6 Replies Latest reply on Sep 25, 2010 1:48 AM by c.pfaffenbichler
    Apply adjustment to affect all layers when xport layers to files
    tedski Level 1
      Hi.
      Have a set of sequence images opened with Bridge and placed in photoshop as individual layers. I´ve croped the image and
      applyed som adjusments eg. curves etc. Now i want to save the layers as files from the file-scripts having the layer adjustments affecting
      my layers before saving.
      /Tedski
        • 1. Re: Apply adjustment to affect all layers when xport layers to files
          c.pfaffenbichler Level 9
          It’s certainly possible to achieve something like that.
          But I think it might be easier to start with a new Script and do without the dialog at all instead of trying to change the existing one.
          How experienced are you with JavaScript?
          • 2. Re: Apply adjustment to affect all layers when xport layers to files
            tedski Level 1
            Hi c.pfaff......
            Not good enough to script photoshop i guess. Maybe i´m doing it the wrong way all together. Is it another way of adjust multiple files without bringing them into photoshop as layers?
            /Tedski
            • 3. Re: Apply adjustment to affect all layers when xport layers to files
              One could create a Script that offers a dialog to select files (or a folder) and subsequently opens and adds the Adjustments to all those files.
              If nobody else has some Scripts ready for this or the original task I might give it a look on the weekend.
              But you might also search or ask at http://www.ps-scripts.com/
              • 4. Re: Apply adjustment to affect all layers when xport layers to files
                Michael L Hale Level 5
                If you want to apply the same adjustment( or add the same adjustment layer ) to every image you could make an action that applies the adjustment( or adds the adj layer ) then either batch that action or use Image Processor.
                • 5. Re: Apply adjustment to affect all layers when xport layers to files
                  tedski Level 1
                  I went to javascript forums where i got help editing *.jsx for photoshop, so it now applies adjustment to every single layer before saving as a file.
                  Thanks all for your time.
                  /Tedski
                  • 6. Re: Apply adjustment to affect all layers when xport layers to files
                    Well, you don’t need it anymore, but I still gave a Script that saves the pixel-layers as separate files with the Adjustment Layers flattened in a try; only for psd, though, so no format-selection.
                    If you want to give it a try …
                    // create psd-copies of  all pixel-layers with adjustment layers applied to them;
                    // thanks to xbytor for the regexp;
                    // 2010, use at your own risk;
                    #target photoshop
                    if (app.documents.length > 0) {
                      var thedoc = app.activeDocument;
                    var docName = thedoc.name;
                    var basename = docName.match(/(.*)\.[^\.]+$/)[1];
                    // get path;
                      try {var docPath = thedoc.path}
                      catch (e) {var docPath = "~/Desktop"};
                    // duplicate;
                      var myDocument = thedoc.duplicate ("thecopy", false);
                      var theLayers = hideAndCollectPixelLayers(myDocument);
                      var theArtLayers = new Array
                      if (theLayers.length > 1) {
                    // show one layer and save psd;
                        for (var m = 0; m < theLayers.length; m++) {
                          var aLayer = theLayers[m];
                          aLayer.visible = true;
                          savePsd (myDocument, aLayer.name, docPath, basename);
                          aLayer.visible = false;
                    // close duplicate;
                      myDocument.close(SaveOptions.DONOTSAVECHANGES)
                    ////// function to collect all pixel-layers and hide them //////
                    function hideAndCollectPixelLayers (theParent) {
                    if (!allLayers) {
                    var allLayers = new Array}
                    else {};
                    for (var m = theParent.layers.length - 1; m >= 0;m--) {
                    var theLayer = theParent.layers[m];
                    // apply the function to layersets;
                        if (theLayer.typename == "ArtLayer") {
                    // process pixel-layers;
                          if (theLayer.kind == "LayerKind.GRADIENTFILL" || theLayer.kind == "LayerKind.LAYER3D" || theLayer.kind == "LayerKind.NORMAL" ||
                          theLayer.kind == "LayerKind.PATTERNFILL" || theLayer.kind == "LayerKind.SMARTOBJECT" || theLayer.kind == "LayerKind.SOLIDFILL" ||
                          theLayer.kind == "LayerKind.TEXT" || theLayer.kind == "LayerKind.VIDEO") {
                            theLayer.visible = false;
                            allLayers.push(theLayer)
                        else {
                    allLayers = allLayers.concat(hideAndCollectPixelLayers(theLayer))
                    // this line includes the layer groups;
                    // allLayers.push(theLayer);
                      return allLayers
                    ////// function to save psds //////
                    function savePsd (myDocument, layerName, docPath, basename) {
                    // this clause changes the name if a file of that name exists in that location;
                      while (File(docPath+'/'+basename+"_"+layerName+".psd").exists == true) {
                        layerName = layerName+"_"+"1"
                      var thecopy = myDocument.duplicate (thecopy, true);
                    psdOpts = new PhotoshopSaveOptions();
                    psdOpts.embedColorProfile = true;
                    psdOpts.alphaChannels = false;
                    psdOpts.layers = true;
                    psdOpts.spotColors = true;
                    thecopy.saveAs((new File(docPath+'/'+basename+"_"+layerName+".psd")),psdOpts,true);
                    thecopy.close(SaveOptions.DONOTSAVECHANGES)
