parent and so forth along the lineup to see where you are losing the trail.
          • 2. Re: Buttons not accessible
            aditi_bk Level 1
            Hi Ned,
            I checked, and I am calling the same buttons, twice in the code. The first time I do that, using the path
            this._parent.folioholdermc["img"+i]._alpha = 20;            it works. And the alpha is set to 20.
            But when I call the button using the same path the second time, it does not work.
            The reason you see two paths, was because I was testing different variations for the second call. The entire code is given below
            on (press) {
            var scrX2:Number = System.capabilities.screenResolutionX;
            var scrY2:Number = 598;
            var i:Number = 1;
            var intrvl1;
            while (i<=23) {
            trace("img"+i + " alpha " + this._parent.folioholdermc["img"+i]._alpha);      //works fine here
            this._parent.folioholdermc["img"+i].enabled = false;
            i++;
            var loader:MovieClipLoader = new MovieClipLoader();
            var ldrlistener = new Object();
            loader.addListener(ldrlistener);
            ldrlistener.onLoadInit = function(_mc:MovieClip) {
            var halfx:Number = (_mc._width)/2;
            var halfy:Number = _mc._height/2;
            trace("half y = "+halfy);
            trace("img height = "+_mc._height);
            _mc._x = (scrX2/2)-halfx;
            _mc._y = (scrY2/2)-halfy;
            trace("x "+_mc._x);
            // _root.folioholder.imgholder._mc.crossbtn.addEventListener("end",endClip);
            var j:Number = 1;
            while (j<=23) {
            this._parent.folioholdermc["img"+j]._alpha = 100;               //does not access the button here
            trace("img"+j + " alpha " + this._parent.folioholdermc["img"+j]._alpha);  //says img[j] alpha undefined
            j++;
            function goWork(_mc:MovieClip) {
            _mc.unloadMovie();
            ldrlistener.onLoadProgress = function(_mc:MovieClip, loaded:Number, total:Number) {
            // code here
            loader.loadClip("Portfolio/swfdesc/architecture_1/img1desc.swf",imgholder);
            So I know that this._parent.folioholder...path works fine, but only once. I cannot understand what is happening here. Any help will be greatly appreciated.
