This content has been marked as final.
Show 26 replies
1. Re: XML and AS2.0
kglad Jul 24, 2007 2:07 PM (in response to shurleynova)you only need to 3 variable/value pairs to load into flash? if so, the following is all your need. just remember to convert each variable's value to a number for use in flash.
2. Re: XML and AS2.0
shurleynova Jul 24, 2007 2:11 PM (in response to shurleynova)Man that was so easy I almost feel retarded. Thank you I was making it way to hard I am kinda new at XML and the make your own <tags> kinda throws me sometimes. I think I need to go get a good XML book any suggestions? -
3. Re: XML and AS2.0
Newsgroup_User Jul 24, 2007 2:14 PM (in response to shurleynova)Hi shurleynova,
XML is pretty versatile; you should be able to get it do do whatever
you want. With AS2.0, it's also very loose so you can get away with poor
formatting.
Let me suggest a format like this to begin with:
<timeline>
<point x="20" y="30" z="15"/>
<point x="10" y="30" z="35"/>
<point x="60" y="10" z="2"/>
<point x="80" y="5" z="4"/>
</timeline>
This format is actually proper and easy to work with in Flash. Many
people would parse this data into multi-dimensional arrays but this is
automatically done by Flash. If you save this to a file named
"timeline.xml", your script would look something like this:
var timelineXML=new XML();
timelineXML._context=this;
timelineXML.ignoreWhite=true;
timelineXML.onLoad=function(success:Boolean) {
trace ('Data loaded: '+success);
this._context.parseXMLData(this.firstChild);
}//onLoad
function parseXMLData(data:XMLNode) {
for (var count:Number=0;count<data.childNodes.length;count++) {
var currentNode:XMLNode=data.childNodes[count];
var xValue:Number=Number(currentNode.attributes.x);
var yValue:Number=Number(currentNode.attributes.y);
var zValue:Number=Number(currentNode.attributes.z);
trace ('x='+xValue);
trace ('y='+xValue);
trace ('z='+xValue);
}//for
}//parseXMLData
timelineXML.load('timeline.xml');
If you wanted to access a specific node in the list once the data is
loaded, a simple function like this does the trick:
function getPointNode(index:Number):XMLNode {
return (timelineXML.firstChild.childNodes[index]);
}//getPointNode
As you can see, XML is parsed into an associative array so dealing with
it in memory is very straightforward. If you wanted to get the "x" value
from node 1 (index 0), you would call:
var myXValue=getPointNode(0).attributes.x;
Just keep in mind that all attributes are text so if you want to work
with them as numbers, convert them first.
And there you go!
Patrick
shurleynova wrote:
> OK I have been going down one road for this and have taken a few wrong turns.
> A few things about what we are looking at:
> I am using Flash CS3 but I am using Action Script 1.0/2.0 for compatability
> purposes.
> What I have been able to do so far is create random instances of a movie clip
> to appear over a set amount of time but I need to go a bit further. The web
> application needs to be updated regularly and the best way I can think of doing
> that is with keeping all the variables in an XML. The problem is I am not sure
> how to format the XML properly to get Flash to read it and load the variables.
> I am creating an online version of a vision screening tool we use. The test is
> graphically simple just a collection of a few primitives on a dark background.
> There are basically two objects a fixation point and a stimulus. What I need to
> be able to do is this.
> Display either movieclip at (x,y) for (z)ms where x,y,& z are all variables
> loaded from an xml. I have asked questions along this line before but this is a
> different scope in case anyone wants to claim I double posted, this is quite
> different than they way I was doing it before.
> Any help with the XML or even any actionscript suggestions would be greatly
> appreciated.
> Thanks
http://www.baynewmedia.com
Faster, easier, better...ActionScript development taken to new heights.
Download the BNMAPI today. You'll wonder how you ever did without it!
