6 Replies Latest reply on Oct 11, 2010 8:53 AM by jojoleo113
    Indesign Scripting : Generate a PDF
    jojoleo113
      Hello,
      I've a bug with my script. All is OK:
      The script imports the xml file in my Indesign file and the new file generated (.indd) is correct...
      But this script generates PDF files with only 2 pages.
      Do you know the right code to generate big PDF files?
      This is my script:
      var myTemplate = File.openDialog("choose a template");
      var myFolder = Folder.selectDialog("choose a folder to process");
      var myDocs = myFolder.getFiles("*.xml");
      for (i = 0; i < myDocs.length; i++) {
      // open template :
      var newDoc = app.open(myTemplate);
      // import XML :
      var myXMLImportPreferences = newDoc.xmlImportPreferences;
      myXMLImportPreferences.allowTransform = false;
      myXMLImportPreferences.createLinkToXML = false;
      myXMLImportPreferences.ignoreUnmatchedIncoming = false;
      myXMLImportPreferences.importCALSTables = false;
      myXMLImportPreferences.importTextIntoTables = false;
      myXMLImportPreferences.importToSelected = false;
      myXMLImportPreferences.removeUnmatchedExisting = true;
      myXMLImportPreferences.ignoreWhitespace = true;
      myXMLImportPreferences.repeatTextElements = true;
      newDoc.importXML(myDocs[i]);
      // add additional document-specific processing steps here
      // save :
      var newFileName = myFolder.absoluteURI + '/' + myDocs[i].name.replace(/xml/, "pdf");
      app.activeDocument.exportFile(ExportFormat.pdfType, File(newFileName),false);
      var newFileName = myFolder.absoluteURI + '/' + myDocs[i].name.replace(/xml/, "indd");
      newDoc.save( new File( newFileName ) );
      app.activeDocument.close();
