5 Replies Latest reply on Jul 20, 2007 10:59 AM by Newsgroup_User
    Can HTML affect embeded FLASH
    adjourney
      I am trying to find out if there is any way to have the HTML send informaion to the embedded FLASH file. I need to change 2 peices of information on the FLASH file when it loads on the page (based on the page it comes up on.) Is there a way to have the HTML send a message to FLASH that says use "pic_2.jpg" or a way for Flash to look into the HTML to find its directive. Better yet, is there a way to let flash know what file it is within, and search the XML file based on the parameter of location? Please help.
        • 2. Re: Can HTML affect embeded FLASH
          adjourney Level 1
          It seems that through this I can change the text contents, but what if I wish to point to an external image, and want to load that jpg into an empty movie clip within Flash. How do I do that? I suppose I could assign a value to a variable (say "image" = 5) and then look up the XML to pull the variable (grabs image definition 5, and pulls the referenced image). Am I on the right track, or am I shooting beyond capability (of my own I am sure - but what of Flash)?
          • 3. Re: Can HTML affect embeded FLASH
            Level 7
            Hi adjourney,
            External images should work in the same way (via flashvars). You can do
            this in a two step process as you suggested, or directly via the
            embedding variables. I'll assume you want the simpler of the two so you
            would do something like this:
            The HTML embedding code would look like this:
            <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000"
            codebase=" http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,0,0"
            width="354" height="63" id="myFlashThing" align="middle">
            <param name="allowScriptAccess" value="sameDomain" />
            <param name="flashvars" value="imageFile=myImage.jpg" />
            <param name="movie" value="flashFile.swf" /><param name="quality"
            value="high" /><param name="bgcolor" value="#cccccc" /> <embed
            src="flashFile.swf" quality="high" bgcolor="#cccccc" width="354"
            height="63" name="forumLogo" align="middle"
            allowScriptAccess="sameDomain" allowFullScreen="false"
            flashvars="imageFile=myImage.jpg" type="application/x-shockwave-flash"
            pluginspage=" http://www.macromedia.com/go/getflashplayer" />
            Notice that you need to include the file name two...once as a "param"
            and then again in the "embed" tag. This is done to compensate for
            differences between FireFox/Mozilla browsers and InternetExplorer-style
            browsers.
            In Flash, getting the image file name couldn't be easier. In
            ActionScript 2.0, this is simply available as: _level0.imageFile
            In ActionScript 3.0, this is available as:
            this.loaderInfo.parameters.imageFile from the class that's associated
            with the main movie clip (the Document class).
            Now you simply take this value and use a loadMovie or Loader instance to
            get your image.
            If you wanted to specify an XML file and then some identified within it,
            the flashvar would look something like this:
            xmlFile=data.xml&offset=5
            And this would be received as two separate values in Flash:
            _level0.xmlFile and _level0.offset (and the associated ones for AS 3).
            Of course this is a bit of overkill...if you're specifying a file and
            then hardcoding a link within that file...you might as well specify the
            file right off the top. But I guess that's up to you.
            Patrick
            http://www.baynewmedia.com
            Faster, easier, better...ActionScript development taken to new heights.
            Download the BNMAPI today. You'll wonder how you ever did without it!
            Available for ActionScript 2.0/3.0.
            • 4. Re: Can HTML affect embeded FLASH
              adjourney Level 1
              I found a link on FlashVars - and followed it to http://www.permadi.com/tutorial/flashVars/ - which shows how to do basically what I am after. The code they reference says:
              <OBJECT classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"
              codebase="" http://macromedia.com/cabs/swflash.cab#version=6,0,0,0""
              WIDTH="250" HEIGHT="250" id="flaMovie1" ALIGN="CENTER">
              <PARAM NAME=movie VALUE="flaMovie1.swf">
              <PARAM NAME=FlashVars VALUE="imageFilename=images%2Fimage1%2Ejpg">
              <PARAM NAME=quality VALUE=high>
              <PARAM NAME=bgcolor VALUE=#FFFFFF>
              <embed src="flaMovie1.swf" FlashVars="imageFilename=images%2Fimage1%2Ejpg"
              quality="high" bgcolor="#FFFFFF" WIDTH="250" HEIGHT="250"
              NAME="flaMovie1" ALIGN TYPE="application/x-shockwave-flash"
              PLUGINSPAGE=" http://www.macromedia.com/go/getflashplayer">
              </OBJECT>
              Question though - I created an empty MC and have script tht simply reads:
              empty.loadMovie("imageFilename");
              >> and I have tried it without the "" - what am I missing - cause I can't get it to work. (I have the images in a folder byt the requested name. . . )
              • 5. Re: Can HTML affect embeded FLASH
                Level 7
                Are you saying that your actual command is
                empty.loadMovie(imageFilename);? If so, is there a reason why you
                included the quotes in your reproduction below?
                Also, you seem to have omitted the _level0 reference. It should be:
                _level0.imageFilename. This is where the variable is stored and if this
                command is being called from within a movie clip or some other object,
                it's very likely that that object doesn't have this variable.
                As a test, try the following:
                Create a dynamic text field on your _root timeline named "myField"
                (instance name). When you're at the point where you're trying to load
                the image, add the following like of code (and don't forget the _root!):
                _root.myField.text='local imageFilename='+imageFilename+' --
                _level0.imageFilename='+_level0.imageFilename;
                This should show you if it's simply that you're forgetting the _level0
                or if the variable isn't being passed in.
                What do you see?
                Patrick
                > </OBJECT>
