6 Replies Latest reply on Sep 21, 2010 3:37 AM by athiroy
    Display Labels using Arrays
    athiroy
      hi
      i am working in flex builder 4.
      I give input (for example 10) in text box .When i click the button at the time it produces 10 Labels.
      how i do it
      Give me some suggestion
      regards
      athi
        • 1. Re: Display Labels using Arrays
          BhaskerChari Level 4
          Hi athiroy,
          You can do something like below...the example is in Flex3 however you can apply the same logic in Flex4 just the syntax will chnage..instead of addChild you use addElement..
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" horizontalAlign="center">
          <mx:Script>
            <![CDATA[
             import mx.controls.Label;
                private function onButtonClick():void
                 var inputValue:Number = Number(textInput.text);
                 for(var intLoop:int=0;intLoop<inputValue;intLoop++)
                  var lbl:Label = new Label();
                  lbl.text = "Label" + (intLoop + 1);
                  labelBox.addChild(lbl);
          </mx:Script>
          <mx:HBox>
            <mx:TextInput id="textInput" width="200" height="25" restrict="0-9"/>
            <mx:Button id="btn" label="Click Me" click="onButtonClick();" />
          </mx:HBox>
          <mx:VBox id="labelBox">
          </mx:VBox>
          </mx:Application>
          Bhasker
          • 2. Re: Display Labels using Arrays
            athiroy Level 1
            hi
            thank u very much.
            Its working fine.
            regards
            athi
            • 3. Re: Display Labels using Arrays
              athiroy Level 1
              hi
              i use ur program. Its working fine.
              Now i want write Click method in that label.
              When i click that label it must displays the label.text.
              how i do it.
              pls give some ideas.
              regards
              athi
              Message was edited by: athiroy
              • 4. Re: Display Labels using Arrays
                athiroy Level 1
                hi
                how can i write the click method in this label.
                regards
                athi
                • 5. Re: Display Labels using Arrays
                  Hi Athiroy,
                  You can write the click method as shown in the below example...
                  <mx:Script>
                    <![CDATA[
                     import mx.controls.Alert;
                          lbl.addEventListener(MouseEvent.CLICK, onLabelClick);
                        private function onLabelClick(event:MouseEvent):void
                         var label:Label = event.currentTarget as Label;
                         Alert.show("You have clicked the label : " + label.text);
                  </mx:Script>
                  <mx:HBox>
                    <mx:Button id="btnFilter" label="Generate Labels" click="onButtonClick();" />
                  </mx:HBox>
                  </mx:VBox>
                  </mx:Application>
                  Bhasker
                  • 6. Re: Display Labels using Arrays
                    athiroy Level 1
                    hi
                    thanks a lot.
                    regards
                    athi