Available for ActionScript 2.0/3.0. -
4. Re: XML and AS2.0
Newsgroup_User Jul 24, 2007 2:16 PM (in response to shurleynova)I wouldn't waste money on an XML book. The format is open by
specification, meaning you can do with it what you like. It's better if
you do some experiments to see how nodes and attributes are accessed in
Flash, then you make up any XML formats you want. That's the beauty of
XML, it's eXtensible.
Patrick
5. Re: XML and AS2.0
Damon Edwards Jul 24, 2007 2:17 PM (in response to shurleynova)I bought "Foundation XML for Flash" a long time ago when I was starting out.. It helped a great deal. -
6. Re: XML and AS2.0
shurleynova Jul 24, 2007 2:44 PM (in response to kglad)What if I had several variables for each such as I had 4 different movieclips, each had to display for only 200ms, and there were 10 possible x and 10 possible y coordinates for each would I format it like this?
Then in my actionscript just have it load the next variable from the list? I think this is where I am stuck.
7. Re: XML and AS2.0
shurleynova Jul 24, 2007 2:45 PM (in response to shurleynova)Oh I didnt see that post from Patrick B when I posted that last one I think that migth be what I needed to know, thanks all I'll be back if I still get stuck. -
8. Re: XML and AS2.0
shurleynova Jul 25, 2007 7:59 AM (in response to shurleynova)Ok I have it I created an xml using the example from Patrick B and I can see in the Output window that the variables are loaded correctly. The XML and AS is formatted like the code attached I get an out put that looks like this:
Data loaded: true
object_type=stimuli
x_coordinates=25
y_coordinates=25
z_display_interval=200
object_type=stimuli
x_coordinates=85
y_coordinates=175
object_type=stimuli
x_coordinates=325
y_coordinates=55
object_type=stimuli
x_coordinates=115
y_coordinates=355
object_type=fixation
x_coordinates=289
y_coordinates=229
Thanks to all now I have to figure out how I am going to use the variables to display my clips :)
9. Re: XML and AS2.0
Newsgroup_User Jul 25, 2007 9:15 AM (in response to shurleynova)That's the way we do ;) Good luck!
> Data loaded: true
> object_type=stimuli
> x_coordinates=25
> y_coordinates=25
> object_type=stimuli
> x_coordinates=85
> y_coordinates=175
> object_type=stimuli
> x_coordinates=325
> y_coordinates=55
> object_type=stimuli
> x_coordinates=115
> y_coordinates=355
> x_coordinates=289
> y_coordinates=229
> display my clips :)
> <?xml version="1.0"?>
> <!-- Where omc is the object to display xp is x position, yp is y position,
> zms is display interval -->
> <timeline>
> <point omc="stimuli" xp="25" yp="25" zms="200"/>
> <point omc="stimuli" xp="85" yp="175" zms="200"/>
> <point omc="stimuli" xp="325" yp="55" zms="200"/>
> <point omc="stimuli" xp="115" yp="355" zms="200"/>
> <point omc="fixation" xp="289" yp="229" zms="200"/>
> </timeline>
> // Then the actionScript in Flash looks like this
> }//onLoad
> var oValue:String=String(currentNode.attributes.omc);
> var xValue:Number=Number(currentNode.attributes.xp);
> var yValue:Number=Number(currentNode.attributes.yp);
> var zValue:Number=Number(currentNode.attributes.zms);
> trace ('object_type='+oValue);
> trace ('x_coordinates='+xValue);
> trace ('y_coordinates='+yValue);
> trace ('z_display_interval='+zValue);
> }//for
> }//parseXMLData
> timelineXML.load('input.xml');
10. Re: XML and AS2.0
shurleynova Jul 25, 2007 11:08 AM (in response to shurleynova)One quick question that has me confused however
It is awesome that I now have the variables in Flash from the XML but...
I am familiar with attaching variables to dynamic text by adding the variable in the properties box but how do I assign the variable to a movieClip? -
11. Re: XML and AS2.0
Newsgroup_User Jul 25, 2007 12:11 PM (in response to shurleynova)Hi again,
I *think* what you're asking is, how do you place a variable inside a clip?
