1 Reply Latest reply on Sep 20, 2010 9:13 AM by Marc Autret
    Undefined is not an object
    Barqx Level 1
      I have the following extract from my code:
      function foo()
      Dlg.gMain[caption].gPageItems.gPhoto.molgrew = Dlg.gMain[caption].gPageItems.gPhoto.add('group',undefined);
      Dlg.gMain[caption].gPageItems.gPhoto.molgrew.cb = Dlg.gMain[caption].gPageItems.gPhoto.molgrew.add('checkbox',undefined,undefined);
      alert("1 = " + caption + " 2 = " + molgrew);
      function bar()
      Dlg.gMain[pageType].gPageItems.gPhoto.caption.cb = Dlg.gMain[pageType].gPageItems.gPhoto.caption.add('checkbox',undefined,undefined);
      alert("1 = " + pageType + " 2 = " + caption);
      foo();
      bar();
      The two alerts are exactly identical. However, I get the error: "Undefined is not an object" in function bar()
      When checking the types of the references Dlg.gMain[pageType].gPageItems.gPhoto.caption is undefined. I have no explanation as to why that is.
      Cane someone help me out, please?
        • 1. Re: Undefined is not an object
          Marc Autret Level 4
          Assuming that:
          (1) Dlg is a global variable,
          (2) caption and molgrew are known within foo(),
          (3) pageType and caption are known within bar(),
          (4) Dlg.gMain[caption].gPageItems.gPhoto refers to an existing object (in foo),
          (5) Dlg.gMain[pageType].gPageItems.gPhoto refers to an existing object (in bar),
          the error message you get simply indicates that the caption property is not defined in the Dlg.gMain[pageType].gPageItems.gPhoto object, and indeed your code does not show any statement which lets suppose that Dlg.gMain[pageType].gPageItems.gPhoto.caption is defined, so you cannot create the property Dlg.gMain[pageType].gPageItems.gPhoto.caption.cb.
          FYI, JavaScript does not allow you to create a 'chain of properties' in one line:
          // The following code will throw
          // "Undefined is not an object!"
          // because obj.prop is not defined
          var obj = {};
          obj.prop.subprop = 'wrong!';
          // You HAVE to do something
          // like this:
          var obj = {};
          obj.prop = {};
          obj.prop.subprop = 'right!';
          Marc
          EDIT: However the JSON syntax allows you to create a complex object this way:
          var obj = { prop: { subprop: 'right!' } };
