9 Replies Latest reply on Dec 4, 2015 12:11 AM by Laubender
    Bug or change in CS5 Extendscript Toolkit debugger or parser
    Andreas Jansson Level 2
      I got a strange error beginning to work with a script in CS5 (that is working in CS4, and has a script version setting making it run as CS4).
      This is what happened: Pressing Step into code in ExtendScript Toolkit. The window switches to InDesign CS5. Nothing happens. I switch back to the toolkit environment, and there is the blue circle spinning at the bottom right, but nothing else happens.
      The status row reads: No Errors
      So I press stop, and then the following is written out in the status row (Bottom left of the Extendscript Toolkit CS5):
      Cannot execute
      Execution halted : Adobe InDesign CS5 did not respond
      Trying to debug this error was not easy, since the debugger never entered the code. But at last I found a row containing a comment like this one:
      //var sResult = '<![CDATA[' + a + ']]>';
      Please will someone else put this code in a new script and see if you get the same effect:
      var sResult = 'test';
      alert(sResult);
      The alert box is not showing up.
      You can even minimize the code to this row in a script:
      That single comment in a script makes my debugger hang.
      I hope there are no other secret character combinations that need to be removed for my script to run in CS5... Continuing my tests now.