It's simply: clipInstanceName.variableName=value;
For example, say your clip instance is named "magicSquare" and the
variable is "myVar":
magicSquare.myVar=123;
-or-
magicSquare['myVar']=123;
Is this what you're asking?
12. Re: XML and AS2.0
shurleynova Jul 25, 2007 1:09 PM (in response to shurleynova)sort of
the variables contain the x,y coordinates and the name of the movieClip instance as well as a value for a timer event. The last one is not the most important so lets just leave that out for the moment.
I was trying to state it with a with statement as in:
with(oValue){
_x=xValue
_y=yValue
but that is when I get the error that the object does not exist. Do I need to add some actionscript to my movieClip to make it work? Or is there another way to do it? Do I need to add an event to the clip itself I guess is what I am asking or do I need to attach the code that makes the clip appear the clip itself?
I did already make sure that the clips were exported for Actionscript but that didnt seem to make a difference -
13. Re: XML and AS2.0
Newsgroup_User Jul 25, 2007 1:15 PM (in response to shurleynova)Hi again,
I'm still a little fuzzy on what you're trying to do. Are you trying to
set the X and Y position of the clip? What is ovalue, or rather, what do
you want it to be? When you trace (ovalue), what do you get? What about
trace (typeof(ovalue))?
Patrick
shurleynova wrote:
> sort of
> with(oValue){
> _x=xValue
> _y=yValue
> itself?
14. Re: XML and AS2.0
shurleynova Jul 25, 2007 1:49 PM (in response to Newsgroup_User)Hello again,
"Are you trying to
trace (typeof(ovalue))?"
I am tracing the oValue and yes I am trying to set the x,y of the clip. The oValue is a variable that is either one of two things "stimuli" or "fixation" and when I trace it that is what is says in the output window. What the oValue is meant to represent is an instance name. but even something as simple as setProperty does not recognize the variable in place of the clip's instance name. So here I am thinking that it may not be possible to pass a variable to call an instance name but it doesn't make sense, because in theory I figure it should work.
thnx a million - your solutions have been the most helpful thus far. -
15. Re: XML and AS2.0
Newsgroup_User Jul 25, 2007 2:19 PM (in response to Newsgroup_User)Okay, so "stimuli" and "fixation" are clips, right? You should be able
to simply set:
this[ovalue]._x=xValue;
this[ovalue]._y=yValue;
The only issue that you may encounter is, is "this" the object that
holds the clip. When you trace (this[ovalue]), what do you get? It
should show you a movie clip instance. If not, you need to figure out
where your clips actually are. When you trace (this)...what do you get?
This should give you a clue as to why your clip(s) aren't being targetted.
Patrick
shurleynova wrote:
> Hello again,
> "Are you trying to
> should work.
16. Re: XML and AS2.0
shurleynova Jul 25, 2007 2:20 PM (in response to shurleynova)Maybe this makes more sense
if I have the following action script on a movieclip
onClipEvent (enterFrame) {
setProperty(_root.stimuli,_x,55);
setProperty(_root.stimuli,_y,115);
The instance "stimuli" appears at 55,115 on my stage
what I want to do is replace the instance name, the x and y coodinates with the variables that I loaded from the XML.
for some reason I thought it would be as simple as
setProperty(oValue,_x,xValue);
setProperty(oValue,_y,yValue);
but that, while not giving me an error , does nothing I can still see the clip sitting in the position I placed it in to start.
So my thought is my error is in the syntax of the script. -
17. Re: XML and AS2.0
Newsgroup_User Jul 25, 2007 2:24 PM (in response to shurleynova)Your notation is a bit archaic but we can work with it :)
setProperty(_root[oValue],_x,xValue);
setProperty(_root[oValue],_y,yValue);
Better still:
_root[oValue]._x=xValue;
_root[oValue]._y=yValue;
Just make sure xValue and yValue exist and are numbers and you should be
okay. How does that work out?
