This content has been marked as final.
Show 3 replies
1. Re: Transition timeline effect flash? Where is it located?
kglad Sep 20, 2010 10:26 PM (in response to user7777)there's a different tween model available in cs5. if you right click in an appropriate timeline span and choose motion tween, you can use the motion editor panel and motion presets panel to create tweens or use pre-programmed tweens.
there's also the classic tween available in cs5 but you can't use the motion presets with the classic tween and timeline effects are not available.
2. Re: Transition timeline effect flash? Where is it located?
user7777 Sep 21, 2010 12:08 PM (in response to kglad)Thanks. I kind of get half of what you are saying. I'm using a old flash mx and half the buttons/menu in it are really different. I'm checking out the motion panel as we speak.
3. Re: Transition timeline effect flash? Where is it located?
kglad Sep 21, 2010 12:46 PM (in response to user7777)you're welcome.
check the motion presets, too. that's similar to the timeline effects with pre-programmed tweens.
