7 Replies Latest reply on Sep 20, 2010 1:26 PM by mikec82
    Multiple formats in same sequence
    mikec82 Level 1
      I have officially switched from using a Mac to edit wedding videos over the past 8 years to a PC. And I'm switching from Final Cut to CS5. I film weddings with three cameras. One is a T2i (so h264 .mov files), and the other 2 film to mini DV tapes. In the past, I've converted all the footage to ProRes 422 in Compressor and edited in a ProRes sequence. As I understand, I'll now be able to edit the T2i footage natively, but I am unsure how I should go about capturing (or transcoding) the miniDV footage so that it will flow best with the T2i footage. Any assistance is appreciated. Thanks, and I'm looking forward to all the great features Premiere has to offer!
        • 1. Re: Multiple formats in same sequence
          Studio North Films Level 3
          it depends on the format of the h264 you are using, and what you will be exporting to.
          Remember: its always best to scale down then scale up. So you may want to open a dv project and downscale the h264 to fit.
          Baz
          • 2. Re: Multiple formats in same sequence
            Colin Brougham Level 6
            Do you shoot fullscreen (4:3) or widescreen (16:9) with the DV cameras? Do you shoot 60i or 24p with the DV cameras? What format do you shoot with the T2i?
            Basically, you'll want to use the lowest common denominator in most circumstances, which is DV for you. As long as your frame rates are the same between the DV cams and the T2i, just pick the DV preset that matches your DV footage, and scale the T2i footage down to fit. For DV, you have choices like:
            DV NTSC
            DV NTSC Widescreen
            DV 24P
            DV 24P Widscreen
            No need to convert anything; just drop everything in the sequence and edit away.
            • 3. Re: Multiple formats in same sequence
              mikec82 Level 1
              Thanks for the quick responses. I'll export to DVD files (MPEG2/aac), a 1080p .mov file, and a 720p .mov file. I shoot all widescren, all 30 fps. Sounds like the DV NTSC Widescreen would be the best sequence. Since this is my first time in Premiere CS5, how will I resize the T2i footage?
              • 4. Re: Multiple formats in same sequence
                Are these DV cameras or HDV cameras? If DV, you're not going to have really great results creating HD output from SD source. If it's HDV, you don't want to use a DV sequence, but instead use a relevant HDV preset.
                Ultimately, scaling standard definition to high-definition by any method is not optimal; the results are nowhere close to shooting in HD originally. In addition, it doesn't make much sense to scaled HD video down to SD for editing, only to scale it back up to HD for output. Clarify your source cameras for a better recommendation.
                Premiere has a "scale to fit" option in the preferences; I don't recommend using this, as everything you drop into ANY timeline gets scaled, whether it's larger or smaller. You can scale to fit on an individual basis (right-click a clip), but the better way is to use the Scale parameter on a single clip, save that as a preset, and apply that to other instances of the T2i footage elsewhere in the sequence. Alternatively, you can copy the Motion effect (where Scale is located) and paste it to the other clips.
                • 5. Re: Multiple formats in same sequence
                  mikec82 Level 1
                  Sorry - I guess that would help! The two other cameras are Canon HV40s (HDV).
                  • 6. Re: Multiple formats in same sequence
                    OK, so you can use an HD sequence; forget the DV recommendations.
                    Now, you need to be specific about which mode you're shooting in with each camera. The HDV cameras are 1440x1080, but you have the option of 30p or 60i (sometimes called 30i). Since the T2i only has one 30p mode (1920x1080, 30p), I'll assume that that's what you're shooting in, but please correct me if I'm wrong.
                    If all of this is true, I would use the "DSLR 1080p30 @ 29.97" preset in Premiere. This is the best common denominator with those footage choices. You could also use "HDV 1080p30" but I prefer to use square pixels (which is what the other preset uses) wherever possible.
                    No need to alter the dimension of any of the footage; it'll all drop in and fit perfectly. From there, you can export in all of the ways you want.
                    • 7. Re: Multiple formats in same sequence
                      mikec82 Level 1
                      All of that is true. Thanks for walking through that with me!