Patrick
18. Re: XML and AS2.0
Newsgroup_User Jul 25, 2007 2:26 PM (in response to shurleynova)If you put this on the frame within the clip itself (rather than on the
clip), you could use:
this.onEnterFrame=function() {
_root[ovalue]._x=xValue;
_root[ovalue]._y=yValue;
But maybe that's something you can implement when you get the initial
problem fixed.
Patrick
> Better still:
> Patrick
19. Re: XML and AS2.0
shurleynova Jul 25, 2007 2:59 PM (in response to Newsgroup_User)quote:
problem fixed.
Patrick
> Better still:
> Patrick
Ok I know my syntax is a bit rusty but I am slowly learning to appreciate the dot notation as a much easier way to read the code.
so I went ahead and place this code on a movie clip
I checked the output window and the action script to make sure the xValue and yValue were being read as numbers and that it refelcted that in the output I have attached the action script below. Also this is what is in the output window:
Data loaded: true
object_type=stimuli
x_coordinates=25
y_coordinates=25
object_type=stimuli
x_coordinates=85
y_coordinates=175
object_type=stimuli
x_coordinates=325
y_coordinates=55
object_type=stimuli
x_coordinates=115
y_coordinates=355
x_coordinates=289
y_coordinates=229
Maybe I am looking at this wrong and maybe there is one other step I need to include is what I keep thinking but I dont knwo what it is.
20. Re: XML and AS2.0
Newsgroup_User Jul 25, 2007 3:05 PM (in response to Newsgroup_User)Okay, you still need to check what _root[oValue] is:
trace (_root[oValue]);
Is it a movie clip, undefined, string?
shurleynova wrote:
>quote:
> problem fixed.
> Patrick
> > Better still:
> > Patrick
> window:
> Data loaded: true
> object_type=stimuli
> x_coordinates=25
> y_coordinates=25
> object_type=stimuli
> x_coordinates=85
> y_coordinates=175
> object_type=stimuli
> x_coordinates=325
> y_coordinates=55
> object_type=stimuli
> x_coordinates=115
> y_coordinates=355
> x_coordinates=289
> y_coordinates=229
> //onLoad
> //parseXMLData
21. Re: XML and AS2.0
shurleynova Jul 26, 2007 6:19 AM (in response to shurleynova)when I trace using trace (_root[oValue]);
my output is:
Data loaded: true
object_type=stimuli
x_coordinates=25
y_coordinates=25
_level0.stimuli
object_type=stimuli
x_coordinates=85
y_coordinates=175
_level0.stimuli
object_type=stimuli
x_coordinates=325
y_coordinates=55
_level0.stimuli
object_type=stimuli
x_coordinates=115
y_coordinates=355
_level0.stimuli
x_coordinates=289
y_coordinates=229
_level0.fixation
is _level0 and _root the same thing?
because if I add the action to the clip
_level0.stimuli._x=55;
_level0.stimuli._y=55;
or
_root.stimuli._x=55;
_root.stimuli._y=55;
the results are the same the movieclip with the instance name 'stimuli' appears at (x,y) 55,55. So my guess is even though the variables are loaded and the trace shows me they are the onClipEvent doesn't see it that way. Logically the action script
_root.[oValue]._x=55;
_root.[oValue]._y=55;
should have the same effect but it doesn't that is kinda why I am confused. If the variables are loaded and the code works with hardcoded data why does replacing the hard coded information with the variable not work. -
22. Re: XML and AS2.0
shurleynova Jul 26, 2007 6:28 AM (in response to shurleynova)So I guess the short answer to that question is it is a movieclip
the movieclip is named "mc_stimuli" and has an instance name "stimuli" and its path is simply "_root.stimuli" or "_level0.stimuli" which appear to be one in the same. -
23. Re: XML and AS2.0
Newsgroup_User Jul 26, 2007 7:53 AM (in response to shurleynova)Woaw....when your trace _root[ovalue] you get all that? This doesn't
look right at all. If this was a complex object, you should see "[object
Object]", if it's a movie clip you should see "[object MovieClip]" or
the path to the movie clip.
