6 Replies Latest reply on Sep 23, 2010 6:45 AM by Linda Valentin
    Textfield Loop - Rollover and Clickevents
    Jonas Philippon
      Hi.
      I have created a loop with 5 textfields (with 5 different names). The textfields autosizes and are in an array, so i can place every textfield as i want.
      - But how do i create rollover and click events to these textfields?
      - Is it possible to place this loop in a movieclip, where the movieclip autosizes according to the text in my text-array?
      This is for a menu only with text - no graphic.
      My Code:
      // INITIAL VARIABLES
      var buttonArray:Array = new Array( );
      var currentButton:Object=new Object;
      // NAVIGATION CONTAINER
      var navContainer:Sprite=new Sprite  ;
      addChild(navContainer);
      // NAMES OF BUTTONS
      var navArray:Array=["BUTTON 1","BUTTON 2","BUTTON 3","BUTTON 4","BUTTON 5"];
      // NAVIGATION BUTTONS
      var myFont:Font = new GillSansLight();
      var NavItemFormat:TextFormat = new TextFormat();
      NavItemFormat.font = myFont.fontName;
      NavItemFormat.size = 13;
      NavItemFormat.color = 0xCCCCCC;
      NavItemFormat.letterSpacing = 2;
      for (var i:Number=0; i<5; i++) {
      var NavItem:TextField = new TextField()
      NavItem.autoSize = TextFieldAutoSize.LEFT;
      NavItem.defaultTextFormat = NavItemFormat;
      NavItem.embedFonts = true;
      NavItem.text=navArray[i];
      buttonArray.push(NavItem);
      //NavItem.addListeners();
      navContainer.addChild(NavItem);
      NavItem.name=String(i);
      navContainer.buttonMode = true;
      navContainer.mouseChildren = false;
      Philippon
        • 2. Re: Textfield Loop - Rollover and Clickevents
          rHemanth Level 2
          import flash.events.MouseEvent;
          var yPos:Number=10;
          navContainer.x=100;
          navContainer.y=100;
          // NAMES OF BUTTONS
          //var myFont:Font = new GillSansLight();
          NavItemFormat.font = 'Sans';
          NavItemFormat.size = 30;
          NavItemFormat.color = 0x000000;
          trace("in");
          var NavItem:TextField = new TextField();
          NavItem.selectable = false;
          NavItem.y=yPos;
          yPos+=35;
          NavItem.addEventListener(MouseEvent.CLICK,onClick);
          NavItem.addEventListener(MouseEvent.ROLL_OVER,onRoll);
          //navContainer.mouseChildren = false;
          function onClick(e:MouseEvent):void{
          trace("CLICK : "+e.target.name);
          function onRoll(e:MouseEvent):void{
          trace("ROLL :"+e.target.name);
          Based on the name of the text field u can have  various operations no need to add  the text field to separate movie clip and resize,u can add mouse events to text field too
          • 3. Re: Textfield Loop - Rollover and Clickevents
            Jonas Philippon Level 1
            Hi.
            Thank you for your answer (:
            I worked a little and made it work (: Thank you very much.
            - Can you maybe tell me how to put all the textfields in separate MovieClips?
            - And how do I make a function removeListeners():void {  } I need the textfields to remove listeners on click. But when i add the listeners, i do it in the NavItem loop. I cant do that with remove listeners?
            Thank you again (:
            • 4. Re: Textfield Loop - Rollover and Clickevents
              riquigley Level 2
              There are several ways you could do it.  I would try adding in the Remove Listener function in the handler for the clicks.  So, for instance:
              var tempTextField:TextField = e.target;  // this makes a reference to the TextField that was clicked
                    tempTextField.removeEventListener(MouseEvent.CLICK,onClick);  // this removes the listener
              Unfortunately, I don't have spare time to test it and see if assigning a TextField to another text field creates a reference to the original textfield (like it does when you create a reference to a MovieClip), or if it makes a clone of the original (new textfield, just with all the same properties of the old one).
              If it clones it, then the above won't work.  In which case, try this:
                    e.target.removeEventListener(MouseEvent.CLICK,onClick);  // this removes the listener
              • 5. Re: Textfield Loop - Rollover and Clickevents
                Hi.
                I actually got it to work. I used your last example - i havent tried the first (:
                Thank you.
                • 6. Re: Textfield Loop - Rollover and Clickevents
                  Linda Valentin
                  Thanks a ton for your response. I'll write back and let you know if it works.
