2 Replies Latest reply on Jul 25, 2007 12:14 PM by silent runner
    xml in datagrid instead of a proper result
    silent runner
      Hi
      I'm new to FDS and I have a problem to show my data in my data grid. As you can see below I have a datagrid and a button.When I click on the button I search for every item which contains 'BA' but instead of giving me all the items of my search results, the data grid gives me my search result in a xml-format: <articles><article><number>262</number><description>BALPEN BIC M10 BLAUW</description></article>
      Has anybody have had a similar problem and found a solution?
      Thanks!
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" backgroundColor="#FFFFFF" viewSourceURL="srcview/index.html">
      <mx:WebService id="srv" wsdl=" http://localhost:8080/axis/ArticleService.jws?wsdl" showBusyCursor="true"/>
      <mx:DataGrid dataProvider="{srv.getArticles.lastResult}" width="100%" height="100%">
      <mx:columns>
      <mx:DataGridColumn dataField="article.number" headerText="Article Number"/>
      <mx:DataGridColumn dataField="article.description" headerText="Description"/>
      </mx:columns>
      </mx:DataGrid>
      <mx:Button label="Get Data" click="srv.getArticles('BA')"/>
      </mx:Application>
        • 1. Re: xml in datagrid instead of a proper result
          Level 7
          Note that this issue would be technically unrelated to FDS (now known as
          LCDS - the latest version being LCDS 2.5.1), but rather it concerns WebServices
          and the decoding SOAP into ActionScript objects. That is, FDS is not required
          to use WebServices in Flex (unless you need the proxy service) and FDS does
          not decode the SOAP responses - that is something that the rpc.swc client
          library does from the Flex SDK.
          Depending on the version of Flex that you're using, it may be a bug in the
          <mx:WebService> implementation in the Flex SDK?
          A new <mx:WebService> implementation was provided in the Flex SDK which was
          first made available in LCDS 2.5 which co-incided with Flex SDK 2.0.1 Hotfix
          2, and will be more widely exposed in Flex 3 (which is currently in Beta).
          The latest nightly builds for the Flex SDK 2.0.1 can be found here:
          http://labs.adobe.com/technologies/flex/sdk/flex2sdk.html
          The latest nightly builds for the Flex SDK 3 Beta can be found here:
          http://labs.adobe.com/technologies/flex/sdk/flex3sdk.html
          If you find a problem with WebServices, please log a bug against the Flex
          SDK at the public bug repository:
          http://bugs.adobe.com/flex/
          You can log the bug under the "RPC: WebService" component.
          When logging a WebService bug, it's best to provide the WSDL, any XML Schema
          imports, a snippet of MXML or AS3 code that you used to call an operation
          and process the result (as you did in your post), and ideally a capture of
          the SOAP response as XML.
          Regards,
          Pete
          > Hi
          > Thanks!
          > width="100%"
          > height="100%">
          > <mx:columns>
          > Number"/>
          > </mx:columns>
          > </mx:DataGrid>
          > </mx:Application>