What I'm seeing here looks like many trace statements. Did you remove
the ones from the "for" loop? If you leave all the other ones in there,
what you end up with is meaningless because any one of thos lines may or
may not be what we want to see. We're trying to isolate one value
here...you're showing me everything you're receiving plus some other
data without any context. Get rid of all your trace statements and,
leaving only the one, ....what does trace(_root[ovalue]); show you?
Don't put it in a loop. We want only one line of text. If you get more
than that, check your code again and remove any remaining traces.
> my output is:
> Data loaded: true
> object_type=stimuli
> x_coordinates=25
> y_coordinates=25
> _level0.stimuli
> object_type=stimuli
> x_coordinates=85
> y_coordinates=175
> _level0.stimuli
> object_type=stimuli
> x_coordinates=325
> y_coordinates=55
> _level0.stimuli
> object_type=stimuli
> x_coordinates=115
> y_coordinates=355
> _level0.stimuli
> x_coordinates=289
> y_coordinates=229
> _level0.fixation
> or
24. Re: XML and AS2.0
Newsgroup_User Jul 26, 2007 8:18 AM (in response to shurleynova)Okay...I'm not sure how you came up with that but assuming you're
right...first...are the values you're trying to set numbers? They may
*look* like numbers but if they're strings, the X and Y position won't
be affected.
_root[ovalue]._x=Number(xValue);
_root[ovalue]._y=Number(yValue);
Second, do you still have this?
This continually loops and sets the clip X and Y to 55,115 so get rid of
it. It sounds like you're making a bit of a dog's breakfast of your code
because you're trying to fix things piecemeal.
At this point you may have 2 or 3 things that are working against each
other. I only see the tiny bits of code you are posting here and not
seeing it in context. If you were to ask me what could be causing the
clips not to go to their target position, the answer is literally
"anything". It certainly sounds like you're not sure how to set X and Y
position or how to correctly work with values but how many other
problems do you have in your code that could be causing this? I've seen
one onEnterFrame loop and I've suggested an XML parsing routine that's
out of context (it's very generic and not suited to what you're doing
specifically...whatever that is). I would advise that you either read up
on core Flash concepts like movie clip references, scope, setting
properties, and looping...or you post your code in its entirety so I can
give you a rundown how the pieces fit together. It's very difficult to
work with bits and pieces when other bits and pieces may the crucial
problems.
Feel free to drop me an email if you want and we can continue this off
the forums.
Patrick
> the same.
25. Re: XML and AS2.0
shurleynova Jul 26, 2007 8:23 AM (in response to shurleynova)Ok I see your point, I commented out the other trace statements and only left the following two trace statements
and
and the output file now looks like this:
Data loaded: true
_level0.stimuli
_level0.stimuli
_level0.stimuli
_level0.stimuli
_level0.fixation
so it looks like it is grabbing the right variable from the XML -
26. Re: XML and AS2.0
Newsgroup_User Jul 26, 2007 8:54 AM (in response to shurleynova)Okay, that looks good. So, in this case _root and _level0 are the same
thing (this isn't always the case but here it is).
So, the only two things I can see, as per my previous post, are:
1. Your enterFrame loop is hard-setting the position. Whatever you set
it to outside of this, this loop simply resets it next time the frame
loop hits. So...comment it out or get rid of it.
2. Your X and Y values may not be numbers. You should try something like:
_root[ovalue]=Number(xValue);
_root[ovalue]=Number(yValue);
If they are numbers, no problem. If they're not, this should convert it.
Like I said, this is a 2-inch view of the whole canvas so this is the
best I can do without seeing everything you've written.
Good luck!
Patrick
> and
> Data loaded: true
> _level0.stimuli
> _level0.stimuli
> _level0.stimuli
> _level0.stimuli
> _level0.fixation
