0 Replies Latest reply on Sep 20, 2010 4:20 AM by DivyaMahendran
    how to create paging in air application
    DivyaMahendran
      hi ,
      I have created an  air application which takes the data from a feed.
      I ve to create paging for my Richtext which wiil hold the description of my image.i took the length of the description from the feed using substring
      using the following code
      var description:String=event.result.rss.channel.item.description;
                      if(description.length > 2000)
                          des1inner.text = description.substring(0,2000);
                      else if(description.length <= 2000)
                              des1inner.text = description;
      i need to display the remaining description using pagination. .can any one give solution for this?????????????
